Chrome vs Molly Rings.. Which are Better and Why? - Chevelle Tech
Auto Insurance
Old Nov 20th, 04, 9:23 AM
garfield garfield is offline
Post
Between using Chrome and Molly Piston rings in a 350 small block 4-bolt main bored out.040 with Fuelly Cast Iron Heads, which would make the better ring and why? Please Note that motor is in a street machine that will see very little if any time at the track!
Fords....Ha! Only little girls dream of Ponies. REAL men wear Bowties
Old Nov 20th, 04, 10:20 AM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Post
Chrome rings are alot of money and are used mostly in industrial engines that are in dirty conditions and there will wear a cylinders faster as chrome rings are so hard there seems to be more wear with them and require a corse finish.
Moly rings are less money and the moly finish on the rings help lubricate the cylinders and you can use a fine finish sush as a 280 grit.
Old Nov 20th, 04, 11:55 AM
Pat Kelley Pat Kelley is offline
Post
Some dirt track racers like chrome.
Pat Kelley
66 El Camino, daily driver
Sold 67 El Camino, Bracket car (7.33, 93.60, 1.61 60', 1/8) (1.53 60', 7.26 660', 11.50, 115.08, 1/4 mile) 355 powered
Pat's Page (Dynamic CR Calculator, car specs)
Shop equip for sale
Old Nov 20th, 04, 7:35 PM
Schurkey Schurkey is offline
Gold Founding Member
Post
Chrome tolerates dust bettter. Note that the cylinder walls aren't chrome, so they still wear plenty fast when exposed to dust.
Moly is what you want unless you plan to leave the air filter in the garage when you drive the car.
Did you SEARCH BEFORE POSTING a new thread?
Did you post in the CORRECT FORUM?
Old Nov 20th, 04, 8:06 PM
pdq67 pdq67 is offline
Guest
Paul
Post
If not mistaken, chrome rings require "round" cylinders b/c if the cylinders aren't round, they take forever to seat b/c the chrome is so hard that it takes a long time to wear the chrome coating down so the rings fit and seal properly.
I don't think it is a good idea to use chrome rings for a "dingle-berry" hone, "shade-tree" overhaul b/c the cylinders are usually worn unevenly so aren't really round to allow chrome rings to seat quickly unless you bore her oversize and change pistons.. Then the cylinders will be round again...
pdq67
  #6
Old Nov 21st, 04, 3:46 AM
Post
Oh Boy.... Well guys, the engine is already finished "with Chrome rings installed". [img]redface.gif[/img]
Oh well, Come next summer I'll run her around a little bit to see how she holds up. If the Chrome rings prove to be a no-go, back to the machine shop she goes
  #7
Old Nov 21st, 04, 5:54 PM
Randy Mosier Randy Mosier is offline
Post
Moly or cast iron. Chrome is rarely used in a street engine. Be aware that the cylinder requires a different finish for Moly and cast iron rings. The hone stones used for moly rings are finer grit.
A man with an experience will never be at the mercy of a man with an argument.
Chevelle Tech > Mechanical > Engine      Current Topic: Chrome vs Molly Rings.. Which are Better and Why?
Human Verification
