using Pinchweld Primer To Install Glass - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Oct 29th, 11, 10:33 PM
SSuper Dave SSuper Dave is offline
Gold Member
Dave
Default using Pinchweld Primer To Install Glass
I'm setting my back glass using butyl tape. I have 3M pinchweld primer, and know its supposed to go on the painted channel where the glass sits, but does it go on the glass as well? Should I let it dry before dropping the glass, or do it while its still tacky? Thanks!
"Profanity is the linguistic crutch of an inarticulate mother f$%&er"
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
1968 300 Deluxe coupe, 461 inch stump puller, 2004R, Ermine White, red bench.
1968 Caprice coupe, Ash Gold/Ivy Gold, 327/300hp, N96 caps and whitewalls, buckets, console, am/fm and tach dash, tilt and a/c.
Old Oct 29th, 11, 10:41 PM
BlueSS454 BlueSS454 is online now
Tom
Send a message via AIM to BlueSS454
Default Re: using Pinchweld Primer To Install Glass
You can, it won't hurt anything, actually it should help promote adhesion. Just make sure you keep it no more than a 1/2" from the edge of the glass. you don't want any black showing past the reveal moldings.
Tom Rightler, MCC VP & Newsletter Editor
1970 SS Best ET: 12.31@108 MPH
1969 Malibu
1969 Dodge Charger
1970 Chevelle Convertible
Maryland Chevelle Club
Old Oct 30th, 11, 12:26 AM
TechNova TechNova is offline
Greg
we always masked 3/8" to 1/2" in from the edge of the glass before applying the primer. pull the tape off after priming.
71 Malibu
Asst Novas
Old Oct 30th, 11, 10:13 AM
Gold Member
Dave
Thank you!
Old Oct 30th, 11, 10:37 PM
Wyochevyman Wyochevyman is offline
Jeff
X2 what TechNova said. The easiest and cleanest way to do it is to run a piece of 1/2" painters tape around the edge of the windshield with the outer edge along the edge of the glass. The run another piece of 1/2" tape inside of the first piece with the outer edge just touching, but not overlapping the first piece. Then peel off the first piece (outer) that you laid down. You now have a perfect template. Apply primer and peel off the inner piece of tape. You will have a perfectly straight line along the inner edge of the primer in case it can be seen from the outside after the trim is in place.
  #6
Old Oct 31st, 11, 7:35 AM
Gold Member
Dave
I did something similar to that, the install went well, and its in there tight!
Chevelle Tech > General Tech Area > Body Shop      Current Topic: using Pinchweld Primer To Install Glass
Location
*REQUIRED*
Insurance
First Name
Human Verification
