383 mud racing build - Chevelle Tech
Auto Insurance
Old May 26th, 12, 2:09 AM
Gibson75 Gibson75 is offline
Ricky
Default 383 mud racing build
Hello everyone. I've found many Google searches have landed me on posts from this forum over the past year or so while researching an engine build that I've been toying with. I figured I'd sign up and throw the questions directly at those experts whose opinions and knowledge I've been reading over.
First off, the vehicle that this engine is going to be intended for is a 100% mud racer (mud bogger). Don't worry, I have a 1972 SS454 El Camino in the garage that should help me somewhat fit in with you muscle car guys. Anyway, it's a 1975 Chevy with 38.5'' tall Super Swamper Bogger tires, th350 transmission with 3,500 stall converter, np203 transfer case (currently ran in low lock), Dana 44 front differential and 14 bolt full floater rear differential with 4.11 gears. The truck is gutted completely. Estimated vehicle weight with driver is around 4,000lbs. Currently I am running the factory original 350 with a Summit camshaft with 214/224 @ .050'' duration and .465/.488'' of lift, an old Edelbrock Torker intake, Edelbrock 650 carburetor and full MSD ignition. I do OK most times and actually place when I'm lucky.
The classes that I run are dominated by some built small blocks and a few healthy big blocks. My initial plans were to build a 496, but after pricing everythng out I've ruled it much over my budget. Instead I've priced out building a 383 at around $6,000 before machining expenses. I'm pretty confident in the parts that I've chosen (listed below), but I'm drawing a complete blank when it comes to cam sizing, carburetor sizing, and some other small part decisions. That's what has lead me here for the past year and now has me posting.
My plan is to build a solid small block that will have an operating range from 3,500 to around 7,500RPM that will have plenty of torque to kick those Boggers up and keep them moving. If you don't know, the object in mud racing is to wing the engine up fast and keep it tached (keeping the tires spinning as fast as possible). I don't really know what kind of horsepower number will get me there, nor do I care much for building to a specific horsepower number.
First, I have a 4 bolt 350 010 block laying around that I plan to use as my foundation. To keep the engine within my budget I'll likely be doing some of the minor machining myself, such as freeze plug installing and piston ring gapping. Not only that, but I also enjoy doing that kind of thing. I will certainly and obviously having it sent out to be bored and clearanced.
My plan is to use the SCAT rotating assembly with all forged internals including 6'' I beam rods, -7cc domed pistons (advertising around 12.9:1 compression), and all of the other goodies that come in the SCAT kits. In addition to this I plan on studding the mains for just some added "help me sleep at night" mojo.
I'd like to make use of the AFR 210 Race Ready cylinder heads. I like their flow numbers a lot for what I'm intending on using them for. I know with that kind of compression that I may see more horsepower numbers with the larger 227cc heads, but I think I will see my torque numbers fall off which would be a big problem for such a heavy vehicle in the mud. The AFR 210's come with springs that would work well with any cam that should work well with the setup also.
I'd mostly be using an Edelbrock Victor Jr intake manifold with this combination as well. For some other goodies, I'm certainly going to be running aluminum roller rockers with stud girdles, an electric water pump (as if it matters much), and my existing MSD setup (6AL, Blaster 2, Pro Billet).
For the unknowns... the cam first of all. I definitely want a solid roller cam as this engine is only going to be flogged. However, I'm not sure if I'm going to need a small base circle cam or not. Is this something that is going to have to be one of those "check and see" deals? I know a lot of that also depends on how much lift I go with... so... how much lift do I go with? In other words, what cam would fit my needs? Would I be better suited to contact a cam manufacture and possibly have one ground specific to my needs versus getting an off the shelf camshaft? Would a cam manufacture or very credible engine builder be able to tell me based on my desired lift and bottom end components if I'll need a small base circle camshaft or not? I'm lost when it comes to this.
Now with the carburetor. The only reason my truck has the 650 Edelbrock on it is because I knew that I could buy one and slap it right on my engine, set the idle and go without hassle, and it's proven to be a good carburetor so far. I got schooled on the general in's and out's Holleys when I had a mild 350 and an old, needing-to-be-rebuilt-Holley in a S-10 Blazer years ago. However, I've never dealt with carburetors much. Would an 850cfm feed this engine? Larger? What about annular boosters vs. down leg? I know there's not going to be an easy, definite answer without experimentation, but what could be a good starting point? Also, I do have an old Holley 780 laying around that I could have rebuilt and attempt to use if it's enough to feed this monster.
I will take any additional tips, opinions or anything else that anyone is willing to take the time to give me with open arms. A full blown racing engine is new business to me. So, any help from those of you who have been through it before would be great.
Thanks a ton for reading this far.
Some pictures and video to give the thread some "cool" .
Old May 26th, 12, 2:39 AM
496blaze 496blaze is offline
Todd
Default Re: 383 mud racing build
Looks like a cool truck! You've come to the right place for advice.
If your thread doesn't get much traffic I suggest posting in the Performance section.
1970 Chevelle SS 396 (491 now) 4spd
1969 Nova 496 Turbo 400 Dana 60
Old May 26th, 12, 2:46 AM
Ricky
Hey, thanks! I skipped right over the Performance Forum. You're right. I should've posted there. I'm still learning the forum itself and its features. I'll see if I get some answers here.
1975 Chevy mud racer
2008 Kia Optima
Old May 26th, 12, 4:51 AM
bdr66 bdr66 is offline
If you want to get the most out of the engine, yes, I would call up someone and ask about either an off the shelf recommendation or custom grind. I just finished swapping in a solid roller into my 350 from Chris Straub the other day. While I haven't had a chance to flog on it yet, it's a totally different engine now and for the better. Before settling on him, I had talked to the guys at Lunati who were also very helpful.
Make sure the springs on the heads will work with the cam or you will run into valve float or just beat the crap out things. Pick up a good used 850 carb mechanical secondaries, downleg is fine, look it over and put it back to stock if anything has been changed then go from there. I've done that with two carbs now and it's saved me from spending 750 bucks if I had bought 2 brand new ones.
With what you have for an engine now, going to this new 383 will be a huge jump in power lol. Or you could always buy a big block done for under 6k http://www.vortecproperformance.com/...binations.html Good old big block torque will keep them tires spun up and cleaned out.
Old May 26th, 12, 10:19 AM
Scotch Scotch is offline
Scott
I also have a 383 with AFR 210s on an 010 block with a solid roller cam. I did the homework ahead of time and ended up at 550 hp and over 500 ft-lbs.
The Edelbrock Air Gap intake is what you want. It'll deliver more bottom end but doesn't lose anything to 6,500 rpm.
You don't need any more than a 650 carb. Honestly- a 650 will support what you're doing to 6,500 without a problem.
The cam you want is a Comp XR286R. It's a nice fit with the AFRs and is done by 6,500.
The springs AFR sends along with the heads are a bit much. Get the springs Comp recommends with the cam- they're a better match.
I wrote this article detailing my build. I also build a similar 355 at the same time. This recipe works well.
http://www.popularhotrodding.com/eng...d/viewall.html
See my Pro Touring '67 Chevelle Wagon at:
http://www.flickr.com/photos/1192966...7594110671642/
Winner- 2011 Car Craft "Real Street Eliminator" competition
  #6
Old May 26th, 12, 10:43 AM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
He wants to run it to 7500 rpm
Would think more cam more intake better?
220 AFR head would rock with some compression on this.
My guess is he will be in the 600hp+- range
$$ wise in BBC territory
This post is a duplicate of a post that you have posted in the last five minutes.
  #7
Old May 26th, 12, 4:08 PM
Ricky
That is certainly a good build there. However, it's much milder than I'm looking to do. Your compression figure is 9.7:1 while I'm planning on pushing up close to 13:1. Additionally your build is geared towards running low test pump fuels while I'm planning on running VP110 or higher. It just seems that the cam, intake and carburetor that you have recommended would do well feeding the 9.7:1 of your build but would starve out 13:1 at 7,500RPM.
With this build fuel type is no limit of mine (other than I cannot run alcohol per class rules) and street manners... well, what are those? This engine will know two throttle points : idle and wide open.
Again, I am not talking down about your build at all whatsoever. It's quite an impression machine. It just seems that it may be a bit limiting for what I plan on doing.
2008 Kia Optima
  #8
Old May 27th, 12, 11:13 AM
Scott
Ok cool..then go with 220s and a Victor, and turn the wick up. You'll want better rockers up there- I like shaft mounts for over 7000. A 750 will do fine... Cam wise, I'd have to do some homework.
  #9
Old May 27th, 12, 2:26 PM
Todd
One thing to.consider. If your going into race gas compression territory, make it worh your while and bring the compression up higher than 13:1.
Chevelle Tech > Mechanical > Engine      Current Topic: 383 mud racing build
Location
*REQUIRED*
Insurance
First Name
Human Verification
