Best way to get 500 hp and 500 tq from 406 sbc - Chevelle Tech
Auto Insurance
Old Apr 24th, 11, 9:59 PM
Locotrician Locotrician is offline
Matt
Default Best way to get 500 hp and 500 tq from 406 sbc
Not looking to go "cheap" but at the same time would like to get the bang for the buck . What parts would you use / whatever will work ? Thanks.
Old Apr 25th, 11, 2:03 AM
VinceS427bb VinceS427bb is offline
Vince
Default Re: Best way to get 500 hp and 500 tq from 406 sbc
put some vortec heads and a small blower on it
68-Malibu 427/T400
F-1R HO-Intercooled
3.73 33-spline 12-bolt
http://i260.photobucket.com/albums/i...erinstall4.jpg
http://i260.photobucket.com/albums/i...-11-200715.jpg
Old Apr 25th, 11, 3:54 AM
Matt
hmmm..... not very feasible in N/A form ?
Old Apr 25th, 11, 10:00 AM
Scotch Scotch is offline
Scott
N/A will require a good 210cc head and a healthy solid roller cam. It's a lot of bang for the buck, but if you're wanting to cut corners and save a few bucks, you won't hit the goal. 500 horses/ft-lbs is not playing around. Although- you can hit those marks without any trick machine work or exotic porting...so that's pretty cool.
Follow my recipe and you'll make it for sure. It's quite a few bucks, but a LOT of bang..
http://www.popularhotrodding.com/eng...ild/index.html
See my Pro Touring '67 Chevelle Wagon at:
http://www.flickr.com/photos/1192966...7594110671642/
Winner- 2011 Car Craft "Real Street Eliminator" competition
Old Apr 25th, 11, 12:30 PM
Matt
thanks for the link but it looks like those matched kits stop a 388 cid.
  #6
Old Apr 25th, 11, 1:41 PM
Notalent Notalent is offline
Brandon
What are your goals and budget for the engine? Running power brakes/steering etc? What cam style?
Many ways to make the power, but at what price and streetable is another thing...
71 Chevelle
ATK Engines 496 Stroker
TH400 / 9 Inch 3500 Stall
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Need an engine...shoot me a PM.
ATK SBC Performance Cylinder Heads are on the way!
  #7
Old Apr 25th, 11, 1:50 PM
Scott
I designed/built those 2 engines with the same basic recipe. If you use the same components on your 406, you'll make similar (if not better) numbers. That's why I offered up the link.
  #8
Old Apr 25th, 11, 3:21 PM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Of course you could make those kinds of numbers pretty easily without using anything exotic at all by starting with a 454 or larger BBC.
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
  #9
Old Apr 25th, 11, 3:45 PM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
Shhhh, Rich. Don't you know that small blocks are the bees knees?
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
  #10
Old Apr 25th, 11, 4:22 PM
Scott
It's not too hard with the N/A SB either! Swapping over to a BBC adds weight to the nose and expense to the wallet. But yes, a 454 can make 500/500 pretty easily. A 502/502 can do it with a factory warranty too...but that's not what he asked about!!
  #11
Old Apr 25th, 11, 5:11 PM
Super Mod
Rich
Just offering other options and perspectives........
A big block with aluminum heads and intake weighs about the same as an iron small block.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #12
Old Apr 25th, 11, 10:33 PM
Matt
Well I would certainly like to go big block but I have this 406 already . I wouldnt be opposed to the bug block but the parts tend to.be more expensive . I really don't care what kind of cam setup I run but I do plan to be mostly a weekend driver on the street. Maybe I want too much .
  #13
Old Apr 26th, 11, 1:05 PM
Winston Wolf Winston Wolf is offline
My engine is very similar to the one in the article and is a 406. Same exact AFR heads and my cam is almost the exact same size too, except a Lunati (pn 60133). I have 11" of vaccum at idle and it pulls to about 6700 with the single plane. Torque peak is around 4600 rpms. I do have slightly higher compression, 10.25, and it runs without detonation at 37 deg total with 93 octane. I have not had this one on an engine dyno, just a chassis, but it did 438 rwtq/402 rwhp with an RPM Airgap intake and 437 rwtq/428 rwhp with a ported Super Victor. Even if you just figure in 20% drivetrain loss, you can do the math.
I think you could probably get close to that if you used a hyd roller too. When I went from a flat hyd to a solid roller, the biggest difference was the lower RPM torque went way way up.
You should be able to do what you want with off the shelf parts pretty easily. You are not asking too much at all.
  #14
Old Apr 26th, 11, 3:24 PM
marks412 marks412 is offline
mark
.060 over 817 block, 750dp, VicJr, AFR210, HEI dizzy with MSD parts. Crower hyd roller, -18cc dish KB Hyper pistons 9.3-1 compression (87oct gas!!!) 5.7 GM rods, Scatt 9000 series crank. 500hp 512tq all in buy 5,500. Verry easy now days with good heads and cams.
I had the block, rods, and pistons The heads were used, off a sprint car and needed guids. The shop I was working at had a wholesale account with Crower, thus a complete Crower valve train. Cam, lifters, push rods, rockers. I could have re-used the stock crank, but the cost of a Scatt 9000 series is hard to beat. I probably have about 3 grand total in this build, and it rocks!!!
And now with Craigslist, E-Bay, RacingJunk, etc, etc, etc, You can find much more parts thay you could about 10 years ago when I built mine. Good luck, and have fun!!!
1969 Chevelle
412 small block
M-20 4spd
4:11 12 bolt
1957 Thundarbird Gasser
Aluminum Shafiroff 582
Richmond 5spd
4:33 59 Olds rear
  #15
Old Apr 26th, 11, 8:48 PM
Matt
Thank you. That's exactly what I was hoping to get when I asked this question .
Chevelle Tech > Mechanical > Engine      Current Topic: Best way to get 500 hp and 500 tq from 406 sbc
Location
*REQUIRED*
Insurance
First Name
Human Verification
