1972 floor and steering column shift linkage? - Chevelle Tech
Auto Insurance
Restoration Corner Where originality comes first.
Old Jul 31st, 11, 8:24 PM
stevieray stevieray is offline
Default 1972 floor and steering column shift linkage?
I was poking around in the engine bay of my 72 chevelle project and noticed I have linkage for floor and steering column shifting. I can turn the "collar" on the steering column to move the linkage. The floor shifter is also functional. Is this standard? Just seemed weird to me. Thanks
Old Jul 31st, 11, 8:59 PM
BlueSS454 BlueSS454 is offline
Tom
Send a message via AIM to BlueSS454
Default Re: 1972 floor and steering column shift linkage?
That's how it's supposed to be. The linkage from the column to the trans on a floor shift car is to prevent the shifter from being moved from the PARK position when the ignition is off.
Tom Rightler, MCC VP & Newsletter Editor
1970 SS Best ET: 12.31@108 MPH
1969 Malibu
1969 Dodge Charger
1970 Chevelle Convertible
Maryland Chevelle Club
Old Jul 31st, 11, 10:32 PM
That makes sense. I never thought of that. Thanks
Old Jul 31st, 11, 11:58 PM
1972malibu 1972malibu is offline
Doug
Exactly... We just went through reconnecting the linkage after doing a column to console conversion. Initially, I wasn't thinking we would reconnect the linkage, but after getting everything mocked up, we decided it would definitely be a better way to go.
-Doug
Our '72Malibu Build
Old Aug 1st, 11, 8:37 AM
JIML82 JIML82 is offline
The "Steering Column/Transmission Shift Interlock System" also prevents you from turning your ignition key all the way to OFF-LOCK while the car is moving straight ahead. GM was very concerned that with a locking steering column, a few people might turn off their ignition key and lock the steering wheel even though the car was moving. So they invented the backdrive system as a safety feature. You can always turn the engine OFF, but you cannot lock the steering wheel and remove your ignition key unless automatic transmission vehicles were in PARK or manual transmissions had to be in REVERSE.)
Locking the column while moving may seem remote but people sue over less obvious things.
Just a bit of trivia which may or may not be usefull. There are five positions for your ignition key in the ignition lock cylinder. From full CW to full CCW:
START, RUN, OFF, OFF-LOCK, & ACCESSORY.
Some header systems interfere with the backdrive linkage so a lot of owners remove the linkage and permanently lock the lower column lever full UP (out under the brake master cylinder) and at the same time the shift bowl near the dash (full CCW) is locked in position as well.
One other thing, some vehicles (I am not sure about your Chevelle) use the backdrive system to rotate the lower lever on the column which rotates the shift tube inside the column which actuates a switch which controls the backup lights and the park/neutral start. That switch may be mounted on top of the steering column tube down under the dash. If your state has safety inspections, you may need the linkage to operate the switch. (Other systems may have the park/neutral start switch mounted on the shifter in the console and would not be affected by eliminating the linkage.)
This paper (in Microsoft Word format) has several drawings that help explain the above.
http://jimshea.corvettefaq.com/?p=665#attachments
Jim
Chevelle Tech > Specialty > Restoration Corner      Current Topic: 1972 floor and steering column shift linkage?
Human Verification
