Cowl Induction flapper door install - Chevelle Tech
Auto Insurance
2000 Tech postings from 2000
Reference and reply only.
Old Sep 22nd, 00, 3:45 PM
jimmy jimmy is offline
Jim
Send a message via ICQ to jimmy
Default
Ok, I think I have all the parts to install the flapper door on my new repo CI hood, but something isn't quite right.
Here is a pic of the parts I have.
http://members.home.net/azjimmy/ciparts.jpg
The bolts and bushings on the left are what the door pivots on, correct? The 4 bolts in the center of the pic screw into the under side of the hood. Now is where I'm confused. The flat part of the bracket has 2 large unthreaded holes. What are these for? The other part of the bracket has 2 small threaded holes, while the other side has 1 small threaded hole. Can someone explain how this all goes together?
Thanks,
Jim Endrud - TC Gold #45 - ACES #3507
72 El Camino SS Clone
GM muscle cars - members.home.net/jimmy4
El Camino gallery - members.home.net/jimmy4/elkygallery.html
www.classicswapmeet.com
Quick reply to this message
Old Sep 22nd, 00, 4:41 PM
Jim
Default
Update:
I think I got the door on, but it sits high and is not centered. Are you supposed to use shims between the hood and the brackets to lower the door so its level with the hood?
Thanks,
Old Sep 22nd, 00, 7:22 PM
DZAUTO DZAUTO is online now
Team Member
Tom
Default
Jimmy,
From the factory, there were shims between the hood and and hinge. These shims are no longer available AND are NOT reproduced. So just use use small washers, works fine.
PAY ATTENTION TO THIS! WHEN SCREWING THE BOLTS IN WHICH HOLD THE HINGE TO THE UNDERSIDE OF THE HOOD, BE CAREFUL THAT THEY ARE NOT TOO LONG. IF THEY ARE A LITTLE TOO LONG AND YOU SCREW THEM INTO THE UNDERSIDE OF THE HOOD TOO FAR, YOU WILL HAVE BUMPS APPEAR ON THE TOP SIDE OF THE HOOD. ---------guess how I know.
Tom Parsons
Chevelle Tech > Team Chevelle > Archives > 2000      Current Topic: Cowl Induction flapper door install
Human Verification
You may not post new threads
You may not post replies
