Tall Ball Joints - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Jun 9th, 12, 3:06 PM
hollingshedlr hollingshedlr is offline
Default Tall Ball Joints
I'm thinking about installing tall upper and lower ball joints, and my question is, by going with both upper and lower will i get bump steer the same as if I had tall spindle or is it best to go with just one are the other?
Old Jun 9th, 12, 3:47 PM
UMI Tech UMI Tech is online now
Ramey
Default
We are currently testing tall lower ball joints with the standard spindle. Look for published data soon.
Tall uppers add spindle height with no bumpsteer effect.
Ramey Womer
Product Development Engineer
UMI Performance, Inc.
ramey@umiperformance.com
(814)343-6315
Ramey Womer - UMI Performance, Inc.
814.343.6315
www.umiperformance.com
Join us on Facebook!
Old Jun 9th, 12, 4:33 PM
Rich-L79 Rich-L79 is online now
Super Mod
Rich
Default Re: Tall Ball Joints
Tall ball joints don't cause an increase in bump steer when using a short 69-72 a-body spindle. The problems with increased bump steer with tall spindles is inherent to the position of the tie rod connections to the tall spindles, not the height of the spindles themselves.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Jun 9th, 12, 7:16 PM
I was told by someone that if you use both upper and lower tall ball joints you would get the bump steer as if you had a tall spindle. Also I wondering weather I should
Old Jun 9th, 12, 7:49 PM
grin07 grin07 is offline
I have the SC&C stage2 plus with tall upper and lower ball joints on my 72, and it is one of the best modifications you could do to your car if you like to drive it hard. I have none of the problems I had with the old school tall spindles bump steer.
  #6
Old Jun 9th, 12, 8:04 PM
Rokker Rokker is offline
Remi
Default
2x
Bastard 65 project thread:
http://www.chevelles.com/forums/showthread.php?t=230714
  #7
Old Jun 10th, 12, 12:09 AM
pist0lpete pist0lpete is offline
Neal
The setup that is known to cause bump steer is the b-body spindle. Tall ball joints will actually improve on many things including the bump steer.
1967 Chevelle
LS1 swap is completed!
www.fquick.com/pist0lpete
12.70 at 108.95mph
  #8
Old Jun 10th, 12, 4:45 AM
Remi
One of the problems with the stock setupe is that the inner tie rod is located too high and the outer to low. When the suspension moves up and down that also move the wheels out and in according to eachother.
A taller lower balljoint makes the outer tierod sit higher than stock and therefore the arm between inner and outer tierod have less angle. This improves bumpsteer.
A taller ball joint in the top with a shorter uca imporves the static and dynamic camber curves drastically.
  #9
Old Jun 10th, 12, 9:47 PM
I hope this is not a stupid question. What is a UCA?
  #10
Old Jun 10th, 12, 9:52 PM
Pete 67 Pete 67 is offline
UCA = Upper Control Arm
  #11
Old Jun 10th, 12, 10:01 PM
I just realized it and knocked my self across the head.
  #12
Old Jun 10th, 12, 10:19 PM
Ramey
Default
Our goal with testing is to show numerical data with stock tie rod location then with tall upper and lower. Hopefully it helps and the data will tell the story.
And no problems asking questions or terminology stuff. That's why we're here.
Ramey Womer
(814)343-6315
814.343.6315
  #13
Old Jun 11th, 12, 2:24 AM
Cameano Cameano is offline
Gold Founding Member
Darren
Would lowering a car with tall spindles improve bump steer? I'd think so, since the chassis, along with the inner tie rods, will move down and more in line with the outers.
Darren
64 El Camino 468, 9", ST-10, 4wdb, eternal project.
69 Firebird 461" stroker, th400, 3.36's, 4wdb, Midnight Green - Sold
Beach Cam
TC #78 Gold, ACES #3130
You may not post new threads
You may not post replies
