WATER PUMP pulley to thick for fan clutch to fit - Chevelle Tech
Auto Insurance
Old Aug 31st, 11, 8:16 PM
HPseeker HPseeker is offline
Javier
Send a message via ICQ to HPseeker
Default WATER PUMP pulley to thick for fan clutch to fit
I just installed a new aluminum water pump pulley ,the probelm is the pulley is to thick and the front pump shaft dont come out of the pulley to hold the fan clutch in the center .
The pump front shaft is not to long to hold the fan clutch in the back , the aluminum pulley is to thick and the shaft dont come out of the pulley to go in the fan clutch .
this help to hold the fan clutch to centralize ?
Anyone runnig aluminum water pump pulley with a fan clutch ?
71 GMC SPRINT
new 496, still tuning
11.44
1.56 60ft
116.8 mph
all steel car
http://www.dragtimes.com/Chevrolet-E...slip-5812.html
Old Sep 1st, 11, 1:39 AM
Javier
Default Re: WATER PUMP pulley to thick for fan clutch to fit
anyone with this problem ?
71 GMC SPRINT
11.44
1.56 60ft
116.8 mph
all steel car
Old Sep 1st, 11, 11:02 AM
greg_moreira greg_moreira is offline
What pulley?
I have a billett specialties water pump pulley, and it is indeed thicker. However...the pilot on the snout of the waterpump does go all the way through the pulley(I actually even have a shim behind the water pump to help with belt alignment). Granted...it barely comes out with the thickness of the pulley and shim together, but it still comes out just enough to get into the fan spacer.
FYI its a stewart stage 1 water pump, so basically a stock casting pump with the guts prepped by stewart.
Wonder if its the pilot on your water pumps fault? The billet specialties pulley works with a water pump using a pilot thats stock or the same length as stock(big block chevy long water pump app).
Old Sep 1st, 11, 8:24 PM
Javier
The pulley is from Speedway ZOOPS , 7" PULLEY .I will meassure the pump shaft and the pulley thickness in a moment .
71 GMC SPRINT
11.44
1.56 60ft
116.8 mph
all steel car
Old Sep 1st, 11, 9:42 PM
Javier
pump shaft .420"
pulley .360"
pulley inner bushing .470"
I will take the inner shim and the pulley to the machine shop make it fit , I only need like .080 shaft in the fan clutch to be safe ,I hope ...
I got a new but damage Weiand 8242 water pump and the shaft is .470", this pump was stored after I installed and noticed the fan clutch wont fit the pump ,so after 1 year in the box the pump is lock and I dont want to install it .
Any repair kit for the weiand 8242 pump?
71 GMC SPRINT
11.44
1.56 60ft
116.8 mph
all steel car
  #6
Old Sep 2nd, 11, 7:13 AM
forcd ind forcd ind is offline
i have milled the front of thick pulleys down enough to register the fan before
when your credit cards are maxed, have the limits raised
Chevelle Tech > General Tech Area > Performance      Current Topic: WATER PUMP pulley to thick for fan clutch to fit
Human Verification
