XFI 2.0 Upgrade - Chevelle Tech
Auto Insurance
EFI Caution: Beyond here be monsters...
Old Jun 14th, 11, 9:27 PM
67 velle 67 velle is offline
Default XFI 2.0 Upgrade
Has anyone upgraded their XFI to the new 2.0 ? One of the improvements mentioned was "self tuning". That's what I'm after. Just would like to know if this feature works good as the other improvements would not help me.
It's $50 for software upgrade only or $100 for a enclose that says 2.0 on it too.
Name=Rich
Car=67 Chevelle Convertible
Color=Butternut Yellow
Engine=540 FAST XFI,1200 cfm
AFR 325cc CNC, Lunati 242/250 .601/.601/
Trans.=4L80E,TCU, 2700 stall
Diff.=Strange S60 3.54
Old Jun 15th, 11, 2:29 AM
ss396boy ss396boy is offline
Jason
Default Re: XFI 2.0 Upgrade
There is lots of info on it over at the EFI101 site. Seems to be a very good tool if you are not a great tuner. Here is the thread:
"All I gotta say is the Auto Tune is cool. I tuned the fuel table to a less than 5% correction then ran the Auto Tune and it knocked that down to 0-0.8%. Then we richened up the Target table and ran a dyno pull again and you could watch the O2% correction count down from -12% to less than -3% with an ending average of -2.7% at the end. This isn't going to replace a tuner or at the very least someone who at least knows the basics and uses common sense but it will help things get done quicker.
The new Auto TPS works great too, connect... go WOT and back a couple of times and it calibrates the TPS for you. Awesome. "
http://www.efi101.com/forum/viewtopic.php?t=6721
69 540 FAST EFI BBC El Camino"it's alive"
http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
Old Jun 16th, 11, 12:14 PM
bluzman2004 bluzman2004 is offline
Ron
It works wonders for the hardest part to tune, the cruise area. You just can't really get good logs in that area due to everything changing so much, but this picks through the good and bad and only uses the good. It works fine in WOT and Idle too, but those are always the easiest to tune.
Old Jun 19th, 11, 6:07 AM
blue66 blue66 is offline
Brian Gooding
If it works as well as Holleys self learning, which I would imagine it is comparable, It would be worth it. Unless you have a real good tune already.
66 Chevelle SS
496ci, Pump gas, no dominator, no spool, no electric fuel pump, no electric water pump, no big tires, full interior. N/A.
1.37
6.21 @ 109.7
9.82 @ 134.9
9.87 pass/grudge match http://youtu.be/Au6Lq7rH9Ak
"Keep your hopes up and your pedal down"....Rowdy
Old Jun 20th, 11, 9:05 AM
I purchased the upgrade. My file was corrupt and was setting codes that I did not have before. Flashed it back to old 1.340 per FAST request and problems went away. Waiting on new file now.
Name=Rich
  #6
Old Jun 22nd, 11, 1:53 AM
Jason
Rich,
Any chance you can you email me your GCT tune file?
  #7
Old Jun 22nd, 11, 9:48 AM
Yes I can afternoon sometime.
please note
My timing is locked at 40*,this may not work with your aplication.
My cam only makes 10" of vac. so my ve table numbers may not work for you.
Also this has never been on a dyno.
Only a hillbilly seat of pants tune
Name=Rich
  #8
Old Jun 22nd, 11, 9:20 PM
I sent the file today. Let me know how it does.
Name=Rich
  #9
Old Jul 10th, 11, 11:24 PM
six9chevelle.com six9chevelle.com is offline
Team Member
Ryan
We upgraded to 2.0 in our race car. Had to send the box back to FAST twice to get it to work. Learning only works at idle for us. Once the throttle is pressed learning is turned off and won't go back on. A very useful tool is the fixed timing tool. It will help you verify your crank signal degree.
Ryan
Under construction: 1969 Chevelle SS frame off pro-touring 'restoration'
My build blog: www.six9chevelle.com
I learn by doing and redoing.
Chevelle Tech > General Tech Area > Performance > EFI      Current Topic: XFI 2.0 Upgrade
Human Verification
