| Chevelle Tech Current Topic: TH350 shifting in burnout box | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Performance Our High Performance area |
Ive heard not to start your burnout in first gear and shift from 2nd gear with a TH350. Is this proven? I know all the major transmission shops say it. I just recently heard this but I have been doing this for 4 years or so without a single issue. We run a fairly stout sbc with around 600HP and a TCI Competition TH350, trans brake, reverse valve body, etc. 9" 4500 stahl B&M converter. Whats everybodys thoughts? Like I mentioned Ive been doing this for quite some time and never had an issue. Is this a ticking time bomb? Whats the theory behind this?
| Sponsored Links | ||
Advertisement | ||
#2
I have sbc th350 t/b from ati . They said to start the burn out n shift to 2nd because your wheel speed is faster n its easy to maintain a lower rpm while you heat your tires up . Nothing to do with blowin the trans just heat the tires up quicker so not as long of a burn out needed to get the same amount of heat in them
72 chevelle best et 10.45 on spray 131 mph 1.42 60ft still tuning 70 ss 396 4 spd #s matching (500 rwhp & 503 tq) http://m.youtube.com/watch?v=SsY4WCfBQEE# http://m.youtube.com/watch?v=_K_u1VHUb6A# |
On ATI's website it says with a TH350 start your burnout in 2nd and shift to 3rd. Just curious to why this is. |
I just leave it in 3rd and do the burnout. Keep the rpms where you wanr them. With 600hp you shouldnt have a problem doing this.
85 swb c10 496 10.5:1 Brodix RR-O Jake Performance TH400 6.89 @ 96.96 Never fry bacon naked!!
It i generally accepted that shifting 1-2 in the burnout can lead to intermediate sprag failure. I'm sure if you did a google search you would find hours of reading on the subject.
I've broken 2 th350 intermediate sprag outter races in the burnout over the years. But they were stock sprags with just the hardened outer race. With the 34 element spags i've never had a problem.
1967 Chevelle Malibu 4 door http://s145.photobucket.com/albums/r...ton/?start=all 8.60 @ 157.71mph http://www.youtube.com/watch?v=9zSGc...e_gdata_player |
#6
They said in 2nd or third you can control the motors rpms easly n you have a faster wheel speed . So the tires are spinning faster in 2nd n evan faster in third at the same rpm as you would in first . It realy just heats the tires quicker n lets you do a shorter burnout while heat up the tires the same as a first gear burnout n more control of over reving the motor in the burnout box .
#7
If you need to start in 1st, wait till the engine rpms stabilize before you shift, if the RPM's are still on the way up and you shift it's even more shock to the sprag. (and by "you" i mean the general automotive public, i'm not singling you out)
#8
I've got the TCI h/d drum with 34 element sprag in mine, been 1-2 shifting for 4 years now. As has already been stated, the 10 element stockers don't care for it. With nice parts, it'll live.
#9
I agree . Just throwin out what ati told me when I got the trans . They said same thing start in first but said as soon as tires spin hit 2nd . just how they told me is all . Plus I had them way over build my trans for hp I make .
#10
Just got off the phone with TCI and they said I have a 36 Element sprag in my trans. Good to hear
#11
I am no expert at all, but the experts explained to me the weakest link on a TH350 is the sprag. The sprag is used in second gear if I remember correctly and this is what fails. Its not from the burnout, it is from catching traction in second gear coming out of the burnout box (maybe also if not enough rpms). It does not like backlash however that occurs. Hope that helps.
1.55 60 ft 11.09 1/4 122.9 mph 512 ci, Team G, probe forged domes, rectangle port cast stockers,eagle rods, scat crank, 950 pro form, M and M TH400 w/brake, 4.10 gears N.A. "just an ole grain truk motor" Straub secret SR cam, stock appearing, 512 cubic inch monster!!!! Hopefully following the footsteps of the other famous Missourian drag racers, even though I'm too far North |
#12
Been shifting the 350 in the box for years. As said 2nd is the weak spot but its gonna happen or it aint. Just put a new TH350 in and the builder said just keep doint what I have been.The new one also has HD sprag though.
WARNING!!! Big Blocks Are ADDICTIVE |
#13
I start in 2nd and immediately shift to 3rd. I do it for the same reason. Seems the consensus is the trans will live longer. Mine is still holding up so far so plan on keep doing the same thing.
1969 Chevelle Junk Yard 6.0 Twin ON3 70mm Turbos Factory PCM/Wiring Harness/HPTuners PG/3.42/12 bolt/Stock Suspension E51-FROM THE ACTUAL PUMP/Non Intercooled "Street Driven" 6.04@114mph 1/8th mile http://www.youtube.com/watch?v=6SoucwBHxr4 Web Page :http://www.chevelles.com/forums/albu...pictureid=3383 Photo Album-http://s1009.photobucket.com/albums/...cpZZ1QQtppZZ20[/FONT] |
| Sponsored Links | |
Advertisement | |
| Display Modes | |
