200R4 vs 700R4 tranny? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Nov 10th, 11, 8:02 PM
davidmal davidmal is offline
Default 200R4 vs 700R4 tranny?
Hi everyone,
I have a 69 chevelle, with a turbo 350 auto. transmission with a 3:55 rear end. I am thinking of changing to an overdrive transmission. Any thoughts on the 200R4 vs 700R4 models and which would be best for my car. No racing here just pleasure driving. Main reason to switch would be for better gas mileage on the freeways and around town. Thanks
DJM
Old Nov 10th, 11, 8:33 PM
zombie1969 zombie1969 is offline
AKA Zombietroll
Default Re: 200R4 vs 700R4 tranny?
The 2004r would for the most part bolt in place of you t350 for an easy install.
64 Chevelle..5867.. FI SB406..700R4..12 Bolt..New door skins and full quarters...
My 64 chevelle SS convertible: http://youtu.be/iwF30uWmvD0
http://www.chevelles.com/forums/showthread.php?t=326530
http://www.chevelles.com/forums/showthread.php?t=334859
My new video! My 64 chevelle ready for paint.: http://youtu.be/iZ7CMku9ERY
Old Nov 10th, 11, 9:58 PM
Boldly procrastrinating
TerribleTom II
What Zombie said. I did that swap in my 70, re-used the driveshaft, crossmember, cooler lines, shift linkage, cable bracket at the carb, etc. had to move the crossmember back, 2 of the holes were already drilled. got a shorter park brake cable.
Tom
Old Nov 10th, 11, 10:33 PM
Alwhite00 Alwhite00 is offline
Had a 200R4 in my 70 - Loved it but make sure you can hook it up - that low first gear rocks. Had a 3:31 rear and it was damn near a perfect combo. 3:73 might be a little better but I don't know how you would ever hook it up if you had any power at all.
LK
The only difference between No.One & No one. is where you put the period.
67
http://i925.photobucket.com/albums/a...7/DSCF9178.jpg
70 (SOLD)
http://i925.photobucket.com/albums/a...e/DSCF9111.jpg
Sea Ray
http://i925.photobucket.com/albums/a...0/DSCF6826.jpg
Old Nov 11th, 11, 12:06 AM
chuckd71 chuckd71 is online now
Stu
200 is an easier swap. Otherwise, trans vs trans has been beaten to death and always turns into a pointless argument/ opinion thread. For pleasure driving one would be as good as the next, so a 200 is the simpler choice.
L92 / 200-4r 71 http://www.ls1tech.com/forums/conver...s1-begins.html
  #6
Old Nov 11th, 11, 12:26 AM
1971 Chevelle SS 1971 Chevelle SS is offline
Scott
I have a new 2004R with shift kit behind a mild 350ci, 3.73 rear gears, and it is a great combo. I usually manually shift because it's so fun to wind up the 350 and bump it into 2nd while still smoking the tires
1971 Chevelle Malibu
383ci - 2004R - 3.73
Code 62 - Burnt Orange
  #7
Old Nov 11th, 11, 1:15 AM
66138 66138 is offline
Elroy
700 is an easy swap too, did the 66 Camino, great upgrade !!
  #8
Old Nov 11th, 11, 1:57 AM
1966_L78 1966_L78 is offline
Tony
But the 700 requires a new or shortened driveshaft and I think a new yoke (which is usually a few hundred dollars at least), and maybe crossmember modifications... But not too much more work
The 200 is pretty much a direct swap for a TH350 or Powerglide...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
  #9
Old Nov 11th, 11, 8:29 AM
fleming23 fleming23 is offline
Eric
I will say I have enjoyed the 200-4R in my 70 as well. I went from a TH350 and 3.42 gears and the difference on the highway is phenomenal. 1st Gear is a great improvement too.
The 700 does have a steeper 1st gear but the 1st to 2nd ratio is not as desirable (IMHO) and the OD is a .7 vs a .67 (probably negligible at best) but does not bolt right up as previously mentioned. Be aware that not all drive shafts will bolt right up to the 200 and I and a few other members have had to have theirs shortened by about 3/4 of an inch or so.
70 Chevelle
496 cu. in. "cruiser"
Assembled & Tuned by Mo's Speed Shop Dallas, GA
  #10
Old Nov 11th, 11, 9:00 AM
bri2203 bri2203 is offline
Send a message via AIM to bri2203
I believe in stock form the 700R4/4L60(not to be confused with the 4L60E as it is eletronic) is stronger than the 200R4.
I will likely be installing a 700R4 in my chevelle because I have one and the parts are much more common. I type 200R4 in craigslist and I found 1 transmission, I type in 700R4 and I found over 50. If 200R4s were more popular I would lean in that direction for a few less RPM's and easy install.
UNDER CONSTRUCTION
1970 Malibu Hardtop with Fiber optics and electrotip wipers.
  #11
Old Nov 11th, 11, 9:25 AM
Robinls5 Robinls5 is offline
Bob
This is like the Chicken or the Egg ! I have a 700R4 in my driver 70 SS 468 Sta. Wgn. Installed it in 2003. NO Problems. It has around 30-35000 miles on it. NO I do not race it, Just drive it everywhere. ( 3000-5000 a year) Also, I am using the 307 driveshaft that was shortened around 2"
I would guess either a 200 or a 700 would be fine for a driver. On the interstate, I get over 20 MPG. With the A/C on it drops to around 18 MPG.
What ever you choose " You Gonna Like it ! "
My 468 in cruise control at 73 MPH. is turning 1950 RPMs. I have a 3:07 open 12 Bolt.
Bob
70 SS 454 El Camino 07 AACA Grand National Winner-MCACN-GOLD-2013
70 SS 454 Station Wagon - Driver
  #12
Old Nov 11th, 11, 9:44 AM
von von is offline
Lifetime Founding Member
Von
Yes the 200 has better ratios and usually doesn't require driveshaft shortening, but I'm in the middle of a 200 4R rebuild and I'm finding that 200 parts aren't as common and can be a little more expensive than 700 parts. Also it seems that in stock form (with a few exceptions like the Buick GN's) the 700 is a little stronger than the 200. There were many 700's in Corvettes, Camaros, Firebirds, trucks, big cars, etc. The 200's were usually put in cheaper, lighter, lower powered cars. But with a few low cost upgrades the 200 can equal or surpass a stock 700 in strength. Then I believe in ultimate strength the 200 can be built stronger than a 700 but expensive.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
  #13
Old Nov 11th, 11, 10:12 AM
slingslingbinks slingslingbinks is offline
Scott
I have always leaned toward the 700, even though it's more to swap over. my problem is that i can build a better 700 than a 200 and i have more 700 cores.
  #14
Old Nov 11th, 11, 12:56 PM
Bullcrappy Bullcrappy is offline
Bull
here are all the ratios:
http://www.oldengine.org/unfaq/leadfoot/trans.htm
CK sells tranys and parts
http://www.ckperformance.com/resourc...SMISSIONS.html
http://www.ptsxtreme.com/faq/display_faq.asp?faq_id=4
http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=C
1969 Chevelle Malibu
73k miles
350/330 crate motor
200-4r w/2400 stall
4.11 rear
Holley 4160 600cfm
Original console and bucket car
disc brakes
aluminum rad/elec fans
QA1 adjustable shock/new springs/new tubular control arms
http://photobucket.com/Rich69Chevelle
  #15
Old Nov 11th, 11, 1:25 PM
Tan66Elkie Tan66Elkie is offline
Jim
I'm with you Von, I chose the 700R, since I had one in my 88 P/U for 20 years and have the 4L60 in my 93 Vette...No problems with either and love the way it works with a healthy small block. If you can be sure the 200R is properly built up, I say it's a flip a coin proposition...200's tend to be a bit more expensive to buy and that negates the cost of shortening the drive shaft. Either way, it's a big improvement over the Powerglide.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 200R4 vs 700R4 tranny?
Human Verification
