Turbo 400 kickdown switch - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Aug 11th, 12, 3:40 PM
dc7432 dc7432 is offline
Dale
Default Turbo 400 kickdown switch
My transmission doesnt downshifting when I hit the gas. I tested the switch on the gas peddle and I have 12 volts on the terminal closest to the firewall. When I manually move the switch the other terminal goes from 0 volts to 12v then tested the feed at the transmission orange wire has 12 volts with the black (ground?) at 0 volts. When I start the car the switch at the pedel doesnt move, it stays at the last location. Should it "slide" up to the pedlal? Need a new kickdown switch? I bought the switch new last year and just installed so maybe its defective. I beleive the vacuum is only for upshifting that works fine. Car is a 71 chevelle with a 402, thanks in advance.
Old Aug 11th, 12, 7:15 PM
hmardown hmardown is offline
Team Member
carlo
Default Re: Turbo 400 kickdown switch
Dale
look at the pedal when your pushing down on it, it should be making contact with the switch. when you floor it should make contact & slide the switch to engage it. once your pedal slides the switch then it will send a signal to engage. there's not a lot of adjustment for the pedal to switch contact. what I did with mine is I slid a piece of 3/8 gas line over that barrel part of the switch. this made the contact area thicker for the pedal to move the switch. works like a charm. hope I explained it good enough.got too have passing gear hooked up unless you go with a quick silver floor shifter, which I just did. good luck. hmardown
72 Elky
MJ 467
Turbo 400
12 Bolt
3.42:1 Posi
Old Aug 11th, 12, 8:37 PM
Dale
Thanks Carol, so after i adjust drive one time the switch is "stuck" at the last position so it doesnt go back to the inital position. I will try the hose trick as well, thanks.
Old Aug 11th, 12, 11:46 PM
Schurkey Schurkey is online now
Gold Founding Member
For the '70 and newer switch, the switch has to be moved fully forward, then it self-adjusts the first time you put the pedal to the carpet. There is no need to put hose over the actuator peg.
http://www.chevelles.com/forums/showthread.php?t=301666
Especially post 16
SOMEDAY I'll stumble across a '68--'69 switch to see how they're different in terms of adjustment from the newer version.
Did you SEARCH BEFORE POSTING a new thread?
Did you post in the CORRECT FORUM?
Old Aug 12th, 12, 12:26 PM
Team Member
carlo
who's carol ? your welcome, Carlo
72 Elky
MJ 467
Turbo 400
12 Bolt
3.42:1 Posi
  #6
Old Aug 19th, 12, 7:22 PM
Dale
Thanks Carlo,
Havent fixed the problem yet, I bought a new switch at the pedal and read you can test the kickdown solenoid by putting 12v to the top terminal and grounding to the frame. Another post didnt recommend this. Has anyone tested the switch? I'm getting 12v on the top and 0 on the bottom. If its bad I assume I need to drop the pan? thanks.
  #7
Old Aug 21st, 12, 12:09 AM
Thanks Carlo,
Switch, or solenoid? Switch is at the gas pedal, solenoid is on the valve body, requires pan removal.
A photo of how you're doing this test would be nice.
  #8
Old Aug 22nd, 12, 10:00 PM
Dale
Im talking about the Solenoid on the tranny, looking on how to test. Thanks again
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Turbo 400 kickdown switch
Human Verification
