How easy is it to install C Clip Eliminators? Do I need them? - Chevelle Tech
Auto Insurance
Old Sep 23rd, 11, 1:06 PM
prostreet75 prostreet75 is offline
Ryan
Default How easy is it to install C Clip Eliminators? Do I need them?
For my piece of mind, I want to install C clip eliminators. I have a 12 bolt chevy rear end with an Eaton Posi, 31 splined axles, and 4.11s.
- At what horsepower should I really be concerned? My car weighs 4100 lbs with me in it and I am pushing 600 HP.
- How easy are they to install or is my best bet to have a shop do it?
- Also, will the axles stay in the same location after they are installed or does the axle shift outward slightly? I run a large tire and want to make sure my tire-to-fender spacing doesn't change.
Thanks!
Old Sep 23rd, 11, 1:34 PM
bracketchev1221 bracketchev1221 is offline
Default Re: How easy is it to install C Clip Eliminators? Do I need them?
I would put them on. I am a huge fan of running them on a race car. They are not difficult to put on, but as far as I know you have to buy axles made for c clip eliminators. I could be wrong, its been a LONG time since I didn't buy race axles with the eliminators.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
Old Sep 23rd, 11, 2:52 PM
shomejim shomejim is offline
jim
I bought strange axels and a c-clip eliminator kit from strange engineering. Everything went together easily. it all comes in the kit, and doesn't move the flange . used the same brake drums and shoes it all clears.
Old Sep 23rd, 11, 3:30 PM
Lionel-n-Chevelles Lionel-n-Chevelles is offline
Gold Founding Member
Hi Ryan,
I have a 12 Bolt Housing with C-Clip Eliminators already installed with Moser Forged Axles if you are interested.
I would install Moser Flush Mount 9" Ford large bearing ends for non c-clip axles
(7900FM):
http://www.moserengineering.com/othe...lip-axles.html
I would also order a set of Moser Axles with the Large Press on Bearings.
Tory
ACES Member #1890
Team Chevelle Gold #288
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396 Unrestored 76,000 Mile Survivor
1968 Malibu L-79, 1 of 4082 - SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds w/ Factory Sunroof, 1 of 99
1985 442 White / Grey w/ Factory Sunroof - SOLD
Old Sep 23rd, 11, 4:18 PM
Ryan
Originally Posted by Lionel-n-Chevelles View Post
Hi Ryan,
Sent PM
  #6
Old Sep 23rd, 11, 5:39 PM
putput putput is offline
mike
they are very easy to install and at that weight and power I would run them for sure. Nothing should move as far as wheel and tires, but you will lose room for the parking brake spreader bar if running drum brakes. If you decide to go that way, be sure to stuff rage in the tubes before you cut the ends off so you dont leave a lot of metal in the tubes. Use a sawzall for cutting and use a piece of 1/16" pin stipe to wrap around the tube as a guide.
68 camaro
496ci 644tq 730hp and a lot of the street
shake down pass, 10.76 @128.52
fun>>
  #7
Old Sep 23rd, 11, 5:46 PM
Ryan
Thats good news. Thanks.
  #8
Ryan
Ok, thanks. I might go for it then.
  #9
Old Sep 23rd, 11, 7:04 PM
Bob West Bob West is offline
Green Weenie
Send a message via Yahoo to Bob West
I put them on my old 12 bolt before I bought the Moser housing. You ruin a good 12 bolt when you install them and I didnt like how they went together, seems like alot of weight hanging on very little metal. I ended up selling my 12 bolt with c clips after I went to Moser.
  #10
Old Sep 24th, 11, 7:11 AM
forcd ind forcd ind is online now
i have used the Moser kit, liked it better than the Strange-you can buy the aftermarket GM small ends, weld them on, open up your backing plates a little, retain your ex brakes, order the new axles and your good to go, even a good time to upgrade to 33 spline
some of the c clip elim. kits have interference inside the axle tube (GM kind of squished it downsizing it) and you might have to grind it inside
when your credit cards are maxed, have the limits raised
Chevelle Tech > General Tech Area > Performance      Current Topic: How easy is it to install C Clip Eliminators? Do I need them?
Location
*REQUIRED*
Insurance
First Name
Human Verification
