402 bbc 500 hp? - Chevelle Tech
Auto Insurance
Old Apr 17th, 13, 6:19 PM
RoyaltyRides RoyaltyRides is offline
Win
Default 402 bbc 500 hp?
I have a 1970 402 bbc. Checked my casting numbers and it makes 325/335hp. I've heard its hard to make huge hp from a 402. Hopefully can tell me the range I'm in. Here is what the motor has:
10.5:1 CR
Lunati 60204 cam and lifter kit .554/.572
Aluminum oval port heads 2.25 int/1.85 exh
Edelbrock Air Gap Intake
Holley 750 Double Pumper
2800 stall with 3:73 gears out back.
Old Apr 17th, 13, 6:25 PM
kev574 kev574 is offline
Default Re: 402 bbc 500 hp?
I'd say around 450 horse.
Old Apr 17th, 13, 7:38 PM
kettbo kettbo is offline
George
could you be VERY SPECIFIC on the heads?
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
Old Apr 17th, 13, 9:04 PM
Win
Prostar heads machined to match my cam specs
300cc intake runners
115cc combustion chambers
valve springs are .600
7/16 rocker studs
Old Apr 17th, 13, 9:09 PM
pauls72 pauls72 is offline
Paul
Wtf are prostars
72 chevelle
496ci bbc
Rpm air-gap
Trick Flow 280 power ovals
850 dp
Straub hyd roller 238/246 .643-.620 107
10.7 cr
Th350
9" 3:73
  #6
Old Apr 17th, 13, 9:30 PM
Win
typo I was tryna multi-task.. they are pro comp heads
  #7
Old Apr 17th, 13, 11:12 PM
VORTECPRO VORTECPRO is offline
MARK
Mike Lewis' 408 made I believe 540 HP.
  #8
Old Apr 18th, 13, 8:05 AM
bracketchev1221 bracketchev1221 is offline
I made 501 with 781 casting steel heads, and a Lunati 40209 solid flat tappet cam. 10.5.1 compression, airgap intake and 800 holley.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
  #9
Old Apr 18th, 13, 9:46 AM
putput putput is offline
mike
I made 490hp, 450tq with 10.5-1, oe 215 heads with some port work and a comp 294 mech cam.
68 camaro
496ci 644tq 730hp and a lot of the street
shake down pass, 10.76 @128.52
fun>>
  #10
Old Apr 18th, 13, 2:42 PM
Win
If I'm in the 450-500 range I'm totally okay with that. I know the only true way is to dyno. I just wanted to make sure I was on the right track. This is my first big block build
  #11
Old Apr 18th, 13, 2:51 PM
I'd say your in that range, have you drove it yet?
  #12
Old Apr 18th, 13, 4:41 PM
Win
Drove it before with the cast iron heads and a 650, but swapping the aluminum heads on with the 750 this weekend. It has hooker comp headers and super 44 flow masters
  #13
Old Apr 18th, 13, 4:44 PM
badrad badrad is offline
jimmyradford
I personally wouldn't use the Procomps or heads with a 2.25" valve in that bore due to shrouding. A decent set of factory closed chamber ovals will do wonders for the 396/402 based engines.
TC Member # 4431
'04 Ram Quad-That thing has a Hemi in it!
'93 F350 Centurion-I needed something big to haul my ego.
'67 Hell Camino-BB 427/TH400/???
'65 Elky-327/TH350/3.08 peg leg
'55 BelAir 2 door post-327, in progress/TH-400/4.10
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
  #14
Old Apr 18th, 13, 5:09 PM
Paul
Ya I don't like those heads either
72 chevelle
496ci bbc
Rpm air-gap
850 dp
10.7 cr
Th350
9" 3:73
  #15
Old Apr 18th, 13, 5:24 PM
Win
It came with the the factory ovals. I'm not a fan of cast iron heads. All the extra weight but can you give me a little more explanation about the shrouding with 2.25s
Chevelle Tech > General Tech Area > Performance      Current Topic: 402 bbc 500 hp?
Human Verification
