anyone used bed liner under car on floorboards - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Jan 11th, 12, 9:28 PM
crush67 crush67 is offline
Chad
Default anyone used bed liner under car on floorboards
i have trany, rear end and gas tank out.thinking about epoxy then bed liner.what are your thoughts? unmask frame &por 13 semi black frame.
Old Jan 11th, 12, 9:47 PM
Bryan59EC Bryan59EC is offline
Bryan
Default Re: anyone used bed liner under car on floorboards
I had the bottom of the car Rhinolined along with the interior floors.
That Rhinolining, and some dynamat, and the interior if the car is dead quiet at cruise on the freeway.
After replacing the floors in the 66, painted them black and sprayed some rubberized undercoating underneith and in the interior.
I mostly did it for sound insulation than anything else.
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
65 Ranchero v8/4-spd, that my uncle bought new
Old Jan 11th, 12, 9:53 PM
fleming23 fleming23 is offline
Eric
The only concern I see is on resale. There is a higher likelihood people will question what is hidden underneath the bed liner coating.
70 Chevelle
496 cu. in. "cruiser"
Assembled & Tuned by Mo's Speed Shop Dallas, GA
Old Jan 11th, 12, 10:15 PM
Aaron Aaron is offline
Eric has hit on a good topic.
I used it on my chevelle, but it aint for sale and its mainly a race car.....I used a bedliner product I got from my local jobber.
67 chevelle
3485 lbs without driver before cage
383 SBC / TH 350 with 3400 stall / 4:10 gears
Best time on motor: 11.811
Best mph: 116.44 mph
Currently undergoing a metal work to remove all rust.
Goal is to have a 10.99 or faster run
Old Jan 11th, 12, 10:37 PM
Chad
good thoughts i have been documenting with pics.do you think that would curb resale concern? I sure would like sound proofing&look.but not at a reasale hit.thanks!this web site rocks!
  #6
Old Jan 12th, 12, 7:03 AM
Andy69 Andy69 is offline
The Fat Stig
I'm planning on using Herculiner or possibly a two part although for my purposes I think the one part will be fine.
Resale is not a concern, at all.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
SuperAndy's Garage
Automotive Archaeology
  #7
Old Jan 12th, 12, 8:08 AM
427stingray 427stingray is offline
steve
I can't see why people would question it. I did mine and it just looks like rough paint. It's not thick looking like you are trying to hide something.
67 GTO more Chevelle than Pontiac.
http://s254.photobucket.com/albums/hh89/67geeto/
  #8
Old Jan 12th, 12, 8:20 AM
lrdvdr41 lrdvdr41 is offline
Anakin
My dad and brother both use it on their Jeep Wranglers. Great stuff in a jeep!!
  #9
Old Jan 12th, 12, 10:15 AM
Beaux Beaux is offline
If anything I would use lizard skin, sand smooth and top coat. Then you actually do have something that looks like the factory finish that possible buyers shouldnt question or factory correct guys wouldnt look at with disdain knowing they would have to remove it all and repaint.
Bedliner / insulator / chip guard styp stuff anywhere but in the rear wheel wells and or above the gas tank is going to have people wondering. And the grain material tends to grab and hold dirt / dust.....well, it always did on the bedlined / lineX'd trucks I owned. I'd use lizard skin or I would just paint it and focus my deadening / insulation on the interior side.
  #10
Old Jan 13th, 12, 1:25 AM
Musclerodz Musclerodz is offline
mike
Alot of builders are using Raptor liner from Upol. It is not thick at all, looks like very heavy orange peel, and hard as nails so easy to clean and tintable.
  #11
Old Jan 13th, 12, 1:53 AM
chuckd71 chuckd71 is offline
Stu
If resale is a concern then there isn't much point in changing anything on these cars as you never get out what you put in. I put POR on the inside of my car and once it warms up I'm going to throw some of the raptor stuff on the bottom and in the wheel wells. Not putting anything on the frame though because once I get out of school I'll probably galvanize and powder coat it.
L92 / 200-4r 71 http://www.ls1tech.com/forums/conver...s1-begins.html
  #12
Old Jan 13th, 12, 11:20 PM
Rapid Rapid is offline
I used gator guard spary on bedliner. It is a two part epoxy that once curred it is unaffected by oils. That is the main reason I went with it. I will have to say spraying it is a messy job and it gets everywhere!! I don't care about resale and our car is not stock or an SS so I was not concered with that. Haveing the body off of the frame and covering everything up as a precaution payed off.
I said it's a messy job.
I had to lay on the plastic and shoot upwards. It dripped down plus the spray would deflect. My wife was holding a large peice of cardboard against the car to help stop the overspray.
I did primer and use chassis black paint before I sprayed the bedliner. It needs a clean surfice to attach to.
  #13
Old Jan 14th, 12, 11:25 AM
The Fat Stig
I think I'll use the brush on stuff. That looks messy!
SuperAndy's Garage
  #14
Old Jan 16th, 12, 11:30 PM
bconwayls1 bconwayls1 is offline
Brian
I used a brush to apply Herculiner to the entire bottom. Should outlast my kids, considering it wont see wet pavement unless necessary.
Sent from my Motorola Smartphone on the Now Network from Sprint!
71SS/L48-1 owner
92 305cid
92 700R4
12 bolt/3.31
http://s222.photobucket.com/albums/d...Chevelle%20SS/
Made in the USA - Twice
  #15
Old Jan 16th, 12, 11:41 PM
Bigjay Bigjay is offline
Jay
I just used chassis paint, I didn't want to spray upside down so I used foam brush's. It looks awesome. Its a lot stronger than regular paint, doing the same thing on the inside of the car.
Jay
Chevelle Tech > General Tech Area > Body Shop      Current Topic: anyone used bed liner under car on floorboards
Location
*REQUIRED*
Insurance
First Name
Human Verification
