turbo 400 wont stop leaking - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Mar 8th, 12, 11:23 PM
jm209modesto jm209modesto is offline
josh
Default turbo 400 wont stop leaking
hi i recently put a turbo 400 in my 67 chevelle bb with nitrous. i had it built at a local tranny shop, it keeps leaking i checked the pan gasket not coming from there i look up looks like its coming from the lines so i take the old metal tubing lines off replaced them with braided lines with AN fittings still leaking. i wrapped the lines with a rab where they screw into the tranny its dry so its coming from somewhere else. i cant stand this leak any suggestions on where it can be coming from an what to try. ps its leaking on the passenger side only. im running b&m trick shift fluid. thanks
Old Mar 8th, 12, 11:38 PM
jonh jonh is offline
Default Re: turbo 400 wont stop leaking
How about the fill tube O'ring.
Jon
Old Mar 8th, 12, 11:50 PM
bln bln is online now
Dave
you wont want to hear this but if its coming out from near the fittings the case is cracked , someone either tightened them too much and cracked the casing rite around where the fittings go in. when you pull the fittings out it will be hard to see maybe its on the top of the fitting area ...... dont ask me how I know
My Chevelle convertible My65
67
Old Mar 8th, 12, 11:51 PM
pnugene pnugene is offline
Team Member
Randy
Jon
car isn't running.
The o-ring is a common leak source. I once had a difficult to locate leak that turned out to be a poorly welded support tab on the dipstick tube. The fluid leaked through a pinhole in the tube where the tab was attached to it. It didn't leak when the engine was running, the fluid level rises up the tube when not running.
Randy
TC # 5401
67 Project SS Clone
Son, that there pedal on the right, that's
the loud pedal. You stand on that, and
the Rat's gonna Roar.
Old Mar 8th, 12, 11:55 PM
josh
completely dry around the fittings pulled the dipstick out put a new seal also rite stuffed it to be on the safe side. im thinking coming out of the vent tube. shop i had build it gave me a 1 year waranty thinking about pulling it out tomorrow an taking it back to them see what they say.
  #6
Old Mar 9th, 12, 12:03 AM
Team Member
Randy
If you suspect the vent tube, try pushing a length of rubber hose over the vent and route it to a different area. Wipe the tranny dry with a rag, and drive it awhile to see if the leak exits the rubber hose at its' new location. If it is leaking out the vent, and the tranny isn't overfilled, it's time to revisit the builder.
Randy
TC # 5401
67 Project SS Clone
  #7
Old Mar 9th, 12, 12:11 AM
josh
thanks ima try that tomorrow before i pull it.....
  #8
Old Mar 9th, 12, 9:29 AM
Dan Orgill Dan Orgill is online now
Team Member
Dan
As stated above, I'd be thinking dipstick tube. The rubber o-ring from the factory is just useless, IMHO. I went with a Hughes dipstick tube, which has a tophat design rubber seal, absolutely no leaks.
Dan
  #9
Old Mar 9th, 12, 4:05 PM
bracketchev1221 bracketchev1221 is offline
Take a rubber hose and attach it to the vent. Tie a soda can under the trans mount and route the hose to the can. See if the can fills. I chased everything in my car until I did this. Mine comes out of the vent. I never noticed it with the trans blanket, but with the shield the car was a mess.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
  #10
Old Mar 9th, 12, 5:48 PM
forcd ind forcd ind is offline
could it be the pan-if a stock pan, just like stamped valve covers, it can get bent with to much torq on the bolts, bends it in, then you have to knock it flat
spray some brake cleaner and clean it off, then you have to watch for the leak
you just have to look hard
when your credit cards are maxed, have the limits raised
  #11
Old Mar 9th, 12, 6:35 PM
Jim Mac Jim Mac is offline
Send a message via AIM to Jim Mac
I had this issue with my nova. Turned out it was the o ring, must have cut it when installing it. I fixed it for good during the summer. I put a M-21 muncie in place of it. jim
Jim
68 el camino custom, daily driver 327 th 350
70 chevelle, SS clone 454 4 speed
71 el camino, SS clone (sold!)
71 nova 350 4 speed with 4.10 gears! Sold
71 camaro. (owned since 1978!) 6-71 blown small block!
67 el camino 307/th400-3.31 12bolt
  #12
Old Mar 9th, 12, 7:43 PM
davis95 davis95 is online now
Doug Davis
Could be the governor cover.
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
  #13
Old Mar 9th, 12, 9:28 PM
The Deejay The Deejay is offline
Rick
If the vent has been become pinched during installation, or something else is clogging the vent, it will spew out the fill tube..........ask me how i know.................
  #14
Old Mar 10th, 12, 6:35 AM
von von is offline
Lifetime Founding Member
Von
Could be shift shift seal or speedo cable drive connector too. Speedo cable drive has both inner and outer seals.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: turbo 400 wont stop leaking
Human Verification
