VortecPro Dyno Results and Initial Track Results - Chevelle Tech
Auto Insurance
Old Feb 12th, 12, 5:40 PM
JOHN WILSON JOHN WILSON is offline
Clueless TnTr
Send a message via AIM to JOHN WILSON
Default VortecPro Dyno Results and Initial Track Results
I had Mark build me one of his pump-gas GM oval-port 496 combo's.
Specs:
4.31x4.25 496bbc
Mahle pistons 10.8:1
Scat crank/rods
Milodon 31188 oil pan
Solid roller .731/.715 268/278@50 108lsa
GM 781 ovals 2.25x1.88
Victor Jr 454-O
Holley Aluminum Ultra-HP 950 carb
It took a couple passes to get a handle on the suspension. Seems as though the extra weight up front doesn't help keep the nose down.
1.297
3.823
6.007@112.1
7.92
9.560@136.79
The above pass was with 32° advance (37° made best numbers on dyno) and the car felt a little lean at the end of the track. So.......feeling better about the suspension settings and also running out of time, I decided to bring the timing up to 35° and threw some jet at the carb. I also tightened the front shock extension another 2 clicks hoping to counter the extra power. It wasn't enough as the car started to climb hard and I pedaled again. So as it stands, the motor is running 9.56 in "detuned" shape. I'm looking forward to playing with it over the next few months as I give the engine the timing and fuel it wants and figuring out the suspension settings to deal with the extra power. In all honesty, I see no reason it won't run a 9.3X once I get it all lined out.
Not too damn shabby for a lil ole pump-gas 496 combo using factory block and heads.
Big thanks to Mark for a solid/powerful build.
Track pic of VortecPro'd RedBull.
Also, thanks to Jake Stelter and Jason Gore for all the help yesterday and keeping my scatter-brain'd a$$ straight!!!
VortecPro Pumg Gas 496
9.29@142.29
With a SBC
440-18°
9.020@147.36 1.271-60'
http://www.youtube.com/watch?v=-ymUH1B1guQ
http://www.dragtimes.com/Chevrolet-C...slip-5661.html
http://www.superchevy.com/features/c...ibu/index.html
Old Feb 12th, 12, 5:48 PM
Vintage Musclecar Vintage Musclecar is online now
Eric
Default Re: VortecPro Dyno Results and Initial Track Results
Excellent results.
How does the Milodon pan fit regarding the inner tie rods?
Carburetor Rebuild & Restoration
www.vintagemusclecarparts.com
Old Feb 12th, 12, 5:50 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
Thanks again John for the hospitality, had a great time. The car looks great and performs awesome, can't wait til you get that 9.3x.
Old Feb 12th, 12, 5:57 PM
JLerum JLerum is offline
Awesome picture! That's what we need this time of year seeing the front end way high. Warm weather will be here soon guys! Nice job Mark as it sounds like another killer power plant!!
Jim
1970 Chevelle LS-6
Pure Stock Drag Racing
12.21 at 115.32mph on G70-14 Goodyear Polyglas
PSMCDR 2009
Old Feb 12th, 12, 5:58 PM
Doug F. Doug F. is offline
Geez, nice!
Did you weigh it with the BB?
Doug
1972 Nova
6.0L LSx, 80mm BorgWarner, 4L80E
9.71@140
  #6
Old Feb 12th, 12, 6:01 PM
Mikeys69 Mikeys69 is offline
/\/\ikey
Send a message via MSN to Mikeys69
There goes the neighbor hood. lol
1969 Chevelle Malibu 406 SB
Dart SHP Block, Scat 4340 Crank/Rods, Iskey Solid Lifters, Comp Cams 288TLS @ .050” 259in 266ex / Lift .550in .570ex 106º, Patriot 190 Heads, Harlan Sharp Roller Rockers, Performer RPM Air Gap Intake, Holley 750 DP, MSD HEI/CDI, 3000 Hughes, Eaton/Richmand 3.73's, M/T SR's.http://www.chevelles.com/forums/showthread.php?t=386745
  #7
Old Feb 12th, 12, 6:03 PM
73nova 73nova is offline
Tim
Originally Posted by Doug F. View Post
Geez, nice!
Originally Posted by JOHN WILSON View Post
3615-3630.
Its on the Team clueless track day run down.
  #8
Harold Sutton Harold Sutton is offline
What happened to the bad small block? I understand the weight gain now and the car slowing from previous outings. Did you just get the urge to drive it once in a while? A set of AFR 290 heads would take some weight off, (at least 70 lbs.), and maybe gain 40-50 h.p. too if Mark would go over them first. What rear end gear did you run the other day?
  #9
Old Feb 12th, 12, 6:07 PM
VORTECPRO VORTECPRO is offline
MARK
Its been great working with you! Thanks.
Click image for larger version
  #10
Old Feb 12th, 12, 6:11 PM
ShawnT ShawnT is offline
Shawn
Badass piece you built him Mark
John, keep me updated!!
85 swb c10
496
10.5:1 Brodix RR-O
Jake Performance TH400
6.89 @ 96.96
Never fry bacon naked!!
  #11
Old Feb 12th, 12, 6:18 PM
MARK
Thanks Shawn, but it takes a killer car to make an engine work, oviously John knows how to get it done.
  #12
Old Feb 12th, 12, 6:29 PM
Stokerboats Stokerboats is offline
Dan
The bar just keeps on climbing. AND with Iron Ovals. That's funny stuff there.
  #13
Old Feb 12th, 12, 6:52 PM
40Coupe 40Coupe is offline
Real nice running, sounding, leaving and good looking car.
Congrats to John and to Mark!
1.27 -1900' DA
  #14
Old Feb 12th, 12, 6:53 PM
mino65 mino65 is offline
Team Member
mark
Wow!!!Hows the pan working as far as fit?Mark installed a canton pan on mine and i had an issue with the centerlink but worked it out.also still workin out the dipstick tube issue as canton puts it on the driver side and there is no room.really don,t know why but they did.congrats on the new motor!
1965 malibu,03 silverado ss
best of 11.59
60' 1.55
114.mph
461,th350,4.10 3600lbs.
28x9 etdrags
New best of 10.38 MJ 496
60'1.42,128.17
replaced the 4.10s with 3.73
  #15
crazydavey crazydavey is online now
Davey
wow, John I didn't know you did that....that's one badass motor...congrats to you and Mark on another outstanding build!! You get some runs on it and it's gonna be wicked....what are you running for tires, radials?
Chevelle
http://www.firstgenmc.com/photopost/...t_woodburn.jpg
The pass...
http://www.youtube.com/watch?v=TM501gwoXsA
Monte Carlo
http://www.firstgenmc.com/photopost/.../scan00023.jpg
'67 Chevelle 509..mine
3.89's
9.44 best mph 141.30
5.97 best mph 114.44
1.316 60'
3535 lbs
Scott Foxwell 509
Straub HYD roller
'72 Monte Carlo 454
1 of 1268...hers
11.66/117 in drive
4100 lbs
crazydaveyracing.com
Davey
You may not post new threads
You may not post replies
