fuel tank removal - Chevelle Tech
  SS396.com and GROUND UP, The Source for 64-72 Chevelle Restoration Parts
Find El Camino Parts at SS396.com
Official Sponsor of Team Camino
Have Bed .... will travel.
El Camino Tech
El Caminos El Camino & Sprint
Old Jul 25th, 11, 6:35 PM
airboss airboss is offline
den
Default fuel tank removal
I have a 72 SS Elk small block that I ordered new in Sep. of 71. Its been in storage for the last 15 years. I'm replacing the fuel tank and all components associated with that. The tank is fairley empty, or should I say, volitale? Anyway, the leading edge tank strap bolts and nuts are rusted bigtime. I've done liquid wrench, large ratchet, open ends and box ends with no results. Leverage issues all the way.There are those that say use a die grinder and just cut the bolts, but the advent of a shower of sparks just doesn't seem prudent. Although its been sitting for that period of time, I still got a face full of very old gas when I disconnected the hoses from the hardlines. Anyway, any 'safe' suggestions??
  #2
Old Jul 25th, 11, 8:36 PM
davis95 davis95 is offline
Doug Davis
Default Re: fuel tank removal
If you're concerned about the sparks igniting the fuel fumes then take a hose and wet down everything under the rear of the car and proceed to cutting the bolts with a cut-off wheel or die grinder. A secondary precaution if you're still worried is to take a fan and put it at the rear of the car on high while you're grinding. I'd bet you'll be fine.
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
Old Jul 25th, 11, 11:15 PM
dashboard dashboard is offline
kevin
If your referring to the forward bolts I just looked at mine, itís on a lift, hacksaw or Sawsall. Lots of room there on a 72. If weight is a concern either shore it up or siphon the fuel out.
Old Jul 26th, 11, 1:32 PM
h8tulooze1 h8tulooze1 is offline
Stacy
If it's a Cali car, make sure to look for the Buildsheet on the top of the tank.
1967 Nova SS LS1
1970 El Camino SS396 L34
1965 Malibu Convertible SS
1970 Chevy SWB 4x4 BBC
Old Jul 26th, 11, 1:41 PM
oscar_a_wiggy oscar_a_wiggy is offline
i was in the same spot in march as you right now. take a hack saw and cut half way through the front bolts holding the straps. then take your wrenches and snap them in two. took me about 20 minutes to get both of them off doing it this way. i too though about using my rotary tool but used the hack saw to minimize sparks.
also, as mentioned above, i have a CA car and i found my build sheet on the top of the tank.
do a search on my name, i wrote up a paragraph on what i had to do and things that can "get-cha" when doing this repair.
good luck - oscar
OAW
1970 ElCamino SS396
Chevelle Tech > Specialty > El Caminos      Current Topic: fuel tank removal
Location
*REQUIRED*
Insurance
First Name
Human Verification
