Pros & Cons of converting GM 8.2 10 bolt to posi - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old May 25th, 12, 11:24 AM
AZ Light Speed AZ Light Speed is offline
David
Question Pros & Cons of converting GM 8.2 10 bolt to posi
I have a GM 8.2 10 bolt 3.08. I see that there are posi carriers available for around $500 to $600. The ring & pinion have been replaced sometime in the past and look good. I recently replaced the spider gears. The axles and bearings look fine. This differential has been in my '65 El Camino for many years so I know it fits. Should I convert this to a posi or look for a GM 12 bolt. I have read here in the forums that 12 bolts are a rare find these days and aftermarkets units are pricey. I am planning a total suspension upgrade with UMI's Stage III package or some thing like it. Thanks in advance for the input.
David
David
1965 El Camino 327, M22
2000 GMC Sierra 5.3L,
But when you get right down to it,
no matter what you try
You deal the cards, give the wheel a spin
(Alan Parsons Project)
Old May 25th, 12, 11:58 AM
big gear head big gear head is offline
Freddie
Default Re: Pros & Cons of converting GM 8.2 10 bolt to posi
How much power are you making and how much traction do you have? If you are not making enough power with enough traction to break the 8.2 then go ahead and upgrade it. No need to spend the money on a 12 bolt if you don't need it, and if you like the 3.08 the just put in a good posi and be happy with it. You can get a good posi for less than the price you listed. What kind of driving do you plan to do with this car?
forcd ind forcd ind is offline
why do you want a posi? a 12 bolt is stronger, but all depends on the usage of the car, power
when your credit cards are maxed, have the limits raised
Old May 25th, 12, 12:16 PM
David
I have a 327 with 2.02 / 194 70's era heads, holley street dominator manifold with 600 holley carb and headers. with a muncie M22. Been gear slamming for years with no issues, but not really drag racing, just playing my fellow motorists and turning heads. I am interested in doing some autocross and highway cruising.
Edit: also a late '70 - early '80 Crane fireball cam, with .465 lift & 270 deg. duration
David
Last edited by AZ Light Speed; May 25th, 12 at 12:30 PM. Reason: Adding information
Old May 25th, 12, 12:56 PM
Freddie
For auto cross use I recommend the Truetrac. I don't know if that is availabel for the 8.2, but I'll check. You might be limited to a clutch type differential. If that's the case I recommend the Eaton Posi or Dura Grip. Stay away from the Auburn.
  #6
Old May 25th, 12, 1:01 PM
Freddie
No Truetrac, just the Eaton Posi or Dura Grip.
  #7
Old May 25th, 12, 3:16 PM
Chevy67 Chevy67 is offline
Kevin
I upgraded my 3.08 10 bolt to a 3.73 with and Eaton Posi. For all around use it works great. If I was drag racing with a manual trans I would go with a 9" or some type of aftermarket 12 bolt.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
Ermine White/Red 1967 Chevelle Malibu
Forged Mike Lewis 383 rotating assembly
AFR Eliminator 195's
Lunati Voodoo 60122 roller cam
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Jake's Performance 200-4R
  #8
Old May 25th, 12, 3:56 PM
chuckd71 chuckd71 is offline
Stu
I put an eaton in mine, not too many miles on it yet but other than the fact it isn't free I can't see a down side to it.
L92 / 200-4r 71 http://www.ls1tech.com/forums/conver...s1-begins.html
  #9
Old May 25th, 12, 5:26 PM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
I've got an 8.2 in my Chevelle
With an m20 Muncie I've gone low 12's with drag radials.
Car makes 376rwhp (about 440fwhp).
It's got about 15k+ miles with zero issues.
Richmond 355 gears, auburn posi, stock axles,
Aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
  #10
Old May 25th, 12, 9:46 PM
Brian Mc Brian Mc is offline
Brian
I'd just throw the posi in it and roll....should be fine.
  #11
Old May 25th, 12, 11:23 PM
shomejim shomejim is offline
jim
Look at Tomsdifferentials.com, he has auburn posis for 375. He also has eatons but you have to call for price. That is what I'd do. Then drive that puppy. !2 bolts for the '65's are harder to find and generally more expensive than the later models because thry're an inch narrower. I have a '65 malibu and I'm putting a 12 bolt in it , but I'm making a little more hp with my big block, so I figured I'd beef up the rear. You should be fine if you don't start making too much more power. Good luck!
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Pros & Cons of converting GM 8.2 10 bolt to posi
Human Verification
