th 400 converter feed restriction - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Jan 9th, 12, 5:36 PM
putput putput is offline
mike
Default th 400 converter feed restriction
Ok so I am getting ready to rebuild the Th400 I took out in my car. It held up well for a long time behind old motor but only lasted a hundred miles behind the new one, granted had many years on it. I had a b@m shift kit, clutch kit and 34 element sprag, but nnothing fancy. Now I am glad it only lasted a short time in new engine because the old motor had extreme thrust wear, which appears to be common 400 problem.
I am planning on hardened input shaft and going to a trans brake valve body, but am concerned about thrust wear. I have done a lot of research and found lots of varying opinions on what to do. Is there a good guide line to follow for restiction size wihthout being able to put the tranny on a dyno to measure pressures??? I would prefer not to have to put together, get line pressure measured and pull apart again etc... Does anybody sell a pump that is already modified for this???? Engine in sig, and plan to put some N2o on it, no more than a 250-300 shot.
68 camaro
496ci 644tq 730hp and a lot of the street
shake down pass, 10.76 @128.52
fun>>
Old Jan 10th, 12, 5:38 AM
77 cruiser 77 cruiser is online now
Jim
Default Re: th 400 converter feed restriction
You can look at this.
http://www.turbobuick.com/forums/tra...striction.html
Jim
77 Monte
385- AFR 190's Clay Smith solid--200-4r w/ 3.73's
67 Imp.SS for the wife 275 hp 327-TH350
http://myweb.midco.net/77cruiser/
Old Jan 10th, 12, 8:11 AM
mike
Thanks Jim,
I had found Turbo Buick a long time ago but couldnt remember the name.
68 camaro
fun>>
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: th 400 converter feed restriction
Location
*REQUIRED*
Insurance
First Name
Human Verification
