Thinning Rustoleum paint to spray w/ gun - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Aug 5th, 12, 2:03 AM
nikwho nikwho is offline
Nik
Default Thinning Rustoleum paint to spray w/ gun
I want to spray some inner fenders, inside of fenders and a radiator support with some gloss black Rustoleum. I have a DeVilbiss gun. I would rattle can it but I want to get more practice setting up and spraying with my gun. So, I am pretty sure it would need to be thinned. What should i thin it with, Acetone? Could anyone suggest a set amount to add to thin it, or is it by sight/feel? I dont want to over thin it. Also, When it is thinned, should I spray with a 1.3 tip? I also have a little touch up gun with a 1.0 tip. Thanks in advance for help, guys!
Nik C.
Old Aug 5th, 12, 9:09 AM
Raven1 Raven1 is offline
Scott
Default Re: Thinning Rustoleum paint to spray w/ gun
Why not use a paint better than Rustoleum? Go to your jobber and buy automotive paint.
Old Aug 5th, 12, 11:59 AM
HowardH HowardH is offline
Team Member
You need to use a primer gun with a 1.8 tip or larger.
The mix should be 50-50.
Urethane would be the better choice.
www.howardsbackyardautobody.com
Old Aug 5th, 12, 1:38 PM
Nik
OK, I guess i'm heading down the wrong path. I will pick up some urethane paint. Thanks guys!
Nik
Old Aug 5th, 12, 2:24 PM
69 Malibu 69 Malibu is offline
Todd
My buddy and I sprayed my Monte with Rustoleum satin black at a 70/30 mix with acetone. No science behind our % but turned out real good. This car was rust free and straight but a hideous faded goldish brown. Just needed a cheap color change, misssion accomplished.
Click image for larger version
468, 781s, th400, 3.73s, Lunati 241/249 .625 hyd roller, Weiand Tunnel Ram, Twin 750 DPs, Freakshow 9.5" 4100 converter, 28x10 Goodyear slicks. 3440 lbs without me
Best ET 10.91
Best MPH 120.13
Best 60 1.47
Best 1/8 6.88 98.76 mph
http://tinyurl.com/60213IDLE
http://tinyurl.com/Drag-Run
http://tiny.cc/69pics
  #6
Old Aug 6th, 12, 2:01 AM
CoolBlueGlow CoolBlueGlow is offline
Keith
Rustoleum is AWESOME... for grills.
O.K. I'm kidding. I once shot a set of early 60's Cadillac steel wheels with the Rustoleum gray gloss.
I noticed that the color happened to match the OEM Cadillac rim color very closely. So I said "what the heck"! This was back in the days before you could get the 60's colors easily matched. (Sheesh! You young guys don't know how good you have it these days...)
Anyway, I cut it with either PPG 870 or 885 reducer. I can't remember which, but I know it was one or the other of those two, because that's all I had. :-) It shot beautifully and looked really good and lasted perfectly fine on properly prepped steel rims.
Good reducer can make average paint shoot pretty nice, IME.
I wouldn't personally paint a car with it, but Rustoleum can also work well for certain underhood components. For example, their "high temperature black semi-gloss enamel" shoots as a fair match to GM OEM A6 compressor paint (which was enamel - NOT lacquer like so much of everything else under the hood of a 60's GM product.)
NOTE: Rustoleum now heavily pushes a product line that is water based. These days you have to really watch out when buying Rustoleum, because they stock the two products side by side in the stores and the packaging is deceptively similar. Lots of stores are no longer carrying the solvent / enamel stuff. Try the mom and pop stores, where they still know that good paint has to be poisonous. :-)
Just my 2C
Keith
  #7
Old Aug 6th, 12, 2:51 AM
chevygod chevygod is offline
Tom
Recommend using better materials if you can, but RO will work well "for now". I have used it several times on "just need to cover it up with something" projects. Also for underhood, under body painting.
Painted this Monte with RO satin black, paint job lasted 6 years. Painted my Elco at the same time same paint, lasted 8 years. I live in RIverside County in SoCal, lots of sunny hot days, so lasted OK for $50 invested. Would have liked to do a "real paint job", but not in dollar/time budget right now.
Thinned with acetone, about 1:1, sprayed with an old Craftsman gun.
Tom
"Just remember, your last car is always a station wagon." chaos10meter, on The H.A.M.B.
  #8
Old Aug 8th, 12, 10:19 AM
Keith
Hi Tom,
Yes, good point...wish every paint job could be BC/CC fourteen feet deep, but it is better to light a pile of Fords than curse the darkness.
p.s. What is it with you guys and these satin black Monte Carlos? :-) I've seen five or six painted this way.
Keith
  #9
Old Aug 8th, 12, 4:46 PM
Sarcasticshrub Sarcasticshrub is offline
Hal
Just painted a 94 Suburban with that stuff. 1:1 mix using a cheep Harbor Freight spray gun. Two coats and the old primer / baby blue is gone. Wheel wells painted as well. Total cost, including the gun, $80.
The kid next door challenged me to a water fight. Just waiting for the water to boil...
  #10
Old Aug 22nd, 12, 10:38 PM
Nik
Just sprayed my inner fenders, rad support, steering arms, hood hinges, bumper brackets and some other small parts that i had blasted with the satin enamel Rustoleum (Part number 7777) mixed 1:1 with acetone through a DeVilbiss gun with a 1.3 tip. I was set up with a 1.8 tip but after mixing, it was pretty thin. Swapped to the 1.3 and it shot very well. I'm very happy with the results for what it is. Picked up all of my parts from the blaster this morning, shot with epoxy and then the rustoleum. I can post a picture if anyone is interested. I bet that over the epoxy, it will last very well, not seeing day light and all.
Thanks for the advice, guys.
Nik C.
  #11
Old Aug 22nd, 12, 10:51 PM
VinceS427bb VinceS427bb is offline
Vince
my car was sprayed with RO outside on the lawn in southern arizona with a tankless air compressor and generic spray gun - back in 1984 ???
it is still holding on to the car for what it's worth...
i'm about ready to touch it up to make it all the same color again
68-Malibu 427/T400
F-1R HO-Intercooled
3.73 33-spline 12-bolt
http://i260.photobucket.com/albums/i...erinstall4.jpg
http://i260.photobucket.com/albums/i...-11-200715.jpg
  #12
Old Aug 22nd, 12, 11:11 PM
Jim Mac Jim Mac is offline
Send a message via AIM to Jim Mac
I think this shows how the hobby comes around. People like nice paint on the cars, but when it costs more to paint a car than what the car is worth people start getting back to the basics. I rattle canned the nova satin black just to make it all one color. when I get the quarter skin replaced, its getting a regular cheapie satin black paint. jim
Jim
68 el camino custom, daily driver 327 th 350
70 chevelle, SS clone 454 4 speed
71 el camino, SS clone (sold!)
71 nova 350 4 speed with 4.10 gears! Sold
71 camaro. (owned since 1978!) 6-71 blown small block!
67 el camino 307/th400-3.31 12bolt
  #13
Old Aug 22nd, 12, 11:55 PM
zeke67 zeke67 is offline
Interesting. I've rattle canned a lot of stuff. Amazing how good of a finish you can get on small parts. Especially with some of the bigger flowing tips. Other than getting enough volume and getting big drops as the spray can cools. The underside of my Chevelle was shot with True Value's XO-Rust back in about 1990. At that time TV's parent had their own paint factory and still had the rust inhibitors that RO took out of the paint. It was shot with a gun. I used it because I it was affordable (I was in college), I had the level of gear that could shoot it but not something better, and I could always match it out of rattle cans.
Since then we've had the guy doing $100 paint jobs with Tremcald, the Canadian version of RO, using the "roll and roll method." There was even a Car Craft article about the $99 paint job.
All that said, I've always felt the RO and other stuff was not "real paint" for a car. I've been spending time lately on the iBoats forum and a lot of these guys restoring old boats on a budget are using RO, Valspar or other hardware store paints. They thin it with acetone, mineral spirits, or maybe xylene, maybe a mix. Maybe they add hardener, maybe not. They mix colors by blending pints and quarts. Some shoot it with cheap HF guns, some "roll and tip" some "roll and roll". They get really amazing results. Not show car, but well beyond what you'd expect.
So I think there's merit in some of these techniques, especially for under hood, chassis, or other parts that are easy to over restore with typical automotive two stage paint.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
  #14
Old Aug 23rd, 12, 1:33 AM
Andy69 Andy69 is offline
or better yet order from Eastwood
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
  #15
Old Aug 23rd, 12, 8:43 AM
Aaron Aaron is offline
I dont know the whole deal of your car.
Why did you end up using Rustoleum?
Is you car a real budget car or a racer?
If you shot your car in a real nice paint for a show or real nice driver paint job, I dont know why you would use Rustoleum on your car.
67 chevelle
3485 lbs without driver before cage
383 SBC / TH 350 with 3400 stall / 4:10 gears
Best time on motor: 11.811
Best mph: 116.44 mph
Currently undergoing a metal work to remove all rust.
Goal is to have a 10.99 or faster run
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Thinning Rustoleum paint to spray w/ gun
Human Verification
