87 chevy 1/2 ton - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old May 1st, 11, 7:07 PM
TRANNY SMOKE TRANNY SMOKE is offline
JOHN
Default 87 chevy 1/2 ton
I picked up an 87 chevy 1/2 ton 2 WD with a 4.3 fuel injected V6 in. This is an overdrive truck. My question is, what transmission is under it? I'm assuming a 700R4, but not sure. Is so, is this trans. worth hanging on to? Thanks
If you borrow something more than once, you need your own!
Old May 1st, 11, 9:06 PM
zombie1969 zombie1969 is offline
AKA Zombietroll
Default Re: 87 chevy 1/2 ton
I think 87 was the year they made improvements to the input shaft and valve body so if that's true Id hang on to it for a bit anyway.
64 Chevelle..5867.. FI SB406..700R4..12 Bolt..New door skins and full quarters...
My 64 chevelle SS convertible: http://youtu.be/iwF30uWmvD0
http://www.chevelles.com/forums/showthread.php?t=326530
http://www.chevelles.com/forums/showthread.php?t=334859
My new video! My 64 chevelle ready for paint.: http://youtu.be/iZ7CMku9ERY
Old May 1st, 11, 9:27 PM
slingslingbinks slingslingbinks is offline
Scott
It might have the aux. valve body in it as well.
Old May 1st, 11, 10:14 PM
JOHN
I'm not sure what you mean by this? What trans. is in the truck? Thanks
Old May 1st, 11, 10:18 PM
Scott
If the trans has an ext. housing on it it is a TH700, If the case is all one piece and no ext. housing it's a 200r4. Yes on hang onto the tranny. Is that what u wanted to know?
  #6
Old May 1st, 11, 10:22 PM
Mike Mike is offline
& Moderator
If you have the whole truck ,look at the tag on the glove box door for the trans RPO code -believe it's MXO for the 700r4.
The 87 700r4 did have the aux. valve body and the improved input shaft.
  #7
Old May 4th, 11, 5:49 PM
JOHN
I found the MXO code on the glove box door. It must be a 700R4. Thanks
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 87 chevy 1/2 ton
Human Verification
