468 combo help - Chevelle Tech
Auto Insurance
Old Sep 8th, 12, 10:57 PM
StevenS StevenS is offline
Steve
Default 468 combo help
Just picked up a 87 monte SS with a 468. I was out playing today and the motor lost oil pressure and I shut it right off. Put 4 qts of oil in it to overfill it and oil pressure is back. So the pick came off.
So since I need to pull the motor. I fiqure I should change the cam. Car runs ok but I feel it needs a little more power. What would you change?
468 with about 200 miles on it.
781 heads
10.1 compression
forged pistons
Comp cam FT 280H 280/280 520/520
1.7 roller rockers
850 holley
2.5 exhaust
headers look to be 2 inch a little big
2500 convertor in a 700r4
373 moser 12 bolt
64 Chevelle 496 underway
64 F100 Street Rod with BBC /Chevy trapped in a ford body
Old Sep 8th, 12, 11:33 PM
RATtyCamino RATtyCamino is offline
Bill
Default Re: 468 combo help
Have the heads pocket ported and big valves installed if not already. If you are good with staying flat tappet on the cam then upgrade to a lunati 60204.
Bill
1978 Malibu
406 w/AFR 195's, 9.9;1, Lunati 60103
TH400, 10" converter, 3.73's.
1.65 60', 7.55 @ 91.37 mph.
http://i1270.photobucket.com/albums/...u/DSCN0151.jpg
http://i1270.photobucket.com/albums/...DSCN0155-1.jpg
http://www.youtube.com/watch?v=RZOxc9ywxbI
Old Sep 10th, 12, 6:52 AM
Steve
That is the cam I was looking at. Heads had some port work done but it does retain the stock valve size.
Old Sep 10th, 12, 7:32 AM
dreis454 dreis454 is offline
Dan
Bill
Or if you really want to wake it up, stick a Comp xr288hr in it or a Lunati 20110712 (previously the 60212) or even a comparable Howards cam & lifter package @ a little over $500. Makes it not worth using an FT cam.
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Sep 10th, 12, 8:12 AM
Bill
Even Better!
1978 Malibu
  #6
Old Sep 10th, 12, 8:37 AM
69 Malibu 69 Malibu is offline
Team Member
Todd
Go roller! I'm glad I did, combo in my sig.
Dan, what's with the Lunati part # change?
468, 781s, th400, 3.73s, Lunati 241/249 .625 hyd roller, Weiand Tunnel Ram, Twin 750 DPs, Freakshow 9.5" 4100 converter, 28x10 Goodyear slicks. 3440 lbs without me. 100 shot n2o
Best ET 10.46
Best MPH 127
Best 60 1.47
Best 1/8 6.65 104
http://tinyurl.com/60213IDLE
http://tinyurl.com/Drag-Run
http://tiny.cc/69pics
  #7
Old Sep 10th, 12, 8:47 AM
Dan
IDK,Look on Lunatipower.com and it seems they changed all the Voodoo HRs maybe more,I didn't look.
TC#3095
  #8
Old Sep 10th, 12, 9:34 AM
72BBMonte 72BBMonte is offline
Jon
Consensus is to change the camsaft.
  #9
Old Sep 10th, 12, 10:13 AM
plain 69 plain 69 is offline
Leave the cam alone and put in the bigger valves you will probably pick up around 30 hp. I picked up from 13.45 to a 12.95 with that change with 049's and a 272 .515 lift camshaft several years ago. If you have a good flat tappet I would just run it. If you change it I would not chance another flat tappet. I would go with a roller more than likely. It all depends on what you want. I mean you can grab more power and go with a bigger cam, valves and maybe go with some 1 7/8" headers. That 280 cam probably sounds really good in there right now.
Original 138 car from Freemont. 67 SS Bench seat 4-speed car with 396, Original M-20 with factory 3.73 12 Bolt Posi.
"You can never go fast enough" James Taylor Two-Lane Blacktop
Member #3635
Tri-State Chevelle Member #F-10
Larry Grigsby
Chevelle Tech > General Tech Area > Performance      Current Topic: 468 combo help
Location
*REQUIRED*
Insurance
First Name
Human Verification
