Exhaust/Gas Smell Inside of Car. Please Help! - Chevelle Tech
Auto Insurance
Old Nov 22nd, 11, 8:22 PM
C-Pep's 71 C-Pep's 71 is offline
Aaron
Default Exhaust/Gas Smell Inside of Car. Please Help!
I hope this post finds everyone well. I will try to be as detailed as possible.
1. The car starts and runs fine upon start up.
2. Once running, the car is emitting a strong exhaust/gas smell.
3. After driving the car to a destination or point, the exhaust/gas smell has “statured” the car and is very noticeable on our clothes, hair, etc.
4. Upon reentering the car, “she” starts back up and drives fine, but again the strong exhaust/gas smell.
In being detailed in this post, I must state that the headers are hooked up but that the exhaust system stops “midway” to the back of the car. In other words, the pipes do not run all the way to the back and out of mufflers. I am thinking that when they “rebuilt” the motor, the cut the fuel lines and exhaust and I know that a new exhaust system is need.
1. If the pipes are not extended all the way back, but only about midways (no further than the back of the front seat) would this cause the exhaust to “rise” back up into the car?
2. As with matters of this nature, everyone is an expert. Someone told me it’s not the exhaust at all but a leak from the engine/carburetor. Possibly the carburetor/engine is running “rich”.
3. In my “non-expert” opinion, I think a “full exhaust with mufflers” running to the back will “channel” the smoke exhaust straight to the rear outside of the car and not inside.
Again, I thank you for all suggestions and can reply with more details as needed.
Old Nov 22nd, 11, 8:50 PM
surmin69 surmin69 is offline
Bart
Default Re: Exhaust/Gas Smell Inside of Car. Please Help!
Do you have the cowl seal in place on the car (rubber piece running the length of the hood on the cowl) When I first had my car this piece was missing and I would get exhaust/gas smells in the car when moving. Installing this seal made a big difference.
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
http://www.chevelles.com/showroom/da...all_09_010.jpg
Old Nov 22nd, 11, 8:56 PM
Aaron
Default Surmin69
I don't think it is. Can this be purchased from a regular auto store or do I need to do through ssgroundup etc.
Old Nov 22nd, 11, 9:03 PM
Bart
Most of the restoration places will have it. local parts houses will not.
Running the exhaust out to the back will help also.
69SS Daytona yellow
L35, M-20, 3.73
Old Nov 22nd, 11, 9:13 PM
Aaron
I'm thinking this will help as well. Thanks a million.
  #6
Old Nov 22nd, 11, 10:28 PM
Boldly procrastrinating
TerribleTom II
You'll never get rid of the smell as long as the exhaust exits in front of the rear axle. get tailpipes first. and soon, that exhaust you're smelling is loaded with CO, not a good breathing thing.
Tom
  #7
Old Nov 22nd, 11, 10:52 PM
Helilog56 Helilog56 is offline
Bob
Aaron....Tom made an all too important point. Carbon monoxide poisoning is something too take seriously my friend. As stated, would highly advise too get those tailpipes installed.
Perhaps also consider a good tune-up.....sounds like she's running a wee bit rich !!!??!
Cars, Bikes, Beer (Mmmm....beer!) !
  #8
Old Nov 22nd, 11, 10:58 PM
novaderrik novaderrik is offline
Derrick
the inside of the car is a low pressure area when the car is moving- this is why the fresh air vents work- which means that air will get sucked in from anywhere there is a little hole.. unless the bottom of the car is sealed up like a boat, having the exhaust end under the car is a good way to guarantee that you will suck fumes in from under the car. getting the exhaust out from under the car will get it away from any place that will allow it to get inside the car.. but you sill might notice a little bit of a smell if your trunk isn't perfectly sealed up.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #9
Old Nov 23rd, 11, 7:50 AM
mr 4 speed mr 4 speed is offline
Unlike a new car where everything is controlled by a computer,air/fuel ratio kept perfect,etc. and even with everything sealed up,you will still get some kind of exhaust or "old car smell"
But,running a full exhaust,not having any leaks in the system,cowl seal all do help but it will not be perfect.
  #10
Old Nov 23rd, 11, 9:35 AM
rkd rkd is offline
Ron
Great info here, thanks.
Got some of this in the 66, or just noticed it this summer. Probably because I use it more and more, and have the other issues knocked down.
But with the drivers window open, and especially with the vent open, I smell exhaust. With the pass window also open, its ok. With the kickpanel vent open, and, or the heater on its ok. Windows closed ok.
So, this led to the redneck floor resto that I regaled you all with in gory detail on some other posts, to seal the front floors. Then I realized the trunk gasket had shrunk, so I sealed it, sealed the trunk floor a bit better, closed up the old shifter cable hole in the floor. Dont have a cowl to hood seal, but will get asap. Got a couple more holes where the steering column to cowl is missing some bolts. Got some rust around the trunk gasket channel. And no headliner, so the trunk is open to the backseat sail panel area.
Kind of annoying, because the new exhaust is tight all the way back and the old one had rusted through tailpipes.
66 Malibu Coupe, home rebuilt 350. Took me 39 years to get her!
  #11
Old Nov 23rd, 11, 10:31 AM
oldcutlass oldcutlass is offline
Eric
Also there are some plastic plugs on the firewall. If there are any emiisions from the engine, IE blowby or header leaks, it goes right into the car. I 100% suggest you run your exhaust out the rear of the car.
Your just jealous because you can't hear the voices!
1967 Olds Cutlass 468 BBC/T400
1963 Plymouth Fury 440/Torqueflite
2006 Ford Mustang GT (momma's car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
  #12
Old Nov 23rd, 11, 3:32 PM
Aaron
Spent the better part of today pricing exhaust sytems and most places are saying $150.00 and about 1 1/2 hours to complete. Thanks for the advice on the trunk as I know it has to be replaced with a new trunk floor. Also, at some point I'm going to put the car on a "lift" to fully check the floor pans etc. I will keep the community informed of the progress, and as always, thanks a million for all of the advice. Please know that it is well received.
  #13
Old Nov 24th, 11, 4:24 AM
TerribleTom II
$150? Wow, things are cheap where you live. get it before they change their minds.
Tom
  #14
Old Nov 24th, 11, 9:10 AM
383ram 383ram is offline
Chad
What are you getting for $150? Seems cheap.Real cheap.
There are some nice mandrel bent full systems out there, You'll pay more than $150, but they are designed to fit right.
As an alternative, you could put a 90 degree (or 45 degree if there is room) bend after the muffler to get the exhaust out the side of the car before the back tire. If I do this, I like to try and get a 45 degree bend in there as I feel it mor directs the gases out and away from the car better than a 90. But the point is to get it out away from the car---just have others have said.
CO posioning is not to be messed around with. Years ago some of the fumes never bothered me, but today I am pretty sensative to it---which makes doing old car stuff a battle. I just finished doing some maintance on my snowblower the other night, I started it up in the garage just to make sure it started---it did and ran for all of 20 seconds and I had to get out of the garage. A friend of mine warmed up his car in his garage (both overhead doors open) and within a half hour I was sick and throwing up and was nautious the rest of the night. It is serious stuff and can knock you out and kill you. Seal up all those opened holes up with plugs or silicone, get the exhaust out from under the car, and stay safe.
Built Ram tough with Chevy stuff.
454/4-speed overdrive swap into '85 Dodge Ram.
Mopar guy building a Chevy.
454, PP heads, dual 500cfm carbs and 'Vette manifiolds...First time out..Tire spin for half track
454 semi budget build Part1 followed by PartII
http://www.chevelles.com/forums/showthread.php?t=326289
  #15
Old Nov 24th, 11, 9:21 PM
Aaron
Default 383ram
$150 is just to finish extending the pipes. After futher checking, it does not include the mufflers.
Chevelle Tech > Mechanical > Engine      Current Topic: Exhaust/Gas Smell Inside of Car. Please Help!
Location
*REQUIRED*
Insurance
First Name
Human Verification
