3999289 or 14015445 Casting BBC? - Chevelle Tech
Auto Insurance
Old Jun 17th, 11, 5:34 PM
tonyvol tonyvol is offline
Tony
Default 3999289 or 14015445 Casting BBC?
Hey guys what do you think? I'm building a 496 that should make around 650-700 hp. It will be going into a street car. Should I use a 3999289 2 bolt or go with a 14015445 4 bolt? I heard that the 3999289 casting is suppose to be one of the thickest blocks. Not sure about the 14015445.
Thanks,
Old Jun 17th, 11, 6:01 PM
Busted Knuckles Busted Knuckles is offline
Default Re: 3999289 or 14015445 Casting BBC?
Depends on the year of the 5445 block, the last couple of years (89 & 90, I think), they're supposed to be thick, others are run-of-the-mill, nothing special.
The 289 is supposed to be a hoss, but I don't know that I've ever seen proof of it.
Gary Adrian
FCS Harmony Racing
'Cause if they catch you in the back seat trying to pick her locks,
They're gonna send you back to mother in a cardboard box...
You better run!
Old Jun 17th, 11, 8:46 PM
two junkers two junkers is offline
Arlo
Get them both sonic checked and go from there. I have seen 298 blocks with core shift that ended up being junk, and 445 blocks that were super thick. You can never judge a block by the casting numbers.
Regards, Arlo
Old Jun 17th, 11, 8:56 PM
Arlo
Regards, Arlo
Sorry, meant 289 blocks
Old Jun 17th, 11, 9:14 PM
Stokerboats Stokerboats is offline
Dan
I bought a 445 block that sonic checked at .300 everywhere. Went +.100 and still have Plenty left. That said they aren't all the same.
  #6
Old Jun 18th, 11, 1:01 PM
Tony
First of all, thanks guys for all the great advice. So, I guess what I'm hearing from you guys is that casting numbers aren't as important as the core thickness in the block. So do you guys know if the 445 blocks have a high nickel content like the 289 blocks? Or is that something not to be concerned about either?
Thanks Again,
  #7
Old Jun 18th, 11, 1:48 PM
Mike Mike is offline
& Moderator
UM ,the only high nickle BBC's I'm aware of are the Bowtie blocks.
All others appear to be created equally.
  #8
Old Jun 18th, 11, 2:32 PM
Arlo
I would guess that the older blocks had some what of a higher or "better" nickle content. Again, that's just a guess. I do know that the older 4 bolt main caps had a casting number of 964 on them, whereas the newer (445) blocks main caps had casting number 335. Everyone seems to want the 964s when they are converting a 2 bolt block to 4 bolt. Prices on E-bay seem to reflect that the 964s are harder or better than the 335s in some way.
Chevelle Tech > General Tech Area > Performance      Current Topic: 3999289 or 14015445 Casting BBC?
Human Verification
