Transmission Dip Stick Tube Issues - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Jul 11th, 11, 4:44 AM
NitroPsycho NitroPsycho is offline
Simon
Default Transmission Dip Stick Tube Issues
Hello all-
I have recently purchased a 66 chevelle and had to have the transmission rebuilt. After rebuild and putting it together it was noticed that the transmission was leaking. After investigation it was seen that the dipstick tube was not far enough into the transmission. This appeared to be a difficult fix since the tube is almost wedged completely between the firewall and engine block, but I got it tapped down all the way into the transmission and thought all was good. Well, it still leaks, and the weird thing is, is that it only leaks after it has been run, not during. It would also seem as though the transmission fluid is almost siphoning out of the transmission, since it has to go up to get out and on to the ground. I believe the O-ring may be bad on the dipstick tube and am going to replace that. I am just looking for advice in general, do you think that the O-Ring is the issue here? If so, can you recommend a better dipstick in general if I am going to have this one all the way out again? I am all for making that last bell housing bolt easier to get in as well.
Any and all advice is appreciated,
Thank You
Simon
Old Jul 11th, 11, 8:05 AM
Chevymetal Chevymetal is offline
Default Re: Transmission Dip Stick Tube Issues
Simon,
I had similar issues with my '66 and original dipstick going into a TH350. It was not cheap but I went with a Lokar flexible dipstick and solved the issue.
For either TH350 or TH400
http://www.summitracing.com/parts/LOK-TD350400FM36/
700R
http://www.summitracing.com/parts/LOK-TD-3700FM/
Hope that helps.
66 Chevelle
400 SBC
11:1 Forged Flat tops
Dart Pro 1 Heads
4.56 gears
66 Chevelle
Engine Pic
Old Jul 11th, 11, 8:22 AM
ss1970chev454 ss1970chev454 is offline
Greg
Originally Posted by Chevymetal View Post
Simon,
700R
Hope that helps.
big x's 2 on that. after years of dealing with removing and reinstalling the trans. dealing with small leaks and big leaks. the lokar solved the problem.
TC # 4348
ACES # 6175
NCOA # 10479
"220...221 whatever it takes."
Registry for 68 13867 cars, total to date 169! Looking for more
http://www.chevelles.com/showroom/da...w_2007_019.jpg
http://www.chevelles.com/showroom/data/500/IMG_2694.JPG
Old Jul 11th, 11, 8:35 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
X3.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Jul 11th, 11, 8:38 AM
OLDED OLDED is offline
Team Member
Ed
Jack the car up as high as is safe on that side and remove the dipstick assembly (a bolt is holding the tube to the bellhousing). You may get some fluid running out of the hole, unless you have a drain plug in the pan. Take the old O-ring to NAPA and buy 2 new ones. Clean ALL the residual trans fluid off and out of the hole in the trans. install both O-rings on the tube about 1/2 way up to the flange and apply a small amount of blue or black gasket sealer to the O-rings and re-install the tube assembly being careful to insert it straight with the hole. Bolt the support bracket back on and you should be good to go. Did this on 3 - TH400's and so far none have leaked a drop. Good luck with it.
OLDED - It's STOCK if it's made by GM and it fits!
*65 Elky, Gen VI 496 BBC, TH400
*59 Vette, 283/270 hp. T5 5 spd., 4:11 posi.
*Harley - 06 Street Bob
*Life Member - Team Chevelle & Team ElCamino
*Peach State Chevelle Member
*Retired June 1, 2014****
  #6
Old Jul 11th, 11, 8:48 AM
novaderrik novaderrik is offline
Derrick
i've seen dipstick tubes that were cracked right where they go into the trans case before.. all the o rings in the world won't help with that. they crack where the tube bulges out right above the o ring groove, probably because they get bent when the trans is out or when someone is trying to force it into the trans case at a weird angle.
pull the dipstick out and inspect it. if it's wedged up against the firewall, take the bolt out of the trans mount and jack up the back of the trans to get the bellhousing away from the firewall.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
  #7
Old Jul 11th, 11, 12:16 PM
Dan Orgill Dan Orgill is offline
Team Member
Dan
I used a Hughes transmission dipstick, tophat stlye rubber seal and a lockable dipstick, works great.
Dan
  #8
Old Jul 11th, 11, 12:34 PM
dgcurrier dgcurrier is offline
David
Send a message via ICQ to dgcurrier
X2
The tophat seal is the only way to go. Here is a thread to check out.
http://www.chevelles.com/forums/showthread.php?t=339416
64 Malibu Convertible 327 all orig
66 El Camino 489 Resto Mod (work in process)
"Change is not always progress.... A fever of newness had been everywhere confused with the spirit of progress." -Henry Ford
  #9
Old Jul 11th, 11, 12:38 PM
Andy's Auto Repair Andy's Auto Repair is offline
Andy
Trying to get a 40 year old tube to seal peoperly is a tough one. It only took a minute in the last 40 or so years for it to get tweaked. And if the tube is on the firewall something is def up. Either you have the wrong tube, wrong mounts, or the frame is tweaked. If it has to be original it will take draining the trans and a bit of silicone. The Lokars are nice and are double oringed.
2014 Chevrolet SS 6.2 auto/ 2014 ZL1 Camaro 6.2 6 speed SC/ 2011 DurtyMaxx/ 2009 Tahoe 6.0/ 1994 Wrangler 6.0 /1981 Malibu 505/ 1971 Monte 496/ 1970 Chevelle454 1970 Monte 454/1965 442 400 auto. The 78 Bu parted out 1/15. 68 Velle parting as of 3/15
  #10
Old Jul 11th, 11, 8:09 PM
Derrick
40 year old body mounts coupled with a 40 year old trans mount could put the trans dipstick close to the firewall.
-Hank Hill
  #11
Old Jul 11th, 11, 10:58 PM
Kevin R Kevin R is offline
I purchased the Lokar dip stick and mounted it to the fender well in my 66
  #12
Old Jul 12th, 11, 1:37 AM
70-SS454 70-SS454 is offline
Frank Riley
Loose the O-Ring seal and go to the later top-hat type seal....that alone should solve your problem!
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Transmission Dip Stick Tube Issues
Location
*REQUIRED*
Insurance
First Name
Human Verification
