396 30 over need finishing need some advice??? - Chevelle Tech
Auto Insurance
Old Jul 1st, 11, 2:19 AM
jeffalberto jeffalberto is offline
jeff
Cool 396 30 over need finishing need some advice???
Sup guys so im trying to finish my powerplant for my 70 chevelle.
the block is a 1966 block (3855961) 2 bolt. done 30 over. (402) i belive, correct me if im wrong.
pistons are KB:http://www.jegs.com/i/Keith+Black/64...0.030/10002/-1
im unsure of the cami want to go with, i want it to have a very big loop. the velle will be mostly street driving but i surely dont want it to be a punk lol. most of my boys are runing LS swaps so i want to make sure to give them a run for there money
I am going to run this mpfi kit on there:http://www.summitracing.com/parts/HLY-92105211/
it is a oval port mani.. (keep in mind)
i have two sets of heads: 3856206, 14081045.
also i was thinking of going after market aluminum... i did not see to many small cc heads so im unsure of which ones. im trying to run hi compresion so we can make some good puppies. It says on jegs website that i can make 11:2:1 with 90cc..
my goal is around 550hp im hoping. also ill be running a th400 with a 12bolt.
also if you guys can... estamate what the e.t would be that would be nice..
LMK if you guys need any info and all the advice would be greatful. Thanks in advance!!!
Old Jul 1st, 11, 8:13 AM
jeff swisher jeff swisher is online now
jeff
Default Re: 396 30 over need finishing need some advice???
Iy you ask me you are pushing the limit or possibly past it with that intake and injector choice.
You will need quite a cam to pull off 550hp in the small cube power plant unless your heads flow really good.
We are talking a really good port job and a cam in the high rpm style...
You will need to be shifting that one around 7800 minimum in my book
And a good set up chassis and gears in the 456 range ...build it the way they did in the late 60's early 70's and you can have a quick small cube BBC
Although if i had to do it i would pick a good solid lifter cam in the 250-260 @.050 range and keep lift under .600" so that it is easier on valvetrain parts...I still like my 456 gears...i would also break it in with a single 4 carb and then install a tunnelram with 2 600 or 750 carbs...of course i am old school.
Old Jul 1st, 11, 11:14 AM
jeff
Thanks for the input jeff. any others? I would like to keep everything under the hood. im running a cowl hood..
Old Jul 2nd, 11, 11:25 AM
69 Post Sedan 69 Post Sedan is online now
Kurt
I agree with Jeff.....you will need one heck of a motor for 550HP. My 410ci BBC is 10.4:1 compression, Ross custom pistons made for my block, Comp Cams XR274R solid roller cam, GM 077 rectangular port aluminum heads, 163 stock intake and a 780 vacuum secondary. My motor came out to about 480hp on the dyno.
My car weighs 3800lbs with me in it. My best 1/4 mile time is 12.91 at 108MPH.
A better head/intake choice than mine will get you more HP but I'm not sure if it will be 70hp?????
Hope that helps, Kurt
1969 Chevelle SS396 300 Deluxe Post Sedan Bench Seat 4-speed
Lemans Blue w/Medium Blue Ransom Cloth Interior
CE 402 M22W 4.56:1 12 bolt
12.15@115
A foreign car bought is an American job lost!
TC# 5139
ACES#09593
MCACN Show 2010 http://i300.photobucket.com/albums/n...1010106-11.jpg
Street Trim http://i300.photobucket.com/albums/n...e/100_2256.jpg
Old Aug 28th, 11, 2:36 PM
jeff
Ttt
  #6
Old Aug 28th, 11, 2:39 PM
Mike Mike is offline
You are aware that the 66 block requires a grooved rear cam journal and a grooved rear cam bearing to provide oil to the top end correctly -right?
You may not post new threads
You may not post replies
