holley 3310-2 Vs 3310-4 - Chevelle Tech
Auto Insurance
Old Aug 3rd, 12, 11:42 AM
mkube396 mkube396 is offline
Matthew
Send a message via AIM to mkube396
Default holley 3310-2 Vs 3310-4
i just got a 3310-4 and i was testing it out and I cant get the secondary to open like my 3310-2 one thing i seen in my 3310-2 is a brass nipple in the primary side that looks to help with vacuum signal to the secondary diagram. The 3310-4 i have looks to be missing this "but there is s hole there".
is this something they eliminated in the new ver? or did it fall out?
Note i am using the short yellow spring
1981 Chevy monte carlo 396 BBC .060 over 10.25:1 voodoo 60203,
3:42 Posi GTA rims
Holley 750 3310
8.61 1/8 mile on street tires
http://i190.photobucket.com/albums/z...uff/monte1.jpg
Old Aug 3rd, 12, 1:15 PM
kettbo kettbo is offline
George
Default Re: holley 3310-2 Vs 3310-4
if the carb is used, perhaps someone has been in there
if new...who knows?
Call Holley Tech, they might know http://www.holley.com/
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
Old Aug 3rd, 12, 1:29 PM
64CDNSS 64CDNSS is offline
Mic
I have a 3310-3 and it does not have the brass nipple - just the hole.
Old Aug 3rd, 12, 1:44 PM
oman oman is offline
If I was a betting man I would think that there was a design change to shave a buck or two, or a nickel or a dime, off the cost per unit to manufacture. If the -4 is used versus new well that could be different. As mentioned anything could have happened if it is used. Generally however things are not getting designed to make things better these days so if it is new then I go with my original theory.
Old Aug 3rd, 12, 2:27 PM
540Hotrod 540Hotrod is offline
JIM
The nipple will speed up activation. Do you still have the ck ball in the diaphragm can? Positive there are no leaks in the can or mounting gasket to the main body?
JIM
'67 Vette-Pump gas 555"/Gforce 5 Spd/Dana 60 IRS-3.07's
3850LB
9.90@141.40
http://s318.photobucket.com/albums/m...rrent=Jim3.mp4
http://s318.photobucket.com/albums/m...rrent=Jim4.mp4
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
  #6
Old Aug 3rd, 12, 4:21 PM
Dave427 Dave427 is offline
Dave 383 now
The nipple does make the vacuum secondary more sensitive, like mentioned see if it still has the check ball in the vacuum secondary housing.
Dave
  #7
Old Aug 4th, 12, 12:29 AM
Matthew
First i just installed it every thing was fine flots and set. The idle on this carb so much nicer then my older 3310-2 so is the response.
any way i had the original VS Unit on with the black spring all most didint open mybe 1/8 installed the yellow got 1/4 opening
then i took my hole VS Unit off my 3310-2 with my quick change spring kit. still 1/4 opening.
Yes i have the check ball installed. and it is clean and there is a little relief cut under the check ball to let air bypass it.
all so used Carburetor Cleaner and compressed air to make shure there was no crap in any thing
3:42 Posi GTA rims
Holley 750 3310
  #8
Old Aug 4th, 12, 12:31 AM
lg1969 lg1969 is offline
Louis
Do your self a favor, Remove the check ball. In another post I read it was removed and the secondary responded better without any problem. It may bog, It may not.
Louis
69 Chevelle Malibu Sports Coupe Change to SS
11:1 TR406sbc/AFR227/Comp cam 280HFT/3500 RPM Stall conv./TH 350/12 bolt 410 Gears
Original owner
http://www.youtube.com/watch?v=wCG7lnacgGg
http://www.youtube.com/watch?v=4FbCKQlBv0E
  #9
Old Aug 4th, 12, 12:32 AM
Matthew
i this week end i am going to swap out the main body witch sucks becus my 3310-2's dont have the blow out protection.
3:42 Posi GTA rims
Holley 750 3310
  #10
Old Aug 4th, 12, 4:09 AM
Dave 383 now
Its the baseplate that has the power valve protection, its the brass piece with the ball bearing.
Dave
  #11
Old Aug 4th, 12, 8:27 AM
Matthew
Dave
cool i was looking this morning and i seen that so i am going to do that.
3:42 Posi GTA rims
Holley 750 3310
  #12
Old Aug 4th, 12, 11:01 AM
Matthew
Woot I switched the main body and every thing is working as it should! my idle is nice and constant, off idle is crisp, and WOT is opening up the secondaries full with no bog.
The main reason to use the newer carb was my throttle shaft was worn out on the 3310-2 and i got this carb cheep as he didn't need it for his 5.3L lsx
3:42 Posi GTA rims
Holley 750 3310
Chevelle Tech > General Tech Area > Performance      Current Topic: holley 3310-2 Vs 3310-4
Human Verification
