How to remove chrome strips along roofline - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Feb 11th, 12, 1:49 PM
1966-aztec-bronze 1966-aztec-bronze is offline
Hunter
Arrow How to remove chrome strips along roofline
How would you remove this chrome along the roofline?
Click image for larger version
ID:	49820   Click image for larger version
I have learned to use the word "impossible" with the greatest caution - Wernher von Braun
1966 Chevelle ss396
Old Feb 11th, 12, 1:57 PM
DUTCH MAX HEADWORK DUTCH MAX HEADWORK is offline
Al
Default Re: How to remove chrome strips along roofline
The drip rail is easy.
Take off the small on first where the 2 pieces meet. I've been able to do it with my fingers, careful not to get cut. Put your fingers under it and roll it UP until it snaps loose. Then roll the others the same way up. Gripping from the underside and rolling up or forward for the front piece. Start at the front for the top rail working the piece off to the rear gradually to avoid bending.
Not sure on the other trim piece. Never done one of those. Can look it up if no one responds. I'm guessing some sort clip arrangement on welded studs or screws through the back with nuts.
Old Feb 11th, 12, 2:15 PM
modchevelle modchevelle is offline
Steve "Dirty"
Some of those pieces are glued on so heat it up with a blow dryer or a heat gun. The heat gun from a distance.
Old Feb 11th, 12, 3:01 PM
Jerry Briggs Jerry Briggs is offline
Jerry
the lower piece of molding around the sail panel is held on with studs/clips work it loose carefully. the upper piece is as stated by Al.
Jerry Briggs
ROLL TIDE!
70-Elky
67-SS 396-Original-Owner
Project-67-Elky
Old Feb 11th, 12, 4:47 PM
jeffschevelle jeffschevelle is offline
Jeff
None of it is glued on a 66 ...
The rear V-shaped part of the vinyl top moldings have 3 nuts on each side that you can get to from inside the trunk. Remove those and pull the studs out of the holes, then you can pull that piece loose from the striaght piece on the side of the car. Then the straight piece has clips that hold it on. If you are very careful you can pop it off the clips, or better yet use a soft wood block and tap the rear end to slide the piece forward until it lets go of the clips.
The drip rail mldgs can be removed as suggested above, although it is darn hard to do with your hands. I always remove the roof-rail weatherstrip and its retainer first, then you can work from the inside of the car and use a wood block to tap the bottom edge of the mldg outward. Start at the front and go only until you get about half way between the back of the door glass and the curved part of the molding. Then start again at the bottom rear end and work your way up to near the curve. Then work a little from both sides of the cuve, going back and forth, until it pops off last at the curve.
If you try to go all the way from the front to the back, or all the way from the back to the front, you will bend the mldg at the curved area. The curve needs to pop loose last.
Good luck!
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (Survivor Z16 Picture album)
-65 Z16 drag car, unrestored (Red/Red)
-65 SS Convertible (Red)
-65 300 2-dr Wagon, Modified (Tuxedo Black)
-66 SS L78 Coupe (Marina Blue), unrestored
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (Survivor 66 Picture Album)
-66 SS Convertible (Marina Blue)- "LOADED"
-67 SS L78 Survivor Coupe (Grenada Gold)
-67 SS L34/M21 Survivor Coupe (Tahoe Turquoise)
-67 SS L34/M20 Convertible (Bolero Red)
-67 ElCamino L35/M20 (Butternut Yellow)
-67 Concours Station Wagon (Mountain Green)
-67 Camaro SS350 Survivor (Grenada Gold)- 'Vintage Legend' Certified by the American Camaro Association
  #6
Old Feb 11th, 12, 4:50 PM
Hunter
Thumbs up Re: How to remove chrome strips along roofline
Thanks for the info! My dad and I and working on it now!
1966 Chevelle ss396
  #7
Old Feb 11th, 12, 4:54 PM
Dean Dean is offline
I've never tried it myself but I've heard several people say that they used an old time beer bottle opener wrapped in electrical tape to gently pry off the molding.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
  #8
Old Feb 11th, 12, 5:19 PM
Raven1 Raven1 is offline
Scott
You can, but I've seen people ruin it with one too. I prefer to use a block of wood as mentioned. Block's larger face to distribute force will not leave a pry mark like a church key.
  #9
Old Feb 11th, 12, 5:43 PM
Steve "Dirty"
I was just giving heads up. I know on my 68 that is what it is. i dont know what a 66 is but I hate to see parts get ruined.
  #10
Old Feb 11th, 12, 8:59 PM
wjspindler wjspindler is offline
Wayne
I have always been told that a bottle opener used slowly will help in removing the drip rail molding good luck. wayne
  #11
Old Feb 11th, 12, 9:39 PM
65 Skylark 65 Skylark is offline
Bill
Never, ever use a can or bottle opener on them unless you have a new set to install after you've ruined them. They dent very easily so, as already mentioned, use your fingers. Getting started is the hard part but once you do it'll come off fairly easy. Patience is the key when it comes to drip rail moldings.
Bill
_____________________________________________
'65 Buick Skylark,
355 sbc, 10.2 comp, Trick Flow 195 heads, RPM Air gap, Holley 3310, Bullet 224/230 .483/.485, Hedmans, 200-4R, 10" 2,800, 4.10 12 bolt.....and factory a/c
http://s1085.photobucket.com/albums/...t=Buick007.jpg
  #12
Old Feb 11th, 12, 9:49 PM
66138 66138 is offline
Elroy
I just took the 66 to the bodyshop today with the same question. I had started the drip mldg off with my hands but it was tough. He took about a 2 " flat spoon and tapped the bottom side out easily
  #13
Old Feb 12th, 12, 7:13 PM
Hunter
Good luck!
Thanks! We decided to attempt it next weekend. We took out most of the interior and badging on the car this weekend!
1966 Chevelle ss396
  #14
Old Mar 17th, 12, 7:07 PM
Hunter
We haven't got to the trim yet (we've been taking of bumpers etc.).
Looking through the opgi catalog we found this trim removal tool.
Has anybody used it?
http://www.opgi.com/p/body-moldings-...5/CVT0039.html
Thanks!
1966 Chevelle ss396
  #15
Old Mar 17th, 12, 8:03 PM
cheveslakr cheveslakr is online now
jerry
Thanks!
That molding removal tool is designed for windshield/rear window stainless removal not driprail molding. It can assist you with the driprail but you gotta be real careful. I use mine to run it along the small curled edge on the bottom of the molding and just give it a little pressure to open up the crimp being careful not to pry. Keep in mind the early cars used aluminum for the driprail while 68-72 used stainless.
Jerry
Chevelle Tech > General Tech Area > Body Shop      Current Topic: How to remove chrome strips along roofline
Location
*REQUIRED*
Insurance
First Name
Human Verification
