Pete Jackson Gear Drive - Chevelle Tech
Auto Insurance
Old Apr 24th, 13, 5:28 PM
The Bullet The Bullet is offline
Default Pete Jackson Gear Drive
I am going to be rebuilding the Big Block currently in my car. I am have decided on the cam and heads that I will be using but there is one thing I am debating. I have always liked the sound of a "Noisy" gear drive and am considering installing a Pete Jackson Gear Drive.
What are the pros and cons to using one. The car will not be driven a great deal (2000 to 3000 per year).
Should I do the gear drive or a double timing chain?
Thanks!
Old Apr 24th, 13, 6:34 PM
chuckd71 chuckd71 is offline
Stu
Default Re: Pete Jackson Gear Drive
I had one in my car for about a day. One of the most obnoxious things ever.
L92 / 200-4r 71 http://www.ls1tech.com/forums/conver...s1-begins.html
Old Apr 24th, 13, 7:16 PM
boyd66k20 boyd66k20 is offline
Ive had one for awhile now and I dont mind it at all. Fits in with the whine of the m22. Personal choice in my book
66 SS-396/425 - M22 -3:73 -12 bolt
USN-SSBN 645-G
Old Apr 24th, 13, 7:34 PM
1971ss454Elco 1971ss454Elco is offline
Marc
You will encounter many opinions but I will tell you that I love that sound. Those that either cant or wont appriciate that sound will never understand. Its just a car guy thing I guess.
-its just like the annoying drone of some mufflers-it can get old real fast.
This one dosent sound to bad actually
Marc S
Old Apr 24th, 13, 8:49 PM
Chevycollecter Chevycollecter is offline
I had that set up in my 71 Nova. It was cool for a while and it did turn heads. Got tired of it, replaced with a double roller and sold the gear drive at a swap meet. I guess everyone needs to have one once in their lives.
  #6
Old Apr 24th, 13, 9:16 PM
69 Malibu 69 Malibu is offline
Team Member
Todd
I had a noisy one for less than a week......
468, 781s, th400, 3.73s, Lunati 241/249 .625 hyd roller, Weiand Tunnel Ram, Twin 750 DPs, Freakshow 9.5" 4100 converter, 28x10 Goodyear slicks. 3440 lbs without me. 100 shot n2o
Best ET 10.46
Best MPH 127
Best 60 1.47
Best 1/8 6.65 104
http://tinyurl.com/60213IDLE
http://tinyurl.com/Drag-Run
http://tiny.cc/69pics
  #7
Old Apr 24th, 13, 9:35 PM
Turbine Turbine is offline
Chris
What!?!
71 Chevelle
LM7 5.3l genIII 295hp / Th-350 / Quick Performance 9 inch housing, Ford 3.55:1 Traction - Lok, Moser Axles, Gm Disc / Drum brakes.
LS & 9 inch Swap complete!!!
255/45/17 front, 275/40/17 rear, SPC Springs, stock suspension other than Koni Classic D fronts for now. Planning SC&C Stage II+ front / UMI arm Rear
  #8
Old Apr 24th, 13, 9:41 PM
jackie schmidt jackie schmidt is offline
jackie
They have been around forever. I used them exclusivly in our Race Boats back in the '70's. You could hear it whine over the open headers.
I never had any problems, even with the latest in heavy seat pressure valve spring tech back then.
They actually make a noisy one, and a quiet one. From what I remember, I would go with the quiet one.
'67 Chevelle Malibu, Catalina Blue, 540 inch Rat, Air Flow Reasearch 290 CNC Heads heads, Custom Hyd Roller, .675 lift, 234, 244 at .050, Lemons Headers, TCI 6X 6Speed Automatic, 12 bolt Posi, 3:31 Richmond Gears, front and rear power disc brakes, Global West Suspension, etc.
http://www.chevelles.com/showroom/sh.../22377/cat/604
  #9
Old Apr 24th, 13, 11:05 PM
Uppster Uppster is online now
Gold Member
Edd
I have heard it said that it is for blower motor want-to-be's.
  #10
Old Apr 24th, 13, 11:36 PM
crtrailrider crtrailrider is offline
Ive had three of them in different motors they turn heads when driving down the road
  #11
Old Apr 25th, 13, 12:26 AM
sschevellefan sschevellefan is offline
Banned
Anthony
This is going to start a debate. I loved my Pete Jackson noisey geardrive. I had dumped 2 chamber flows with my old 327 and could barely hear it from inside the car but outside was the typical noisey geardrive. I still like them and would run another one but unfortunately PJ went out of business. I would run a quiet one though just because. You will get people who will tell you it creates cam harmonics because of the gear on gear but Ive never seen a engine blow because of cam harmonics. I dont really see the problem. Pretty much the same idea as the gears in a manual transmission or a ring and pinion. Those are both gear on gear.
  #12
Old Apr 25th, 13, 5:05 PM
Stu
Right, a car guy thing, whatever that means. There is nothing to understand or appreciate; it's some gears in a motor that make a whining noise, it isn't art, science or sculpture. It's not as though liking them means you are somehow enlightened or aware of some cosmic secrets about meaning of life, it's sound and either you like it or you don't, it doesn't mean anything more than that. If OP likes the sound he should use them, if not he shouldn't.
  #13
Old Apr 25th, 13, 6:21 PM
65cayne 65cayne is offline
Well said Stu.
The biggest "pro" is rock solid timing which can also be had with a quality roller timing chain. The biggest "con" is you decide you dont like it and have to tear your engine apart to install a chain.
I've been running the PJ "Quiet" version for about 7-8 years and maybe 10-12k miles with no problems. Some days I like it, some days I dont. I loved the way they sounded on other peoples cars... "bad a#s" I think was the term.
Like someone said earlier (paraphrasing), if you think you want one, then just do it and get it out of your system. You'll either love it or hate it. It's what YOU think that matters. It's your car you know? Have fun and post a video.
-Kevin
1965 Chevy Biscayne
454cid, "peanut ports", Voodoo 60201, Approximately 9.37:1 CR
TH400, 3.36 Stock Rearend
  #14
Old Apr 25th, 13, 6:30 PM
shomejim shomejim is offline
jim
Forget the gear drive. If you want the whine put a blower on it.
  #15
Old Apr 25th, 13, 7:16 PM
pink panther pink panther is offline
harvey
I have a pete jackson gear drive in my 355 it's louder than most 671 blowers LOL it's if u can put with it sounds awesome i love mine had it in for13 years still going strong the motor is and i run it hard
Chevelle Tech > Mechanical > Engine      Current Topic: Pete Jackson Gear Drive
Location
*REQUIRED*
Insurance
First Name
Human Verification
