Gear Ratios? - Chevelle Tech
Auto Insurance
Old May 17th, 12, 11:09 PM
red72 red72 is offline
Andrew
Default Gear Ratios?
So I'm looking for suggestions on a new gear ratio.
Here's the back ground: I have a 72 El Camino with a mostly stock (for now) 355, th350, 2500 stall converter, 27" tires, and 2.73 gears (open). It's way over due for having the gears upgraded, but before I have it done I want to get some feed back/input.
It's not going to be a race car, but I may take it down the track a couple of times. It's mostly a daily driver/joy rider. I would like to have good performance off the like but not be running 4000 rpms going down the free way.
I was thinking of going with 3.73s but I'm not positive. I'm new to the "re-gearing" thing. Not sure what's going to be my best bet. That's why I'm looking for feed back.
Thanks!
Old May 17th, 12, 11:54 PM
chuckd71 chuckd71 is online now
Stu
Default Re: Gear Ratios?
I would not run 3.73 without and OD trans (which I why I got one). Maybe 3.31:1, that seems like the sweet spot for a non OD setup. But I'm not an expert by any means.
L92 / 200-4r 71 http://www.ls1tech.com/forums/conver...s1-begins.html
Old May 18th, 12, 12:10 AM
Camaro_fever68 Camaro_fever68 is offline
Ray
3:55's are a great all around gear.
Ray
Old May 18th, 12, 12:16 AM
Andrew
3.31? that would be too convenient. There's a local guy selling a complete diff. with 3.31s right now.
http://boise.craigslist.org/pts/2973266594.html
Does anyone have experience with a similar setup?
Old May 18th, 12, 12:42 AM
ricks68chevelle ricks68chevelle is offline
Rick
Chuckd is right on!
  #6
Old May 18th, 12, 2:31 AM
66360horse 66360horse is offline
andy
I vote for 3.42s
  #7
Old May 18th, 12, 5:48 AM
71454Chevelle 71454Chevelle is online now
Darren
Send a message via ICQ to 71454Chevelle
10 bolt or 12 bolt?
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
  #8
Old May 18th, 12, 6:08 AM
novaderrik novaderrik is offline
Derrick
i didn't mind the 3.70 gears in my Nova- it got to be a little much at 80mph on the interstate, but otherwise i didn't mind it..
mild small blocks seem to like ratios in the 3.42-3.55 range, too..
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #9
Old May 18th, 12, 6:39 AM
Yellomalibu Yellomalibu is offline
Dave
For a street car without OD, 3.73's would be the most gear I would want to run, but if you do a lot of highway driving, even 3.73's are a bit much.
You'll feel a performance improvement with anything steeper than the 2.73's you've got.
How much in town driving versus how much highway driving you do should weigh into your decision... 3.31's (or 3.36's if a ten bolt) will run about 400 rpm lower on the highway than 3.73's.
Which rear end do you have? You may have to buy a new carrier, too.
_____________________________________
68 Chevelle
flat top 406, AFR 195's, XR286R, RPM AirGap
750 Holley DP,TH400 w/brake, 4000 stall FTI
4.30 gear, 12 bolt
... for now.
  #10
Old May 18th, 12, 7:23 AM
Lionel-n-Chevelles Lionel-n-Chevelles is online now
Gold Founding Member
Without an Overdrive Transmission, 3.42 gears is the line in the sand I would not cross.
Tory
ACES Member #1890
Team Chevelle Gold #288
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396 Unrestored 76,000 Mile Survivor
1968 Malibu L-79, 1 of 4082 - SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds w/ Factory Sunroof, 1 of 99
1985 442 White / Grey w/ Factory Sunroof - SOLD
  #11
Old May 18th, 12, 7:47 AM
Andrew
It's a 12 bolt. Sorry, I forgot to mention that.
My drive to work is about half highway, half in town.
So, the 12 bolt posi with 3.31s in the craigslist link I posted above might be a good way to go then? Not much experience buying rears, does that look like a good deal? Worth the $800 he's asking.
  #12
Old May 18th, 12, 8:36 AM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
Winner!
I have gone 112mph with my 355 with 355 gears at the track.
Drive great too
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
  #13
Old May 18th, 12, 8:54 AM
Harold Sutton Harold Sutton is offline
I've had about everything that G.M built and like 3.31s the best. My 396/350 Chevelle got 18-19 mpg with that gear.
  #14
Old May 18th, 12, 9:35 AM
jeff swisher jeff swisher is offline
jeff
What no math for the boy.
336 is a given to make the math work out..but allow for converter slippage..I usually add in 10% for a sloppy converter..
336 X gear ratio X MPH, divided by tire diameter = RPM
Here is some more TH350 gear ratois 2.52 in first and 1.52 in second
1.52 X 2.73 = 4.14,, so if you drive around in second it would be like having 4.14 ratio.....
I like my 3.25's 9" ford though...the 2.75 was a tad tall and i have 29" tall tires 3.73 or 3.70 was a good all around gear but you will cruise in the fast lane at 3500 rpm at around 75mph or 2500rpm at 55 mph.
I will agree with Harold with the 3.31 being an excellent choice
Sometimes it is nice to have a complete rearend to swap out..We had a spare that had different ratio for the 64 elcamino..and about 45 minutes and you were rolling. that was a 60 dollar salvage yard part..we had 2.56's and 3.08's. With 3.08's we usually only used 1st and second in the 1/4 mile.
  #15
Old May 18th, 12, 12:07 PM
Twins Fan Twins Fan is offline
Brad
Looks like it might be too good of a deal?? A rear like that would fetch quite a bit more money than $800.
I question how legit the stuff/ad is when he says the second rear listed came out of a 70 Chevelle with a 454/TH400 combo and had a open 2.73 rear end.
There were A body BOP 12 bolt rears that had 12 bolts on the cover, but were more like 10 bolts internally. If that's a real deal Chevy 12 bolt for $800, it's a great deal. Do a bunch more "checking out" of that one before handing any cash over.
Chevelle Tech > General Tech Area > Performance      Current Topic: Gear Ratios?
Human Verification
