is there any way to increase valve retainer to seal clearance? - Chevelle Tech
Auto Insurance
Old May 8th, 03, 6:25 PM
john6066 john6066 is offline
Team Member
Post
i'm glad you guys talked me into checking the clearance between the valve retainers and oil seals. i'm aprox. .076 short.
is there an easy way to fix this. are there shorter retainers for instance? i don't really want to pull the heads. i've seen different types of seals but i don't know if their shorter or not. i'm going to replace the valves, retainers and seals but i need recommendations on increasing clearance.
thanks john
Bad Papa's '69 Chevelle
Old May 8th, 03, 6:34 PM
cjlandry cjlandry is offline
Post
Are these Vortec heads? If so, I got around the seal to retainer clearance problem by ditching the positive seals and using umbrella seals. Of course they don't seal as well, but they keep the oil splash to a minimum.
Chad Landry
Real treasures give you hugs.
The rest is just stuff.
Old May 8th, 03, 9:26 PM
BillK BillK is offline
Super Mod
Mr Bill
Post
John,
There are valve locks that will give you an additional .050" but that is not enough by the sounds of it. The correct fix is to remove the heads and machine the tops of the valve guides down.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
1984 Buick Riviera - original owner (Wife's car)
Team Chevelle #100
Old May 8th, 03, 10:52 PM
Boldly procrastrinating
TerribleTom II
Post
Bill is right, as always. You're not close here, you need another .100". Might as well bite the bullet, all that jazz. But just think of all the valuable experience you're getting!!
Tom
Tom
Old May 9th, 03, 9:48 AM
Team Member
Post
i factored in the .060 suggested clearance. the .076 is with a thick shim of .057". is there an effective oil seal that i could use with a thin shim maybe an .015" to make up the difference? i only have to loose .034". isn't there a retainer made for this purpose?
i'l pull em if i gotta, but i'd rather be on the road. how about having the retainers machined down say .040"?
Chevelle Tech > Mechanical > Engine      Current Topic: is there any way to increase valve retainer to seal clearance?
Location
*REQUIRED*
Insurance
First Name
Human Verification
