Fuel Line help 71' - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Feb 5th, 13, 7:25 AM
71'bu 71'bu is offline
steve
Default Fuel Line help 71'
Ive researched for 2 days now and cant find a staright answer on what I need. How do I run the fuel lines and what size lines do I need? I plan on bending them myself. Its a mild 350 and I have the EEC(?) gas tank. The original lines are long gone. They used rubber hose the whole way on the outside of the frame. I plan on using my canister so I need to hook up the vent line(line). Short on money because of a wedding coming up and the government possibly furloughing us. Thanks for the help guys
Old Feb 5th, 13, 10:46 AM
K.R.Joye K.R.Joye is offline
Default Re: Fuel Line help 71'
did you try Inline Tube, they manufacturer most of the prebent lines for the industry they also carry straight stock in Steel or Stainless.
http://inlinetube.com/Preformed%20Li.../CH-CAT-03.htm
1968 - 72 Chevelle / Malibu / SS Main Fuel Lines
1970-72 Main Fuel Line 1pc, PS Side, 3/8" Hardtop
1970-72 Main Fuel Line 1pc, PS Side, 3/8" Conv.
1970-72 Fuel Return Line 1pc, PS Side, 1/4" Hardtop
1970-72 Fuel Return Line 1pc, PS Side, 1/4"Conv.
1970 - 72 Chevelle / Malibu / SS Fuel Emission Lines
1970 Fuel Vapor Line F to R 1pc, DS Side, 5/16" Hardtop
1970 Fuel Vapor Line F to R 1pc, DS Side, 5/16" Convertible
1971-72 Fuel Vapor Line F to R 1pc, DS Side, 5/16" Hardtop
1971-72 Fuel Vapor Line F to R 1pc, DS Side, 5/16"Convertible
1971-72 Vapor Tank Line 3pc
......._________
.../ /__________\ \
</______________\>
..| O O __ss__ O O |
..\_____|___|_____/
....|__|. . . . . .|__|
71 Chevelle SS Vert(Body-off/Matching#s) http://www.fquick.com/garages/viewga...=1&carid=56357
96 Impala SS http://www.fquick.com/garages/viewga...d=56401&page=1
Old Feb 5th, 13, 11:10 AM
steve
haha, I didnt think about looking at their site for the sizes. Thanks
Old Feb 5th, 13, 11:33 AM
toofastforyou toofastforyou is offline
Claude
I was told that all small block Chevelles came with 5/16" diameter lines, big block cars had 3/8"...Nowadays, they can be had in 1/2" !
Claude.
1971 Chevelle SS "496"
1987 Buick Grand National 9.53 @ 143.79 mph
Old Feb 5th, 13, 11:35 AM
steve
does it matter if I put 3/8 on? will this affect the motor?
  #6
Old Feb 5th, 13, 12:08 PM
David Bates David Bates is offline
Dave
Many of the higher horspower small blocks also had 3/8" sending units and lines. Even the current ZR1 Corvettes (638HP) and Cadillac CTSV (556HP) use 3/8" lines so you would be well served to use that size. Anything larger is just overkill on a typical street driver.
Dave
USAF Retired (1968-1988)
UTC Aerospace Systems, Space Systems International - Retired (1989-2014)
  #7
Old Feb 5th, 13, 4:49 PM
plain 69 plain 69 is online now
350 Small blocks that I have seen had 3/8" lines. 307 and smaller had the 5/16".
Original 138 car from Freemont. 67 SS Bench seat 4-speed car with 396, Original M-20 with factory 3.73 12 Bolt Posi.
"You can never go fast enough" James Taylor Two-Lane Blacktop
Member #3635
Tri-State Chevelle Member #F-10
Larry Grigsby
  #8
Old Feb 5th, 13, 9:42 PM
Did a little research and found `fuel return line' was only used on AC cars only. My non AC `71' SB only needed a 3/8 Fuel & 5/16 Vapor line.
......._________
.../ /__________\ \
</______________\>
..\_____|___|_____/
  #9
Old Feb 6th, 13, 12:33 AM
Chevy67 Chevy67 is offline
Kevin
I would use 3/8"for a feed line. On my car the BB's got a 3/8" and the SB cars had 5/16". I used a combo of braided SS and hard lines. Worked out pretty good and they feed the hungry 383 without a problem.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
Ermine White/Red 1967 Chevelle Malibu
Forged Mike Lewis 383 rotating assembly
AFR Eliminator 195's
Lunati Voodoo 60122 roller cam
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Jake's Performance 200-4R
  #10
Old Feb 6th, 13, 6:45 AM
steve
OK thanks for the help guys. While my body is in the air, Im going to run the 2 line sup the passenger side for the pump, then do the line on the driver side for the canister.
  #11
Old Feb 6th, 13, 1:37 PM
71350SS 71350SS is offline
On my 71 ElCamino,an L48 350 car,it has a 3/8 fuel line on the pass side and a vapor line on the drivers side that I think is a 3/8 vapor line but I have to check to be sure.My vapor cannister is long gone so I cannot help you there.
John
71 El Camino SS
406 SBC M21 3.31 12 bolt
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Fuel Line help 71'
Location
*REQUIRED*
Insurance
First Name
Human Verification
