67 el camino BBC w/long water pump? - Chevelle Tech
Auto Insurance
Old Mar 20th, 13, 12:14 AM
Jim Mac Jim Mac is offline
Send a message via AIM to Jim Mac
Default 67 el camino BBC w/long water pump?
I did a search and it looks like its doable. Is there any thing I should be aware of?
Ive got a 454, hedman headers for a bbc A body, and the accy brackets I have are the long waterpump variety. Only thing Im missing is the lower alternator bracket, Other than that I have the upper bracket, waterpump pulley, crank pulley, PS brackets for the later style pump, (not the banjo style).
I know about the oil pan for a A body, but it looks like thats it for having to buy stuff. For the radiator, im going with a ebay aluminum radiator.
Any input is greatly appreciated.
The car is a 67 el camino that had a big block that was removed before being sold. thanks. im
Jim
68 el camino custom, daily driver 327 th 350
70 chevelle, SS clone 454 4 speed
71 el camino, SS clone (sold!)
71 nova 350 4 speed with 4.10 gears! Sold
71 camaro. (owned since 1978!) 6-71 blown small block!
67 el camino 307/th400-3.31 12bolt
Old Mar 20th, 13, 12:27 AM
novaderrik novaderrik is offline
Derrick
Default Re: 67 el camino BBC w/long water pump?
my cousin had a 66 Chevelle with a 402 that had the long water pump.. he had just enough room to squeeze a factory 4 blade solid fan in there... it was tight, but he drove that thing everywhere and beat the hell out of it without any cooling problems..
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
Old Mar 20th, 13, 6:06 PM
busterwivell busterwivell is offline
Bill
Yah, but he didn't do it in Arizona in July or August. Jim, you gonna run electric fan(s)?
Old Mar 20th, 13, 6:17 PM
hpsherlin hpsherlin is offline
Team Member
Herbie
Jim Mac,
I have a 454, LWP, alternator on L side in my '67.
I run a fixed blade 17" fan, a short spacer to get past the alt pulley, and a factory repro fan shroud, with an Alumitech radiator.
No problems.
http://www.chevelles.com/forums/pict...&pictureid=490
Herbie
'67 SS Chevelle 460"
XE284, 9.97:1, CK 2004R, 3.42 12bolt
Holley 770SA, RPM AirGap, 3200 stall
Old Mar 20th, 13, 6:48 PM
Derrick
MN in July isn't exactly a cakewalk for cooling systems..
-Hank Hill
  #6
Old Mar 20th, 13, 7:00 PM
Im hoping to get away with a fixed fan or a flex fan, I am going with a aluminum radiator. The motor I have is a stock truck type 454 so its not a high horse motor, hopefully just torquey. The tranny is a TH350 with a shift kit and a 2500 stall and the rear gears are 3.08. My buddy did offer me a deal on a 454 last night. I think its about 9.5 to 1 peanut ports, performer cam and intake. Fresh riings bearings oil pump and gaskets. The motor came out of another friends truck that he sold. It was a great running motor, but since it was out my friend decided to freshen it up. Comes with the swp brackets and pulleys, bb fan shroud, motor mounts. Only issue I have is convincing my wife to pitch some cash in on the project. jim
Jim
  #7
Old Mar 20th, 13, 8:07 PM
OLDED OLDED is offline
Team Member
Ed
I run a new, stock replacement, BBC 66 radiator in the 65. I use a full 66 shroud and fixed blade fan setting 1/2 in and 1/2 out of the shroud - along with a long water pump. The fan sets about 3/4" from the radiator. The 66/67 radiators are a true full crossflow and are pretty efficient if in good condition.The iron head 496 never gets over 190 in heavy traffic, but typically runs at 170 - 180 regardless of the outside temp when moving down the road. It has a 180 stat in it. Did the same set up to a friends 66 with a ZZ502 and it runs about the same, maybe 5 degrees higher. Ignition timing is crucial to running cool too, I find that I need at least 16 degrees base to let it run cool. FWIW. Ed
OLDED - It's STOCK if it's made by GM and it fits!
*65 Elky, Gen VI 496 BBC, TH400
*59 Vette, 283/270 hp. T5 5 spd., 4:11 posi.
*Harley - 06 Street Bob
*Life Member - Team Chevelle & Team ElCamino
*Peach State Chevelle Member
*Retired June 1, 2014****
  #8
Old Mar 20th, 13, 9:08 PM
jackie schmidt jackie schmidt is offline
jackie
My 67 Malibu has a Edlebrock long Aluminum Water Pump. I had a custom 4 row copper radiator built. I use a high performance flex fan with a shroud. No cooling problems for my 540 inch Rat at all.
The flex fan clears the radiator by about an inch.
'67 Chevelle Malibu, Catalina Blue, 540 inch Rat, Air Flow Reasearch 290 CNC Heads heads, Custom Hyd Roller, .675 lift, 234, 244 at .050, Lemons Headers, TCI 6X 6Speed Automatic, 12 bolt Posi, 3:31 Richmond Gears, front and rear power disc brakes, Global West Suspension, etc.
http://www.chevelles.com/showroom/sh.../22377/cat/604
  #9
Old Mar 20th, 13, 9:49 PM
Anderson3754 Anderson3754 is offline
Anderson
My 67 chevelle is a 427 long water pump, oem standard radiator with a 15in fan, big block fan shroud with a 1in fan spacer I think, to clear the alternator. ALL I did was reroute the harness over to the pass side, purchased 70 BB brackets bolted everything up and never looked back.
I have a 427 bored .030 over, approx 420-430 hp and have absolutely no run hot conditions in heavy stop and go traffic, at freeway speeds, or when I make a frequent run of 10mi at 100mph in the dead of summer 80-90 degrees to see a friend.
Playing the ultimate game every day
  #10
Old Mar 20th, 13, 10:13 PM
Are you guys running power steering too? Thanks.
Jim
  #11
Old Mar 20th, 13, 11:34 PM
Anderson
I am.......... all my brackets, power steering and alternator are for a 70 Chevelle
  #12
Old Mar 20th, 13, 11:40 PM
Thanks! the only thing it looks like im going to be ordering is a oil pan, PST motor mounts and a lower alterantor bracket (which im sure I have, just have to find it). jim
Jim
  #13
Old Mar 21st, 13, 8:28 AM
Team Member
Herbie
I am.
Herbie
  #14
Old Mar 21st, 13, 10:31 AM
forcd ind forcd ind is offline
i had a 65 with a Procharged 496-i used a long WP, 67 BB fan shroud, and a 7 bladed aftermarket fan-Flexlite or something, Procharger PS kit
i used a cheap Ebay rad for a 65, never ran hot at all, did a short spacer on the fan
when your credit cards are maxed, have the limits raised
  #15
Old Mar 21st, 13, 12:36 PM
jvoiles jvoiles is online now
Jon
Fixed flex fan W/power steering and a/c. I had problems until i goy shroud. 3 row radiator as well, 180 in heavy traffic, 190 with air on in heavy traffic.
Sent from my HTC One X using AutoGuide.Com Free App
'66 Marina Blue SS Clone
427 BB 10.5:1 cr
Sft cam 243/251 @.050
AFR 265
Keisler RS600 with 3.73 12 bolt posi
Holley 950 HP
Chevelle Tech > Mechanical > Engine      Current Topic: 67 el camino BBC w/long water pump?
Human Verification
