Bench testing an old 6-volt generator...how to? - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Feb 3rd, 12, 11:54 AM
highlandlake highlandlake is offline
Team Member
Tom #3613
Default Bench testing an old 6-volt generator...how to?
Hi everyone reading this,
I'm working on a '51 Flathead 6-cylinder engine. The generator is a 6-volt type and has not been run for many years. In it's original condition, I bench tested it as-is. My method was to hook up a voltmeter to the output and ground terminals. Then I took a 20-foot long piece of twine and wrapped it around the belt pulley. I pulled it as hard and fast as I could. The meter read 0.5 volts.
So spent a couple of hours disasembling the unit and gave a very thorough cleaning. I replaced the armature bushings with new ones. Used 0000 steel wool on all the inner contact surfaces and gave them a shine like new. Vacuumed and blew out all the dust and wool debris. Cleaned and polished all the terminals.
It looked great, shined like new inside.
After putting it back together I did the twine trick again and got the same result....0.5 volts at the highest speed I could spin it. Turning it slowly by hand will get about 0.15 volts.
So, what am I doing wrong? Should the generator be spinning at 1000 rpm or more to get a 6-7 volt output?
Any advice or suggestions to test the output when it is on a bench?
Thanks,
Tom
Gone but not forgotten...
1968 Malibu 402/400
1965 6-cyl Cameo Beige Malibu SS -
Current projects - '57 Chevy & '51 pickup
Old Feb 3rd, 12, 7:17 PM
Robinls5 Robinls5 is offline
Bob
Default Re: Bench testing an old 6-volt generator...how to?
How I use to do it is , Hook up two 6 Vt. leads to the gen. If it is working it will run BACKWARDS like a 6 Vt. D.C. motor. My Dad showed me this in 1956.
Bob
70 SS 454 El Camino 07 AACA Grand National Winner-MCACN-GOLD-2013
70 SS 454 Station Wagon - Driver
Old Feb 5th, 12, 7:37 PM
Team Member
Tom #3613
Still wondering how to check the output voltage when the unit isn't on a running vehicle.
(Bob, thanks for the reply about how to check if it will turn, not quite ready to do something like that, but haven't ruled it out if I have nothing else to try )
1968 Malibu 402/400
Old Feb 5th, 12, 7:49 PM
JWagner JWagner is offline
Gold Member
The output voltage for something made in 1951 would be controlled by the voltage regulator. I cannot remember if you need to ground the F(ield) terminal or hook it to the A(armature) terminal for doing you test. Either way , you cannot hurt anything. If you can, find an old old Motors Auto Repair manual that would have info on these generators.
edit: you could PM a TCer named Stellar, as he works in the automotive generator, starter and alternator biz and I think he is a pretty helpful guy.
rbwjr325 rbwjr325 is offline
Rich
we always took fan belt off and closed points in reg,if gen ran it was good
  #6
Old Feb 5th, 12, 7:53 PM
Dean Dean is offline
Moderator
Ground the Field and connect the Armature to battery.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
  #7
Old Feb 5th, 12, 9:32 PM
Team Member
Tom #3613
Thanks all, this gives me a direction to go.
(and I'll PM Stellar too for anything else he can point out)
Tom
1968 Malibu 402/400
Tags
hi everyone
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: Bench testing an old 6-volt generator...how to?
Location
*REQUIRED*
Insurance
First Name
Human Verification
