89 camaro sub frame work for a 66 chevelle - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Nov 19th, 11, 10:39 PM
Ten Ten is offline
Tennessee
Default 89 camaro sub frame work for a 66 chevelle
i bought an 89 camaro rs for pretty cheap guy sold it because he drove it when it was really low on oil so it messed up the engine anyways im wanting to take the sub frame off this camaro along with the clutch assembly and put it under my chevelle i will also put the 5 speed manual from the camaro in the chevelle the chevelle is a malibu two dr original 4 speed car i wanna know if it would work in my chevelle
Old Nov 19th, 11, 10:48 PM
Mike Mike is offline
& Moderator
Default Re: 89 camaro sub frame work for a 66 chevelle
Chevelle has a full frame ,are you going to cut off the front of the frame to replace it with the Camaro subframe?
And if so - Why?
Old Nov 19th, 11, 10:50 PM
Ethan1 Ethan1 is offline
Ethan
And if so - Why?
What Mike said.
Ethan
1972 Chevelle
(oo________oo)
Old Nov 19th, 11, 11:00 PM
Ten Ten is offline
Tennessee
so i can use the rack and pinion steering and disc brakes
Old Nov 19th, 11, 11:01 PM
Ten Ten is offline
Tennessee
and i would cut the original frame to fit in the camaro frame
  #6
Old Nov 19th, 11, 11:11 PM
& Moderator
You might want to recheck the dimensions of both as I doubt the front clip (fenders,core support,grill,etc) will come close to fitting.
Don't think the frames will match up enough to graft together either.
Dale has some frame dimensions listed so have a look.
  #7
Old Nov 19th, 11, 11:23 PM
Ten Ten is offline
Tennessee
thanks for the help
  #8
Old Nov 19th, 11, 11:49 PM
72ragtop 72ragtop is online now
Jim
That's actually not a subframe, more like just a bolt in crossmember. It's a strut like front suspension, you need strut towers too. Really don't think it's feasable.
Jim
72 Chevelle SS conv http://www.fquick.com/454ragtop
  #9
Old Nov 20th, 11, 12:18 AM
Matty B Matty B is offline
Resident A-hole
Without being a total jerk, this is one idiotic idea. I will tell you why
1) Gen3 Camaros arent exactly known for their superior handling. Even in their time they werent corner carvers, so spending the amount of time and money on just getting that suspension on the car is like running the Boston Marathon backwards, admirable to some but bewildering to most.
2) There is much more aftermarket support for an A body as far as handling equiptment and it works a lot better than whats available for a 3rd Gen.
3) If all you are doing this for is R&P steering, there are companies that make ready to go kits that get you that without any cutting. Unisteer is the one that best fits that application and the one Id use.
Beyond that, I seriosly hope you are joking cause this is probably one of the worsy conceive ideas Ive ever heard of. Now it you said I have a DSE subframe for a 1st gen then Id be giving a few thumbs up but since you arent I think you need to shelve this horribly assembled idea.
1964 Malibu 5.3 LS twin turbo aka Maliboost coming soon BUT YOU WONT SEE IT HERE
  #10
Old Nov 20th, 11, 8:49 AM
elcamino66 elcamino66 is offline
Gold Founding Member
Thomas
Put a disc brake kit on it for a 66 chevelle, change the steering box to a 93-97 jeep grand Cherokee steering box. Do it all in a day and call it done.
http://www.carolinachevelle.com
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
http://www.chevelles.com/forums/albu...pictureid=6381
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
  #11
Old Nov 20th, 11, 4:50 PM
novaderrik novaderrik is offline
Derrick
no, no you cannot use the subframe from a 3rd gen Camaro in a Chevelle... and, no, the Camaro doesn't have rack and pinion steering..
stick with the basics and learn what you are doing.. disc brakes from a 69-72 Chevelle or any other A body are easy to bolt on. stock replacement Moog rebuild parts for the suspension are available at any parts store. a tighter steering box can be found in the junkyard. stiffer springs and better are readily available.
but the most important thing it to learn the basics before you start spending thousands and thousands of dollars on aftermarket parts that look cool but might not make the car any better for what YOU want out of it.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #12
Old Nov 20th, 11, 4:57 PM
Paul-ish Paul-ish is offline
Team Member
Paul
You should sell your chevelle to someone on this forum and build up the Camaro.
454/T400/9" in a 67 Beaumont
  #13
Old Nov 20th, 11, 5:19 PM
Hot66ss Hot66ss is offline
Moderator
Tom
Send a message via AIM to Hot66ss
Please tell me this is a joke.
Tom
21st Century Performance
(310) 425-8700
67 Velle- AFR headed 509/4L80 Pro-Touring.
68 Vette, Documented 427/435hp Tri Power, 4 speed- Sold
70 SS LS6/M22 Documented, black/white stripes- Sold
71 Elco SS 396/th400/12 bolt posi
01 Mustang Saleen, Convert. Stroked & Blown. 490RWHP/522RWTQ
Chevelle Tech > Specialty > Pro Touring      Current Topic: 89 camaro sub frame work for a 66 chevelle
Human Verification
