Low end torque camshaft specs for stock 350 - Chevelle Tech
Auto Insurance
Old Jul 16th, 03, 6:05 PM
bilydean bilydean is offline
Dean
Post
What camshaft specs should I look for to gain max bottom end torque for a bone stock 350? This is for my 93 chevy truck that I tow a boat with. Any recommendations or experience would be appreciated. This is a flat tappet hydraulic engine.
thanks
Dean
Old Jul 16th, 03, 10:22 PM
Dragn70 Dragn70 is offline
Post
I have a 1990 with a 350 and have been wondering the same thing. After comparing 20 or more cams on Desktop Dyno (for what its worth), I have found that the stock cam is hard to beat with stock manafolds. I plan on adding a set of headers soon, should add a good bit of torque in the 2500 rpm range where I need it.
Marty
1980 Camaro Drag Car
1970 Malibu 2dr hardtop cruiser
Old Jul 16th, 03, 10:54 PM
Rich-L79 Rich-L79 is online now
Super Mod
Rich
Post
When I rebuilt my 400sb for my truck intended for towing the Chevelle, my machine shop recommended the Crower "Baja Beast". I can't recall the item number at the moment but I can look it up if you like. You might be able to find the specs on Crower's site, if not I have the cam card in the truck somewhere.
It is a nice low end torque cam since it is intended for off-road trucks. My engine has small valve heads, about 9:1 compression and pretty much stock everything but the HEI and the cam. It's got plenty of low end grunt.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jul 17th, 03, 11:27 AM
Dean
Post
Dragn70, what you are doing is what I have been doing. Plugging in various cam specs and even using the iterative testing portion. I was hoping someone on the board has been in a similiar situation and what cam worked out for them using stock manifolds, stock everything, but the cam.
Rich, I will see if I can find the specs and plug that in.
thanks
Dean
Old Jul 17th, 03, 1:24 PM
pdq67 pdq67 is offline
Guest
Paul
Post
A -929 is 195/202 at .050 duration so try to shoot for something at or below 210 duration at .050"! Imho. pdq67
PS., and the Performer cam at 204/214 seems to be a dandy here, but it is off older tech design...
  #6
Old Jul 17th, 03, 2:44 PM
Super Mod
Rich
Post
Try to avoid the Crower site! Man! I've never seen so many pop-ups in my life!
Anyway, I already did it for you. The Crower Baja Beast specs as:
Part #: 03015
RPM Range: 1000-4500
lobe center: 112
Duration: 283/286
Duration @ .050: 204/214
Lift: .422/.444
In my 400 is has a nice idle though needs a little extra idle speed from stock to keep it running in gear with an automatic. Tons of torque up to 4500 but then completely is out of breath but then so are my heads. Mine is also running stock intake and exhaust manifolds and Q-jet. It was built to be bullet-proof reliable and it has been for 16k miles.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #7
Old Jul 18th, 03, 12:54 AM
travis g travis g is offline
Post
Check out the comp cams 260H. My first cam swap ever was in a '69 chevy 1/2 ton with a '77 smog 350 that was bone stock. The stock cam went flat, so I stabbed in the 260H and the difference was night and day. Stock convertor, 3.08 gears...the only mods was an advance curve kit in the HEI and dual 2" exhaust from the factory 307 small outlet ram horns. The difference was unbelievable...it would smoke the tires super easy, and got 3mpg better gas mileage than the stocker.
  #8
Old Jul 18th, 03, 11:45 AM
Dean
Post
Travis, I was actually looking at the 260H comp cam as well. Thanks for sharing the experience. Sounds like what I am looking for.
Dean
  #9
Old Jul 18th, 03, 10:39 PM
Kevs68 Kevs68 is offline
Post
I also run the 260h cam in my truck and am happy with it. Good low end and throttle responce.
  #10
Old Jul 19th, 03, 12:43 AM
19Nova72 19Nova72 is offline
Send a message via AIM to 19Nova72
Post
I even have a smaller cam a XE256 in my Nova. Not exactly the right cam for a car but it makes well over 400' lbs. from 2,000 to 4,500. Would make a great cheap truck motor!
19Nova72
M.E. student
Creativity is a drug I cannot live without. Cecil B. DeMille (1881-1959)
  #11
Old Jul 20th, 03, 5:38 PM
Guest
Paul
Post
He, He!! Never thought about it BUT I would bet a dollar to a donut hole that Crowers Beast is the good old Performer cam from looking the spec's listed here over!! pdq67
  #12
Old Jul 20th, 03, 6:43 PM
Wolfplace Wolfplace is offline
Mike
Post
Yep,same old gee golly everyone has one / performer/ RV/ whatever that's been around forever
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
Chevelle Tech > Mechanical > Engine      Current Topic: Low end torque camshaft specs for stock 350
Location
*REQUIRED*
Insurance
First Name
Human Verification
