What is best brake fluid to use? - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Oct 22nd, 11, 2:19 PM
Skier_Bob Skier_Bob is offline
Team Member
Default What is best brake fluid to use?
Experts - it's time to add fluid to and bleed new brake setup...... I have put in new lines from ground up, new tandem wilwood master cylinder and new wilwood two piston calipers..... my question is what is best brake fluid to use? ..... 71 chevelle, 550 hp...... street use only.... someday a test run at the track but not regular racing...... . Wilwood manual says Wilwood Hi Temp 570 grade fluid and not to use Silicone DOT5..... Thank you very much! what are your thoughts on DOT 3? DOT 4? DOT 5?
Old Oct 22nd, 11, 4:15 PM
9pass2drwgn 9pass2drwgn is offline
Dan
Default Re: What is best brake fluid to use?
If I do a complete new system I use DOT 5. Rated for very high temp., does not absorb moisture, and don't think it lifts paint if you spill it. It is more expensive though.
Dan
'65 Chevelle 2 Door wagon
9 passenger
Old Oct 22nd, 11, 6:07 PM
DN DN is offline
Dave
You'll get other opinions for sure, but for the street, I'm a Dot 5 guy too. Won't harm paint or booster plating. No problems for over 4 years.
Old Oct 22nd, 11, 6:46 PM
Vegas69 Vegas69 is offline
Todd
I'd certainly follow Wilwood's recommendation on their product. I've found that GM fluid or quality dot 3 is fine for the street. However, I've overheated those types of fluids when I run my multi events. Usually in the 0-100-0 or 0-80-0 events. I'm running the Wilwood 600 fluid now which is expensive but seems to give me a firmer pedal and a little more protection. For you application, I wouldn't spend the money.
Old Oct 22nd, 11, 6:55 PM
Mike Mike is offline
Um,so Wilwood says not to use Silicone Dot5 and your questioning that?
  #6
Old Oct 22nd, 11, 8:33 PM
Team Member
Wilwood says" Silicone DOT 5 brake fluid is NOT recommended for racing or performance driving........ so DOT5 silicone is ok for street........ I missed the part about racing and performance driving........just trying to learn....
  #7
Old Oct 23rd, 11, 6:54 AM
Monte Carlo Monte Carlo is offline
Mark
Dont forget the cross drilled brake lines
  #8
Old Oct 23rd, 11, 11:46 AM
72ragtop 72ragtop is offline
Jim
Huh?
  #9
Old Oct 23rd, 11, 1:58 PM
Team Member
i don't get that one either? thanks 72ragtop. Monte Carlo - what did you mean by that?
  #10
Old Oct 23rd, 11, 2:19 PM
Never visited Kaleco HUH?
Considering your set up and -Yeah,Yeah, street use only ,I'd go with the performance recommendation from Wilwood and not use the Dot5.
Your eventually going to play with it somewhat and you may also keep the warranty up ,if applicable
  #11
Old Oct 23rd, 11, 6:43 PM
Verle Verle is offline
Verle
High temperature DOT 4 is available if you don't want to use DOT 5.
Verle
Tulsa, Ok
65 Chevelle L79 since Feb 1965
http://i877.photobucket.com/albums/a...e6June2010.jpg
  #12
Old Oct 23rd, 11, 8:50 PM
Team Member
Thank you all very much. Agree that going with Wilwood recommendation seems best way to go. Calling them tomorrow to finalize and order.
Mike - just checked out the Kaleco site --- WOW! Cool to learn so much every day on this site. Thanks for taking the time to mention them.
  #13
Old Oct 24th, 11, 2:14 PM
UMI Tech UMI Tech is offline
Ramey
Another vote here to use Wilwood's recommended fluid. Wilwood provides awesome technical support and whatever they say, when it comes to their systems, I follow to the letter. I've always run their stuff on my oval track cars and have had good success.
Good luck.
ramey
Ramey Womer - UMI Performance, Inc.
Product Development Engineer
ramey@umiperformance.com
814.343.6315
www.umiperformance.com
Join us on Facebook!
  #14
Old Oct 25th, 11, 10:05 AM
Geoff1200 Geoff1200 is offline
Geoff
As a rule, fluid does not compress....but....DOT 5 does have some compressability. Brake pedal is often times a little softer, in my experience.This is why ABS systems don't use 5. Silicone DOT 4 is a real good compromise...
You may not post new threads
You may not post replies
