Oil leak from the PCV grommet - Chevelle Tech
Auto Insurance
Old Mar 3rd, 13, 5:25 AM
LMacdonald LMacdonald is online now
Larry
Default Oil leak from the PCV grommet
I am trouble shooting an oil leak from the grommet around the PCV. It does not leak all the time and it does not leak very much, but it is annoying.
I have a SBC 383. I have a breather on the right side and a PCV value on the left side.
The PCV value is connected back to the carb.
Both are new, less than 500 miles.
The breather is a K&N and the grommet for the breather has a slit in the bottom that acts as a baffle. I checked the breather and is seems to be working fine.. (it took me a while to get the oil off my lips ).
One guess is at higher RPM the pressure in the crankcase builds up and actually forces the rubber baffle in the breather grommet to close. The weakest point is the grommet on the PCV value.
Anyone have a similar problem?
Larry
TC # 1000
66 Malibu - completed transformation 2000 - 2013
Old Mar 3rd, 13, 8:02 AM
65 Skylark 65 Skylark is offline
Bill
Default Re: Oil leak from the PCV grommet
Is there a baffle in the valve cover under the PCV?
Bill
_____________________________________________
'65 Buick Skylark,
355 sbc, 10.2 comp, Trick Flow 195 heads, RPM Air gap, Holley 3310, Bullet 224/230 .483/.485, Hedmans, 200-4R, 10" 2,800, 4.10 12 bolt.....and factory a/c
http://s1085.photobucket.com/albums/...t=Buick007.jpg
Old Mar 3rd, 13, 11:14 AM
Larry
Bill, there is no baffle built into the valve cover. The grommet has a rubber floor that seems to work like a baffle. My thought is if that was the problem the oil would not wind up on the valve cover it would be sucked into the carb.
Larry
TC # 1000
Old Mar 3rd, 13, 12:02 PM
72LS3Z27 72LS3Z27 is online now
Chris
Are they morosos?Their bafflegrommets open up to let more oil thru on high rpm driving.
I was running a set of blue morosos on my 454,no baffles.Was sucking oil thru the pvc and sending it thru the plugs.You couldnt see it or smell it though as it was only happening on high rpm driving,something to do with,I was told,the low tension metric rings gm uses in my gen VI.
I wound up making a set of low profile,wide metal baffles and riveting plus black rtv-ing them into the morosos.Works good now.
For loose hole stamps in the covers I clean well and black rtv the grommet in.
GenVI 454,Autogear M-22W,Moser 12 w/3.42s
'67 Malibu,283 w/ Powerglide 62000 Original Miles
Old Mar 3rd, 13, 1:25 PM
Larry
Not K&N.. I think it is Mr Gasket, I checked the part, there is no mfg name on it.
The oil is leaking between the grommet for the PCV and the valve cover. It is a tight seal, I am worried if I make the seal tighter by using silicone I will not have fixed the problem, just moved the weakest link like to the oil pan gasket.
You can see the baffle on the breather grommet, not sure if that is the problem. But I am suspecting it is closing up when high positive pressure is in the crankcase.
Click image for larger version
ID:	64641   Click image for larger version
ID:	64649   Click image for larger version
Larry
TC # 1000
  #6
Old Mar 3rd, 13, 1:33 PM
Chris
Where does the rest of your PVC hose go?(out of pic)
  #7
Old Mar 3rd, 13, 1:53 PM
LevonH LevonH is online now
Moderator
Levon
Try removing the breather and see if air is entering the engine. A small piece of paper moved over the hole should let you see if air is entering or leaving the engine. You should have air entering.
Those billet breathers can be a problem as well. Sometimes the screen is so fine that almost no air will enter through them.
I would also split those 2 vacuum connections into individual lines. 1 to the carb for PCV and 1 to the intake for the brakes.
Those rubber baffles can be a problem if there is no baffle in the valve cover itself. The rockers spray oil at the PCV inlet and oil will migrate into the PCV and around the grommet.
Levon Hovagimian
Team Chevelle #279
70 Chevelle SS 454 LS5 4 speed (Current Engine VortecPro 460 (513 HP) Original is resting
1966 427 Corvette SOLD
1973 Camaro IHRA Hot Rod (LS-6 Auto)11.00 @121 (Chased a 10.99 or better) SOLD
Priddis, Ab. Canada
My Showroom
  #8
Old Mar 3rd, 13, 2:24 PM
Larry
Chris, one end goes to the carb, the other end goes to the power brakes.
Thanks Levon.. I will try the test with a paper over the breather.
I am not sure if I have 2 ports on my carb, I will check.
The valve train is solid lifters and roller rockers. The cam is a street/strip cam so I am sure there is a lot of oil splashed around inside.
The leak is very minor and I can live with it, but it is annoying. I wonder if there is a better grommet that would still act as a baffle. There is no baffle in the valve covers.
Larry
TC # 1000
  #9
Old Mar 3rd, 13, 2:57 PM
Chris
Wouldnt then,your power booster have oil from the pvc in it?I'd def. seperate them also.Usually power brakes need a manifold port to run good.
Those grommet baffles are prolly letting you down also.Thats a big hole on the one you picced.
Even with my baffles I made,I still run a moroso air/oil seperator and still get some in it.Its on the firewall,to the left.
  #10
Old Mar 3rd, 13, 4:53 PM
Larry
Thanks Chris. I will check to see if I have oil in the vacuum line going to the power brakes. I assumed (likely incorrectly) the PCV valve would have a 1 way valve that would suck air out, but not let anything in. I do not have a vacuum port in my intake manifold (Victor Jr). I do have a spacer that goes under the carb that has a vacuum port, but I am not sure I have the clearance to install it. I need a low profile air cleaner so my hood would close.
Larry
TC # 1000
  #11
Old Mar 4th, 13, 12:20 AM
PA Camaro Guy PA Camaro Guy is offline
Brian
x2 Definitely get that PCV on its own dedicated line back to the carb. Keep the booster on a clean vac line shared by other components. Aside from contamination, you'll actually lose break assist at times the PCV is in operation.
  #12
Old Mar 4th, 13, 5:52 AM
novaderrik novaderrik is offline
Derrick
make the baffled grommets into regular grommets, keep the K&N breather on one side, and put a Mopar style breather in the other side with the pcv in line after that..
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
Tags
oil leak, pcv grommet
Chevelle Tech > Mechanical > Engine      Current Topic: Oil leak from the PCV grommet
Human Verification
