umm which way does this gasket go? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Oct 10th, 11, 4:58 PM
Bullcrappy Bullcrappy is offline
Bull
Default umm which way does this gasket go?
i put these aluminum exhaust gaskets on made leak worse so im guessing i put it on backwards??
on side is recessed... i put the lip facing out towards the header thinking it would seal around the flange?
here is the gasket and see pics below.
http://www.jegs.com/i/Mr-Gasket/720/...rentProductId=
1969 Chevelle Malibu
73k miles
350/330 crate motor
200-4r w/2400 stall
4.11 rear
Holley 4160 600cfm
Original console and bucket car
disc brakes
aluminum rad/elec fans
QA1 adjustable shock/new springs/new tubular control arms
http://photobucket.com/Rich69Chevelle
Old Oct 10th, 11, 5:10 PM
Hi-po SS 454 Hi-po SS 454 is offline
Richy Rich
Send a message via AIM to Hi-po SS 454
Default Re: umm which way does this gasket go?
Bull, the only choice YOU have left it is to try the other side no matter what anyone says.
Rich
71 SS clone, MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
https://www.youtube.com/watch?v=VzkB7RTVDUc
Old Oct 10th, 11, 5:13 PM
Bull
true true... just now im wondering i got a cracked header or something....
i guess i will just try other way...
73k miles
350/330 crate motor
200-4r w/2400 stall
4.11 rear
Holley 4160 600cfm
disc brakes
Old Oct 10th, 11, 5:23 PM
Richy Rich
I had one header that kept leaking with numerous new gaskets. Turned out that Hooker didn't do a good weld around one port on the header which didn't let the gasket seal properly. causing that ugly tick tick tick tick.
Rich
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
Old Oct 10th, 11, 5:30 PM
bracketchev1221 bracketchev1221 is offline
I would have thought flat side to the header. The head is always a good surface to seal to so that doesn't need help. The headers are junk, so they need a surface that will mold to it.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
  #6
Old Oct 10th, 11, 6:19 PM
Bull
thats what i did.. will call mr gasket tomorrow. no instructions i guess i should have just known...
73k miles
350/330 crate motor
200-4r w/2400 stall
4.11 rear
Holley 4160 600cfm
disc brakes
  #7
Old Aug 2nd, 12, 10:21 PM
Autoengineer Autoengineer is offline
I know this post is kind of old, but I had the same question and I couln'd find an answer here. I got on Percy's website and they had a Q&A section....here's what they say.
“Which way do I install the Seal-4-Good Flange Gaskets?” A: With the exception of the Big Block Ford Part #66035, all flange gaskets are installed with the smooth side out. There is a smooth rounded side and a sharp cut side, this sharp side goes on the head and the smooth side goes on the header flange.
72 Chevelle , SB 383, Voodoo roller, 219/227; .515/,530 lift; Patriot Al Heads, 10:1 compression; 12 bolt 3.42's
Vehicle weight: 3405 lbs http://i1281.photobucket.com/albums/...ps16a1d567.jpg
- 2007 Mustang GT
- 2013 VW CC 3.6 VR6
- 2014 Ford F150 FX Twin Turbo Ecoboost
  #8
Old Aug 3rd, 12, 3:44 PM
CoolBlueGlow CoolBlueGlow is offline
Keith
Chevelle Header Quick Installation Guide v6.4b
Step 1: Install headers - remove headers, tweak pipe clearances and reinstall headers
Step 2: Remove headers and tweak clearances again, reinstall and tighten bolts. Start car:
Step 3: scratch head at tickticktick leaking sound
Step 4: flip gaskets, retighten and start car
Step 5: repeat step 3
Step 6: re-tighten bolts again
Step 7: repeat step 3
Step 8: replace gaskets supplied with headers with "extra high quality super duper guaranteed no-leak" header gasket, tighten bolts and start car
Step 9: repeat step 3
Step 10: remove headers, sell on eBay, install cast iron manifolds, tighten bolts, drive car.
Keith
  #9
Old Aug 3rd, 12, 4:29 PM
Bull
i got them installed right and they are the best thing ever. sounds gr8 with no tick.
running cast iron manifolds is silly unless you got an all original car.
73k miles
350/330 crate motor
200-4r w/2400 stall
4.11 rear
Holley 4160 600cfm
disc brakes
  #10
Old Aug 4th, 12, 5:10 AM
Mr69 Mr69 is offline
If you want to really get a good seal, have the headers surfaced at a competent machine shop. Install copper gaskets. (Or NO gaskets at all). Use the Stage 8 locking bolts.
  #11
Old Aug 4th, 12, 5:49 AM
bdr66 bdr66 is offline
Keith
Lucky for me it was...
Bead blast shipping paint off
Spray high temp paint on
Slip headers in and bolt up with supplied gaskets
Check for clearance around things
Push both headers in towards the oil pan to gain clearance around a-arm pockets
fire up and bake the high temp paint on
Let cool a few minutes and re-snug up the bolts
Enjoy
Never really had a problem using cheepo header gaskets, just need to be snugged up after the first 5 short drives or so.
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: umm which way does this gasket go?
Human Verification
