Holley 750 double pumper rich/floods at idle - Chevelle Tech
Auto Insurance
Old Sep 10th, 12, 4:52 PM
memo3189 memo3189 is offline
Default Holley 750 double pumper rich/floods at idle
I've got an older 750 on my 69 396. I'm having "loading up" problems at or near idle. It has vacuum secondaries, not running a choke. Running this past a few friends I've got many different ideas. One seemed most sensible. Because of my cam .544 dur is 230 with 109 lobe center. I have low vacuum (10"). He said the secondary spring is probably opening the secondaries near idle.
How do i check for this and is there a way to choose the right spring.
Or.... any other ideas? I have the floats lower than the sight glass now, checked the needle/seat for shut off, and it's spotless inside, no varnish or dirt.
Old Sep 10th, 12, 4:59 PM
1966_L78 1966_L78 is offline
Tony
Default Re: Holley 750 double pumper rich/floods at idle
Originally Posted by memo3189 View Post
I've got an older 750 on my 69 396. I'm having "loading up" problems at or near idle. It has vacuum secondaries, not running a choke. Running this past a few friends I've got many different ideas. One seemed most sensible. Because of my cam .544 dur is 230 with 109 lobe center. I have low vacuum (10"). He said the secondary spring is probably opening the secondaries near idle. How do i check for this and is there a way to choose the right spring.
First, you need to determine what carb you have.
A "Double Pumper" ONLY has mechanical secondaries, and NEVER has vacuum secondaries... A "Vacuum secondary" carb with the spring housing is not a "Double Pumper, and should only have an accelarator pump on the front (primary) side of the carb... Unless its been assembled from a hodge-podge of parts (not even sure it would work)...
The "secondary" spring should not matter at idle...
Could be the Power Valve, either blown or incorrect... Its been a while, but as a rule of thumb/baseline, the Power valve should be around half on what the vacuum is as idle... For 10" at idle, I install a 5.0 Power valve to start...
If you do have a true Double Pumper, then maybe you have too much pump shot coming in too soon... Double Pumpers can be finicky down low, as their really intention was for all out WOT, with little consideration for idling very much...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Old Sep 10th, 12, 5:18 PM
427L88 427L88 is offline
Gold Member
Gene
Yeah, check the power valve. The only way I know to do so it to "suck it" an see if it holds.
Not going to debate Tony's recommendation of a 050 powervalve, as it what Holley would tell you BUT you can run higher rated ones without them dumping fuel through the venturies if the whole carb is properly set up.
Use a 065 which is pretty much stock Holley. Likely its the one you'll find inside.
And I simply cannot imagine the engine pulling enough cfm at idle to move the secondary flaps at all unless something is amiss with the secondary vacuum system.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
Old Sep 10th, 12, 5:19 PM
lg1969 lg1969 is offline
Louis
Vacuum secondary spring has nothing to do with manifold vacuum. To much fuel pressure will cause the needle/seat to open, or the float itself is not sinking to bottom. Check the gasket between to throttle body and carb body if it's properly sealed.
A power valve is most likely rupture do to backfire. If you have not install a check valve in the throttle body.
Louis
69 Chevelle Malibu Sports Coupe Change to SS
11:1 TR406sbc/AFR227/Comp cam 280HFT/3500 RPM Stall conv./TH 350/12 bolt 410 Gears
Original owner
http://www.youtube.com/watch?v=wCG7lnacgGg
http://www.youtube.com/watch?v=4FbCKQlBv0E
Old Sep 10th, 12, 5:22 PM
Gold Member
Gene
Louis is right on the fuel pressure. I think Holleys can take 8-9 psi though.
Gene
  #6
Old Sep 10th, 12, 5:25 PM
Mike Mike is offline
& Moderator
If this has been played with ,the floats may have gotten switched and that doesn't work.
From Holley
Use of brass floats on the secondary side of Model 4160 Carburetors factory equipped with nitrophyl secondary floats such as part number 0-3310C for Example, may cause the float to contact the metering plate resulting on loss of fuel control and flooding.
Also ,as it was brought up ,if parts were swapped ,you may have a metering block on the secondaries where a metering plate should be.
  #7
Old Sep 10th, 12, 5:28 PM
Louis
Too much. should be 5-6 psi.
Louis
Original owner
  #8
Old Sep 10th, 12, 5:33 PM
Louis
From Holley
3310-1 yes on the metering block
3310-2 on up, no
3310-1 = 780cfm
3310-2 on up, 750cfm
Louis
Original owner
  #9
Old Sep 10th, 12, 6:47 PM
Ok went out and checked carb. It's a 3310-11. Holley says it is a 4160.
I took the vacuum cap off for the diaphram and it looks like an old accoridian. All wrinkles. The holley site shows this as "junk". Also it has a silver spring, Holley says to try a black spring.
Now... where is the power valve?? So I can see what size I have.
Ohhhh fuel pressure is 7psi, vacuum was 10" @ idle up to 11oo rpm.
On the Holley site it says this was the stock carb for a 375HP which I have.
  #10
Old Sep 10th, 12, 6:51 PM
rel3rd rel3rd is offline
Team Member
Bob
Power valve is in the metering block, which is the 5/8" or so block that is sandwiched between the main body of the carb, and the fuel bowl.
1971 Chevelle SS "439" Two tons of fun
Brodix 294s, ClaySmith HR cam, Weiand Stealth, QFT SS-830
Turbo 400, Freakshow 4000 stall, 4.10's, 275/60/15 drag radials
Best run: 11.31@117 (1.55 sixty ft.)
InCar~11.34@117: http://youtu.be/KCz7q06gj5M
Burning rubber: http://youtu.be/ZHMy7idIEjY
  #11
Old Sep 10th, 12, 8:44 PM
69 Malibu 69 Malibu is offline
Todd
Floats too high?
468, 781s, th400, 3.73s, Lunati 241/249 .625 hyd roller, Weiand Tunnel Ram, Twin 750 DPs, Freakshow 9.5" 4100 converter, 28x10 Goodyear slicks. 3440 lbs without me
Best ET 10.91
Best MPH 120.13
Best 60 1.47
Best 1/8 6.88 98.76 mph
http://tinyurl.com/60213IDLE
http://tinyurl.com/Drag-Run
http://tiny.cc/69pics
  #12
Old Sep 10th, 12, 9:13 PM
72sbc427 72sbc427 is offline
Were the idle mixture screws tuned by vacuum? If so, was it done with vac advance disconnected and the port on the carb plugged? A 540 cam really isn't huge for a 396 as I ran similar in a 350. You should be able to get tuned more around 12" between timing and carb. What is your initial timing set at? If this is while driving or taking off from a start have you tried using a smaller pump shot nozzel?
Wheres that money tree hiding and who forgot to water it?
  #13
Old Sep 10th, 12, 9:23 PM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
Holleys cant use more than 5-6?
Think my carter 172 puts out 8ish...no problems yet but dont want to ruin it.
This post is a duplicate of a post that you have posted in the last five minutes.
  #14
Old Sep 11th, 12, 9:24 AM
Where is the best place to get Holley parts? I live in Western New York.
Is there a kit with various springs, valves, jets available?
My initial adv is 12deg with limiters for total of 36, no vac adv.
  #15
Old Sep 11th, 12, 11:18 AM
Louis
Google it, And I do not think Holley made -11 in 69. -1 yes. -11 does not exist. It only goes up to -6
Louis
Original owner
Chevelle Tech > General Tech Area > Performance      Current Topic: Holley 750 double pumper rich/floods at idle
Human Verification
