[non chevelle] Pontiac electrical problem - Chevelle Tech
Auto Insurance
Bench Racing Stories, cruising and more.
Old Feb 16th, 12, 9:28 PM
Racing Racing is offline
Dan
Default [non chevelle] Pontiac electrical problem
99 Pontiac Bonneville:
The other night the dash instrument lights went out. Pulled and check the under dash fuses as well firewall fuses. They all looked good.
One thing I did notice is that if I turn the dome lights on with the light switch the instrument lights do come on. I haven't noticed anything else not working.
Light switch or am I overlooking something else or something obvious? What says the Chevelle Forum?
Dan
Dan's 70 Chevelle
Spencer's 72 Chevelle
Old Feb 16th, 12, 11:58 PM
Sid Coleman Sid Coleman is offline
Gold Founding Member
Sid
Default Re: [non chevelle] Pontiac electrical problem
I used to own a 93 Bonnie-my GUESS would be the light switch/dimmer assy. But if you want a possible better answer, check out this forum: http://www.bonnevilleforum.com . Used to be only a Bonnie board (like this one) but has been combined into a "all GM" board. But still has the bonnie tech info archived. Good luck!
"Until we, as citizens, become proud of the job our government is doing, no elected official should serve more than one term." TC (Gold) #174
Old Feb 17th, 12, 7:29 AM
Dan
Thanks Sid. I'll check out the gm forum.
Dan
Dan's 70 Chevelle
Old Feb 18th, 12, 12:42 AM
Sid
If I recall correctly, and it's been a few years since I owned it, to remove the light switch you have to use a paperclip or thin screwdriver blade to push a tab in that's under the knob, then pull the knob off the shaft. Then unscrew the bezel around the bottom of the shaft. Good luck.
Old Feb 18th, 12, 3:16 PM
Dan
Thanks Sid, This wife is gone with the car this weekend. The new switch will be here Tuesday.
Dan
Dan's 70 Chevelle
Chevelle Tech > Information Exchange > Bench Racing      Current Topic: [non chevelle] Pontiac electrical problem
Location
*REQUIRED*
Insurance
First Name
Human Verification
