750 hp on the street - Chevelle Tech
Auto Insurance
Old Jun 14th, 11, 8:13 PM
wvnova wvnova is offline
dave
Default 750 hp on the street
has to run on pump gas and have a hyd roller. what would your set up be? i'm new to this board and after alot of google bbc searches this forum kept showing up. i respect your guys knowledge here after reading lots of threads. i have a 69 nova that weighs 3600 with driver a tko 600 and 4:10s in the 12 bolt. stock rear suspension. i want a kick a** street car. i currently have a world products 509 merlin [ i think its the only crate motor they have built that has been trouble free] that is supposed to make 575 hp @5800 and 595 tq @3500.i don't want to go to a solid roller because the car is currently undergoing a custom resto. and oil running all over the motor and subframe while adjusting the valve lash isn't happening. i don't plan on racing the car since there is no dragstrip close.
Old Jun 14th, 11, 8:18 PM
ryfrat ryfrat is offline
Ray
Send a message via Yahoo to ryfrat
Default Re: 750 hp on the street
oil running all over the motor and subframe while adjusting the valve lash isn't happening?
You do know the lash is adjusted without the motor running and with shaft rockers you'll hardly ever have to adjust them.I do not get oil spray on my car.
1969 Chevelle protouring
Old Jun 14th, 11, 8:26 PM
Ray
Mike Lewis forged 540/555 cu in 10:5:1
AFR 335
Chris Straub Soild roller and morel lifters
T and D shaft rockers
Victor jr intake
Pro systems hp 1000 carb
That should get you close for starters
Old Jun 14th, 11, 8:30 PM
67 velle 67 velle is offline
AFR 335
Victor jr intake
That should do it!
Name=Rich
Car=67 Chevelle Convertible
Color=Butternut Yellow
Engine=540 FAST XFI,1200 cfm
AFR 325cc CNC, Lunati 242/250 .601/.601/
Trans.=4L80E,TCU, 2700 stall
Diff.=Strange S60 3.54
Old Jun 14th, 11, 8:45 PM
crazydavey crazydavey is offline
Davey
I don't think you need 750 for a kick ass street car Dave. You won't be able to hook that anyway unless you want to do long smokey burouts, especially with a stick car...it would work for that...
750 would be a big stretch for a HR, not saying it couldn't done but a big stretch (and probably expensive). Any reason you chose that number? If you're at 575 now even going to 650/675 would be night and day and that's doable cost effectively....JMO...
Chevelle
http://www.firstgenmc.com/photopost/...um/david_4.jpg
SloMo...
https://www.youtube.com/watch?v=Fa13syTsA0E
'67 Chevelle 509 hyd roller
3.89's
9.44 best mph 141.30
5.97 best mph 114.44
3520 lbs
Straub/Foxwell
prepared by:
Nassimbene
Trubey
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
  #6
Old Jun 14th, 11, 8:50 PM
dave
no 750 is kinda a benchmark i set i don't want to do this again so i figure @750 i won't. hey i like long smokey burnouts
  #7
Old Jun 14th, 11, 8:51 PM
Greg Owens Greg Owens is offline
Save your money IMO. I actually don't think you would be able to tell the difference between 575 and 675 on the street. The tires are going to INSTANTLY light up with either combo and I doubt spinning the tires with 675 HP is any quicker than spinning them with 575. Maybe they stop breaking loose at 95 instead of 85 from a roll.
406 SBC, 9.3:1, AFR 195s, Comp XE294HR, TH400, Coan converter, 3.73
ProCharger D1SC, 8 psi., AIS meth injection, Carb Shop 750
1.319 60', 6.005@115.4 on pump gas
  #8
Old Jun 14th, 11, 8:53 PM
dave
no i didn't know that anytime i've seen it done the car was always running.hey thanks for the tip on the shaft rockers didn't know they worked that well. maybe i could be talked into a s.r.
  #9
Old Jun 14th, 11, 9:11 PM
GRN69CHV GRN69CHV is offline
Team Member
Joe
469" motor was maybe 550hp, new 540" motor is 650-680 hp. You can tell the difference. A step up to 750 hp would entail a much more radical motor. But what's really noticeable with the new 540" is the midrange punch and overall throttle response. Right there all the time from idle To 6000.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
  #10
Old Jun 14th, 11, 9:13 PM
mr 4 speed mr 4 speed is offline
wether its a flat tappet solid or a roller..you can certainly set the lash cold.
I don't set the lash on anything while its running anymore....
I am sure a s/r would wake the 509 right up and take it to the next level
  #11
Old Jun 14th, 11, 9:31 PM
wills65 wills65 is offline
Will
Procharger....Making more HP than guys can put through street tires since they started making 'em. I dont see you getting there any easier unless you slap a plate on it and spray it to 750hp. Any other way is going to cost you some substantial money and make the car more rowdy to drive than most would like with a stick and 4.10s. Plus you can step away from the tall gears and put some 3.55's in there to make it a little more livable to drive on the highway. Just my thoughts.
My signature doesnt work anymore...
  #12
Old Jun 14th, 11, 9:46 PM
540Hotrod 540Hotrod is offline
JIM
Basic 540/555 will do 750+ easily with a good Hyd roller and some CNC AFR 335's or Dart 335's or better. You can do it with a solid flat tappet also. Peak HP RPM will come in around 6300-6500 or so depending on cam. They really like the bigger intakes and carbs. That will get you over 800.
Solid roller is worth another 25-30 HP.
Mainly depends on RPM you want to be in.
JIM
'67 Vette-Pump gas 555"/Gforce 5 Spd/Dana 60 IRS-3.07's
3850LB
9.90@141.40
http://s318.photobucket.com/albums/m...rrent=Jim3.mp4
http://s318.photobucket.com/albums/m...rrent=Jim4.mp4
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
  #13
Old Jun 14th, 11, 9:47 PM
Orr89rocz Orr89rocz is offline
Justin
Turbo and shoot for more like 750 at the tires. 5-6psi should do it
1989 Iroc-Z Camaro
Dart SHP 401" Twin Turbo
1018 whp / 851 wtq pump gas only
  #14
Old Jun 14th, 11, 10:43 PM
dave
i wish i could afford a turbo motor!
  #15
Old Jun 14th, 11, 10:50 PM
dave
thnx for the replies ,750 at the tires would be awesome. what combos would you go with to get there [750 @ the flywheel]. afrs are in the cards so is a solid roller. how about a rotating assembly, cam , intake ,carb and anything i'm missing. seriously i don't care i want rubber in all 5 gears. when that happens then i'll try to hook it up
Chevelle Tech > General Tech Area > Performance      Current Topic: 750 hp on the street
Human Verification
