Need help with a vibration issue (Muncie) - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Nov 14th, 11, 9:19 PM
novadude novadude is offline
Default Need help with a vibration issue (Muncie)
I already think I know the answer, but I need a reality check.
Just got done converting my '65 Nova 327 from a PG to a Muncie 4-speed. I used a Hays Billet Flywheel (12-3/4"), and a Hays Street clutch. I've driven it < 100 miles. Transmission and clutch are working great, but I have a major problem.
I get a real noticeable vibration above 2000 rpm, and it gets really bad at 2500 rpm - enough to blur the rear view mirror and rattle the dash. It is not as noticable above 3000 rpm, but still there (just a higher frequency). I never had this problem with the PG. I replaced u-joints while it was apart. I can go ~50mph where the vibration is the worst. If push the clutch in to let the engine idle and the car coast at that speed, it is smooth as glass. Same is true at 70 mph. I can duplicate the vibes running the engine at those speeds in the garage.
At this point, I am pretty convinced that it can only be flywheel and/or pressure plate imbalance. Not real happy about this, as I used "quality" parts ($$) that were brand new - not Autozone China junk. Before I pull it apart, I wanted to see if anyone else has any other suggestions.
If it wasn't for this issue, I'd be really happy with the whole project. Clutch engagement is very smooth, and trans shifts perfect, whether under load or just cruising around.
So am I pulling the pressure plate and flywheel and visiting a machine shop for balancing, or does someone have other ideas? Thanks!
Old Nov 14th, 11, 9:41 PM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
Default Re: Need help with a vibration issue (Muncie)
Have you brought it up to 2500 RPM with the clutch engaged and trans in neutral?
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
Old Nov 14th, 11, 10:58 PM
Yup. Same vibes. Clutch in or out, in every gear. It is definitely RPM dependent. Seems worse on the road for some reason, but it could be my imagination.
Old Nov 15th, 11, 12:46 AM
Michael
Certainly sounds like something is off kilter in the rotating assembly.
Old Nov 15th, 11, 7:00 AM
dreis454 dreis454 is offline
Dan
Are you sure that you didn't get a flywheel for a 400sb?
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
  #6
Old Nov 15th, 11, 7:16 AM
I'm positive it is not a 400 flywheel. Hays 10-330.
  #7
Old Nov 15th, 11, 7:37 AM
WurlitzBurg WurlitzBurg is offline
Tom
NovaDude,
I had exactly the same problem. Severe vibes clutch in/out, moving or still. All based on engine speed. I pulled the trans and ran the engine with a jack uner the pan just in case. No vibration. I soon discovered the builder used the wrong GM bellhousing. It was for a truck and the locating hole for the trans case was too large. I bought a new bell, replaced the pilot bushing, dial indicated the bell hole to make sure it was centered and put it back together. End of problem. If you do not see anything wrong, I suggest you check center of bellhousing location. Use the hydraulic (grease) method of pulling the pilot bushing if you change it.
Tom
'69 SS396 4-Speed Hardtop Red/Red
http://photobucket.com/WurltzBurg
  #8
Old Nov 15th, 11, 8:38 AM
I am using a new non-magnetic bronze pilot bushing, and a '309' bellhousing specific to '64-67 Novas. The bearing retainer is a close fit in the bellhousing pilot hole. Thanks for the suggestion, but this probably isn't my issue.
I did check bellhousing pilot run-out, and it was 0.012" TIR (0.006" offset). This is just barely outside the acceptable 0.005" limit, so I feel pretty sure this isn't casusing my vibration. I'm sure GM sent cars off of the assembly line with far worse alignment. In 4th gear with the clutch in, the input shaft is turning at driveshaft speed, and I get no vibes in this situation at any speed, so I don't think misalignment is putting any excess load on the pilot bushing / front bearing.
Tom... beautiful '69... love the red interior!
  #9
Old Nov 15th, 11, 8:51 AM
bracketchev1221 bracketchev1221 is offline
I would think its in the flywheel or the clutch. I put mine in and didn't check the bellhousing.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
  #10
Old Nov 15th, 11, 10:16 AM
andrewb70 andrewb70 is offline
Andrew
If the vibration is present while the car is stationary, then it is in the rotating assembly. As you mentioned in your first post, I suspect the flywheel/pressure plate combo.
Andrew
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
1967 Cougar LSx build
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
  #11
Old Nov 15th, 11, 1:15 PM
Tom
Thanks, NovaDude. I'm glad you checked TIR on that bellhousing.
I had never done that before and hope I don't have to again.
Tom
  #12
Old Nov 18th, 11, 12:52 AM
5speeds 5speeds is offline
Paul
Sometimes people forget the basics as to how things work.
With the transmission in neutral, car at idle. Press down on the clutch pedal.
Put the transmission IN GEAR ( any gear )
Rev it up. If you have a vibration still, the transmission IS NOT even turning.
Typically engine flywheel , harmonic issues happen at the 2000 - 2500 rpm range. Try and have someone rev the engine up while you look at the engine. See if your belts look like the vibrate. I've seen water pumps as well as alternators cause vibrations.. Other issues I have seen are the clutch covers not being perfectly aligned with the flywheel.
Thanks,
Paul Cangialosi
http://www.MuncieBook.Com
http://www.transmissionbook.com ( Facebook Support )
http://paul.video ( Youtube Videos)
  #13
Old Nov 18th, 11, 6:35 AM
Thanks, Paul. It vibrates in gear with the clutch in and the car stopped. I guess it doesn't hurt to look at the front of the engine, but it didn't do this 3 months ago when I was driving it with the Powerglide. The only changes were the transmission, and replacing the flexplate / converter with a flywheel / clutch.
Seems like this keeps pointing to a bad balance from Hays, or maybe the clutch cover issue you mentioned. How would the clutch cover not be aligned? I used the special shoulder bolts that Hays provided, not regular fasteners. It basically ended up in the only place I could install it.
It's also interesting to me that you mention the 2000-2500 range, because that it where the vibration can be felt the most.
  #14
Old Nov 18th, 11, 11:48 AM
Tom
Sometimes you have to think outside the box.
My vibration got really bad at 2500 and up. It was caused by misalignment between trans input shaft and pilot bushing/crank axis.
From what you have checked, I don't think this is your problem but it could be good info for someone.
Tom
  #15
Old Nov 18th, 11, 5:40 PM
nitrofox nitrofox is offline
Jeff
Alignment dowel still in crank?
Jeff
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Need help with a vibration issue (Muncie)
Location
*REQUIRED*
Insurance
First Name
Human Verification
