Best cam setup for this 454 big block - Chevelle Tech
Auto Insurance
Old Aug 27th, 11, 11:09 AM
michel1972 michel1972 is offline
Michel
Default Best cam setup for this 454 big block
Hello,
After a long vacation i went on with restoring my chevelle.
I have removed the engine from the car and i am looking for a good cam with distributor and ignition.
I have the following setup allready
The intake is a aluminium gm hi perf intake gm3933163 and the cylinder head is casting 6272990 with 118cc Replacement Rectangular port 325cc intake. I have 1 3/4 inch alu headers with a 3 inch collector and a holley 830cfm NASCAR carb.
So what cams will be best too use with this setup and what distributor and ignition do you recommend to me.
Thx for your help.
Old Aug 27th, 11, 11:57 AM
mr 4 speed mr 4 speed is offline
Default Re: Best cam setup for this 454 big block
manual or auto trans? what gear?
Old Aug 27th, 11, 3:00 PM
Stikman33 Stikman33 is offline
Daniel
hydraulic or solid, flat tappet or roller?
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
Old Aug 27th, 11, 5:19 PM
dreis454 dreis454 is offline
Dan
& what are you doing with the car Street or RACE???
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Aug 28th, 11, 5:08 AM
Michel
The axle ratio is 4.10 and i am having a TH400 automatic. Just wanne make it a street/strip car.
Here is a pic of my dyno sheet form last monday.
You can see how horsepower is dropping when the car is going faster. Also the th400 is not performing well.
I got 392 horsepower on the wheels.
  #6
Old Aug 29th, 11, 3:12 AM
Michel
Somebody any idea about the best cam , distributor and ignition?
  #7
Old Aug 29th, 11, 10:56 AM
cstraub cstraub is offline
How much rpm do you want out of the engine? Hyd roller or Solid roller? What rocker arm ratio is on the engine now?
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
www.distributorgears.com
Why is it we never have time or money to do it the right way in the beginning but we always have time and money to do it over again?
  #8
Old Aug 29th, 11, 12:08 PM
Michel
Good question. I dont know that. The guy that built the car is in jail.
How can i find out if i have a Hyd roller or Solid roller and how can i find out what the rocker arm ratio is.
When the engine goes above 4500 rpm it is losing power. So i suggest that the cam i am using now is not for higher rpm's
  #9
Old Aug 29th, 11, 12:16 PM
You are going to have to get into the engine see what you have. The heads are quite large so the engine won't start feeling good until after 4000 rpm but it is a stick car. If you want a max of 6500 or so I would go hyd roller. If you want to rev the engine higher then that we need to go solid roller. I can supply you the whole kit for either. If you need an idea on pricing PM me. You can check my reputation on this board, its pretty good.
Chris Straub
  #10
Old Aug 29th, 11, 2:39 PM
Michel
What do you mean with " the engine won't start feeling good until after 4000 rpm but it is a stick car"
Do you mean that these heads are made for higher rpm? So the engine will produce some power when i go above the 4000 rpm?
  #11
Old Aug 29th, 11, 3:46 PM
The heads are quite large for that CID so the manual tranny will help with this. A small roller cam can be used to broaden out the powerband and give me more useable power but we have to know what is in the car now.
Chris Straub
  #12
Old Aug 29th, 11, 4:18 PM
Michel
Ok,
I have a th400 automatic and not a manual tranny.
But do you mean that these heads are made for the higher rpm range? When will these heads give their best performance? above or below 5500 rpm?
So to find out what i have now i have to open my 454 engine and find out.
  #13
Old Aug 29th, 11, 4:29 PM
Ok thought I saw manual. Heads are best suited with that kind of runner volume to make power starting above 4000 rpm. Need to know what you have on the inside of engine now so we would know what you need to accomplish your goals.
Chris Straub
  #14
Old Sep 3rd, 11, 4:16 PM
Michel
Today i opened my engine and found out that i have Hydraulic Roller Tappet in the engine.
What else do you need to know to tell me what the best cam is for this setup.
I wanne start fresh and want to flow the 6272990 heads and put new valves in it.
  #15
Old Sep 4th, 11, 7:38 AM
427L88 427L88 is offline
Gold Member
Gene
Michel, I know you dont have access to a wide assortment of Chevy BB heads over there, but do flow the 990's. You may be somewhat disappointed in them, so the right cam will be critical. only experience with 990s on a 427, they were too big everywhere. ( so far the engine has made it best power with small, highly ported rectangulars so a rect head worked best, just not these unported ones.).
But you have 1/4" longer stroke to create more velocity.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
Chevelle Tech > General Tech Area > Performance      Current Topic: Best cam setup for this 454 big block
Location
*REQUIRED*
Insurance
First Name
Human Verification
