Hard pedal with engine off; soft after starting - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Mar 25th, 12, 12:41 PM
larrygk larrygk is offline
Larry
Default Hard pedal with engine off; soft after starting
Hey guys before I dive into the obvious vacuum test wanted to get any suggestions on this.
Situation: With engine off, the pedal is very firm with little travel. Once engine is turned on pedal goes down dramatically and of course triggers the Brake Warning light on the dash.
What was done previous to resto: the completely stock power brake system was not touched while taking the car apart. Nothing was taken apart except of course removing the vacuum line from the booster and plugging up the hole to protect it while painting, etc. Brakes were bled and new shoes in rear were installed. Front pads were fine.
I will check the vacuum line which is new and appears to be fine, but if it is any hint the engine runs perfectly which of course supplies vacuum to other places (e.g. distributor).
Larry
San Diego, CA
1969 SS396
All Numbers Matching
L35 TH400 3.07
Factory Air, am/fm Stereo, PS, PB Disc/Drums
Factory SS Package
Dover White, Black Interior, Bench Seat
Restored to show condition-SOLD
Old Mar 25th, 12, 1:04 PM
65 Skylark 65 Skylark is offline
Bill
Default Re: Hard pedal with engine off; soft after starting
That's pretty much they way they're supposed to work with the exception of the pedal going down that far. Sounds like you still have air in the lines and need to bleed them again.
Bill
_____________________________________________
'65 Buick Skylark,
355 sbc, 10.2 comp, Trick Flow 195 heads, RPM Air gap, Holley 3310, Bullet 224/230 .483/.485, Hedmans, 200-4R, 10" 2,800, 4.10 12 bolt.....and factory a/c
http://s1085.photobucket.com/albums/...t=Buick007.jpg
Old Mar 25th, 12, 2:10 PM
pnugene pnugene is offline
Team Member
Randy
I agree you have air in the lines, but you may also have a bad vacuum check valve on the booster or possibly a ruptured booster diaphragm.
Randy
TC # 5401
67 Project SS Clone
Son, that there pedal on the right, that's
the loud pedal. You stand on that, and
the Rat's gonna Roar.
Old Mar 25th, 12, 2:16 PM
Larry
Thanks Bill and Randy. Will go for the bleed first and hopefully the other 2 components are fine.
One of the most baffling things in a resto, for me anyway,is with certain components and assemblies that worked great before the project, and you did not have to touch them during the resto, all of the sudden, they don't work fine.
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
Old Mar 25th, 12, 2:27 PM
Gary56 Gary56 is offline
Gary
First time you have anything work fine the last time you used it, next time not? You've been lucky if so. I don't believe anything on the vac part of the system will trigger your brake light to come on. Got to be a hydraulic issue, air in the line, big external leak, or leaking cup inside the master cylinder. jmo
  #6
Old Mar 25th, 12, 2:32 PM
Larry
Gary- Thanks. You may have been clear on this but if not, the brake warning light only comes on when I press the pedal while engine running, in Park. Yeah I agree it most likely is air in the lines. I guess that months of non-use can do that.
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
  #7
Old Mar 25th, 12, 10:48 PM
Gary
You were clear, maybe I was not. There are two only things that I know of that will trigger the dash light. The switch on the emergency brake pedal, and the proportioning valve located below your master cylinder. The proportioning valve has a spool, for lack of a better term, in it with a ground post between the flanges of the spool. If there's a pressure difference between the front and rear brake lines, the spool moves one way or the other, completes the circuit to ground, and the dash light comes on. That pressure difference can originate in the master cylinder itself or anywhere down the lines. No connection to the vacuum booster at all. I suspect it's just to hard for you to overcome the springs in the booster and master cylinder to activate the switch in the proportioning valve with the engine off (no vacuum assist). BTW, did you adjust the brake shoes when you changed them? If the fronts are properly adjusted or disc, and the rears are not anywhere near tight enough, that will probably do it. jmo
  #8
Old Mar 26th, 12, 11:44 AM
Larry
Thanks Gary. Appreciate the detail. As far as the brake shoes, I will recheck the new ones we installed as well as adjustment. All these brake related items were "done" when I first got the car to get it road-worthy but that was about a year ago so no surprise that things are not the same. Also thanks for the reminder on the E-brake activation of the light. I tested that the other day and no light so I will check the switch/connection.
Larry
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
  #9
Old Mar 26th, 12, 2:07 PM
JWagner JWagner is offline
Gold Member
What Gary said about adjusting the rear bake shoes. Double check that.
  #10
Old Mar 26th, 12, 2:12 PM
Larry
Thanks. Been a while since I adjusted shoes. When you turn the tire by hand how much resistance is about right? Right now they turn with shoe scraping noise for sure but it is not difficult to turn them.
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
  #11
Old Mar 26th, 12, 3:21 PM
Gary
I usually adjust them untill I can't turn the wheel, then back them off a couple of clicks. One way to sort of test for adjustment is to pump the brake pedal. If it gets higher and firmer with every pump, that's probably it. If the pedal starts out high, and slowly sinks to the floor, that indicates a leak which can be inside the master cylinder or external down the line. A low spongy pedal indicates air in the system. No biggie. You'll get it figured out.
  #12
Old Mar 26th, 12, 4:52 PM
Larry
Yeah it needs to be bled. I adjusted the shoes and in fact they needed it! Brand new, but loose. Started her up and pedal is better but still triggers light. It does not sink to the floor but goes about 2/3's down and stops firmly. So bleeding is next. My gut says it is not the booster or MC but that is the guess for now based on when I got the car.
Also I did order a new booster vacuum check valve to be sure. I thought a check valve only lets (in this case) air in one way, thus the term "check". I blew through the existing one both ways and it freely lets air in both ways.
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
  #13
Old Mar 26th, 12, 9:38 PM
Team Member
Randy
This explains the hard pedal when engine isn't running. The check valve should hold vacuum in the booster for a couple presses on the brake before the pedal becomes firm. Sounds like you're getting there, bleed your brakes and replace the check valve, and see how it works out.
Randy
TC # 5401
67 Project SS Clone
  #14
Old Mar 27th, 12, 11:53 PM
Larry
Yup. Bled first, new check valve. The car will now stop. Although bleeding did not expose any real "bubbles before clear fluid" scenario. Just kind of did it's thing. The culprit was the check valve. But go figure,,,,light never came on and pedal was not that soft before when I bought the car and drove it for a week before tearing it down. And it had the same bad check valve. The mysteries of life.....
Thanks guys for the assistance.
Larry
San Diego, CA
1969 SS396
L35 TH400 3.07
Factory SS Package
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: Hard pedal with engine off; soft after starting
Location
*REQUIRED*
Insurance
First Name
Human Verification
