rochester quadrajet to the 2101 performer intake issue - Chevelle Tech
Auto Insurance
Old Dec 21st, 11, 10:16 AM
1972 El Camino 1972 El Camino is offline
Mark
Default rochester quadrajet to the 2101 performer intake issue
hey guys,
need help in finding the correct gasket solution for my Rochester Quadrajet to have no vacuum leaks using the edelbrock 2101.
i had a mechanic install the carb and manifold and i have a huge leak at the carb base. (Spraying carb cleaner at the base gasket changes the idle) so im taking matters into my own hands and looking for the correct gasket.
When i got the carb from Shaun murphy he sent me a gasket but the mechanic said there was a huge vacuum leak. the mechanic then got another one but it still has a leak.
anyone have experience or advice the correct gasket/solution?
i found this one - http://www.summitracing.com/parts/MRG-56A/
do i need an adapter or something to make this work using the two together?
i appreciate the help,
Mark
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
1470-080 Dish Top Pistons
Stock Converter
Th350 Trans
Stock Exhaust Manifolds/AIR System/Dual Exhaust
Old Dec 21st, 11, 10:44 AM
ss3964spd ss3964spd is offline
Team Member
Dan
Send a message via Yahoo to ss3964spd
Default Re: rochester quadrajet to the 2101 performer intake issue
Mark,
It'll probablyt be faster to just call Edelbrock and ask their tech line which carb base plate gasket to use for the 2101 and QJ combination.
Dan
Awww, fer cyrin out loud, it's that IMPALA guy again.
If I recall correctly my memory is excellent. My ability to access it is not.
SS 396 4sp
Old Dec 21st, 11, 10:52 AM
bracketchev1221 bracketchev1221 is offline
The 2101 is a q-jet intake. Try one for like a 86 Caprice. That one used a 1/4" insulator gasket. I have never had an issue with a q-jet on those manifolds unless he is overtorquing it and destroying the gasket.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
Old Dec 21st, 11, 11:17 AM
496blaze 496blaze is online now
Todd
Just went through this myself.. I would check your initail timing to make sure it has enough to idle properly. In my case, I would spray around the carb base and get a false reaction since it would suck in at the throttle shafts and make the engine happy (thinking I had a vacuum leak) for second since it was idliing with O* timing at idle. Fixed the initial timing and I was able to tune the carb properly.
2 thumbs up for Sean Murphy btw! He builds a killer Q-Jet carb.
1970 Chevelle SS 396 (491 now) 4spd
1969 Nova 496 Turbo 400 Dana 60. Under construction
Old Dec 21st, 11, 11:21 AM
Mark
Originally Posted by 496blaze View Post
Just went through this myself.. I would check your initail timing to make sure it has enough to idle properly. I would spray around the carb base and get a false reaction since it would suck in at the throttle shafts and make the engine happy for second since it was idliing with O* timing at idle. Fixed the initial timing and I was able to tune the carb properly.
you know whats funny? is the car idles with the idle screw all the way out?!? the screw is an 1/8 of an inch from touching where it should to adjust the idle.... and the car idles?!?
when i got the car back from the shop he had the dwell set at 14. i set it to 30, he had the timing mark 3 inches advanced past the timing plate!!!!, i moved it to 6 degrees advanced.
who knows how much he played with the fuel air mixture screws as well... heh
another thing is that the car has since getting the manifold and carb installed making too much of an air sucking sound through or around the carb. i thought it was because now im using an open air element but it doesn't make sense its as loud as it is unless again, im clueless.
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
  #6
Old Dec 21st, 11, 11:26 AM
Todd
Do you know what the base idle timing is set at? Are you running a PCV valve?
  #7
Old Dec 21st, 11, 11:30 AM
Mark
you mean the rpm? its at or around 650rpm.(it doesn't seem like its idling to high or too low.)
yes a pcv valve that has the hoses for the air system hooked up going to the canister and carb port.
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
  #8
Old Dec 21st, 11, 11:40 AM
Team Member
Dan
Guys,
Much of this is discussed in Marks other thread.
Mark, from what you described on your other thread you've got a vacume leak at the carb to manifold gasket. You need to focus on that before you start fussing/discussing the timing again.
SS 396 4sp
  #9
Old Dec 21st, 11, 11:45 AM
Mark
i agree. my main reason for the thread is trying to figure out if i need a special gasket and or adapters etc.
i hesitated in calling edelbrock because its been through two gaskets already, the one Shaun gave me even after i told him i would be using it with a 2101 and the second one the mechanic got.
When i first spoke with the mechanic about it he said the gasket i provided had a leak. He then ordered one and the one that showed up was identical to the one i provided so then, apparently, he went down to the part house to try and find one that would work, that is the one that is in the car now.
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
  #10
Old Dec 21st, 11, 11:54 AM
Team Member
Dan
Mark,
Give me a ring and I'll explain it. 703-675-3410.
Dan
SS 396 4sp
  #11
Old Dec 21st, 11, 11:57 AM
Todd
No, what is the timing set at in degrees at idle? If you have way too much idle timing on a mild engine it will cause it to idle very high as you describe.
All the connections from the PCV are controlled vacuum leaks and will cause the idle to raise. I would try temporarliy plugging them off and see if you can get the idle to come down to where it can be adjusted by the screw after confirming your idle timing is in the 10-14 degree or so range.
  #12
Old Dec 21st, 11, 12:33 PM
Team Member
Dan
Todd, the above is the key bit of information. If the primary's are all the way closed and the engine still runs the air has got to be getting in somewhere else - like a serious vacume leak. Of course, this assumes the linkage isn't binding and holding the throttle blades open.
Mark, that's another thing to quickly check. Disconnect the throttle linkage to be certain the butterflys are able to close. on their own.
Dan
SS 396 4sp
  #13
Old Dec 21st, 11, 12:43 PM
Mark
Dan
the throttle cable and even the trans kick down cables are loose. the throttle body is closed all the way.
1972 El Camino SS
4bbl SMI QuadraJet
Performer 2101
Points Distributor
76cc Iron Heads
E274s Cam
Stock Converter
Th350 Trans
  #14
Old Dec 21st, 11, 12:54 PM
Todd
Dan
Exactly Dan. That is why I am suggesting he eliminate the PCV and Evap canister (until he can get it to idle with the screw), as they are both controlled vacuum leaks. I believe the evap canister is supposed to be hooked to ported vacuum so it doesn't affect the idle circuit of the carb.
Still need to know what the timing is at idle.
  #15
Old Dec 21st, 11, 1:06 PM
Team Member
Dan
I hear ya Todd - agreed. Definitely a great idea to remove and cap any vacume ports on the carb to remove them from beign a factor.
In Marks other post on this subject he did mention that he shot propane or other flammable around the base of the carb and saw an increase in RPM. That, along with the other symptoms, still say carb base gasket leak.
I believe that until he can get this thing to idle down around 700 pursuing the timing will be an exercise in frustration for him. Depending on how high it's idling the centrifugal advance might already be starting. No amount of timing advance will keep an engine running if the air is choked off.
Dan
SS 396 4sp
Chevelle Tech > Mechanical > Engine      Current Topic: rochester quadrajet to the 2101 performer intake issue
Human Verification
