Good oil for solid roller BBC break-in ?? - Chevelle Tech
Auto Insurance
Old Apr 23rd, 11, 10:58 AM
JIM JIM is offline
Jim/834
Default Good oil for solid roller BBC break-in ??
I assume no need for high ZDDP stuff since it is a roller motor. Machinist said not to use synthetic for the break-in.
Typical BBC, standard 1/16, 1/16, 3/16 ring package.
Isky EZ-X rollers (no needles)
Typical main/rod clearances.
Moroso 22175 Standard volume pump (which looked like an M77)
Got a suggestion for a good conventional oil for break-in?
Jim
My 70 Chevelle
The 454
Keisler/LGT SS700 5-speed
Best ET 11.39 @ 121 Mph
Old Apr 23rd, 11, 11:09 AM
sleeper sleeper is offline
Default Re: Good oil for solid roller BBC break-in ??
Any conventional good quality oil will be fine regardless of brand. I would use either the Shell or Delo diesel oil as first choice but any quality oil will be fine.
Old Apr 23rd, 11, 11:10 AM
ericrickster ericrickster is offline
brad penn has a break in oil,and after that I would highly recommend there 10/30 high performace oil,
works for street/strip [detergents]and still has zddp [zinc-phosphate] which other areas of the motor will still appreciate
I use it with a k&n 3002 oil filter and a moroso block off adapter for full time filtering
best place I know to get brad penn oil is here>>
http://theoilwarehouse.com/?mainURL=...acing_Oil.html
btw,nice choice of lifters,I was glad to hear ron [isky] speak highly of the brad penn oil when speaking to him about the lifters when they first came out
69 camaro ex-NHRA superstocker,548" 93 octane,g-force 4speed,9" w/ 4.86's and a lenco billet locker,NEVER to be trailered.9.63 at 141.80,1.38 60',126 mile round trip[3000rpm's at 60mph]
Old Apr 23rd, 11, 11:26 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
All I use is regular 10/30 detergent motor oil. Get maybe an hour running time on the oil, then do a filter and oil change. Overkill? ??? For oil, Typically Castrol , or whatever I can get a deal on. JMHO, breaking in a roller motor is more about having valve train adjusted correct, getting timing set and checking for leaks,etc. Especially with new valve springs, I like to get the motor just up to operating temp, then shut it down to heat cycle the valve springs.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Apr 23rd, 11, 11:31 AM
CDN SS CDN SS is offline
Gold Member
Bill
I used Shell delo 1st time to break in roller motor then switched to syn ............last time Ron at ISKY suggested the Brad Penn dino when I switched to ez roll lifters .......used that ....
66 CDN Malibu SS A51,L34,M20 Aztec Bronze
Now 439ci Straub Solid Roller Brodix RR ,Tremec by Liberty
10.97/ 124.31 1.41 60ft
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
  #6
Old Apr 23rd, 11, 11:53 AM
JIM JIM is offline
Jim/834
Found a dealer of Brad Penn near where I live. He has the straight 30w for break-in and carries everything but the 10w-30 racing oil. He stocks the 10w-40 racing oil. Think that would be good enough for street/strip or should I order the 10w-30 from the online place mentioned in the above post?
EDIT, added info..
The "break-in" oil has no zinc/phos listed... http://www.amref.com/CMSFiles/File/b...-In_Oil_PB.pdf
The dealer on the phone said they remove those additives to allow stuff to "wear in" faster.
But the 10w-30, 10w-40, 15w-40 racing oil does..
http://www.amref.com/CMSFiles/File/b...HP_Oils_PB.pdf
Jim
My 70 Chevelle
The 454
  #7
Old Apr 23rd, 11, 12:17 PM
69 Ratt Vette 69 Ratt Vette is offline
John
You guys get way to worried about oil, particularly for a street engine. Any brand name 10-30 or 20-50 will be fine. Nothing special for a roller motor.
Thanks Nitrous Supply 714 373 1986
I don't have a Chevelle, but I wish I did!!
69 Corvette Stingray
454, 6 speed, 11.87 @ 124 mph (full street trim) all motor, only trip to the track
63 Corvette A-gas / Top Sportsman
Pettis Performance 565 with two stages of Nitrous Supply nitrous systems.
Bests:
1.082
4.61 / 155
7.170 at 192.6
  #8
Old Apr 23rd, 11, 12:24 PM
rustbucket79 rustbucket79 is offline
Doug
Just because you have roller lifters doesn't mean you don't need a quality oil with a good additive package. If anything, you should be buying the best oil to keep those very spendy lifters alive. We use Gibbs BR for break in, then something like HR-2 until the rings are fully seated.
We saw an increase in roller lifter failures around the same time we started seeing more flat tappet lifter failures, back when they started to take "the good stuff" out of the oil.
www.carsengines.ca
  #9
Old Apr 23rd, 11, 1:33 PM
jeff swisher jeff swisher is offline
jeff
Some people take the cake, so to say...You spend all that money on a good rotating assembly and then more money on a roller cam and lifters.
Then you want to skimp on oil!!!!
I do not get the theory behind this thinking.
I use joe gibbs in all my breakin stuff...I also add zddplus to my mobil 1 synthetic in all my vehicles just 1/2 to 1/3 of the bottle depending on how much oil it holds....
When i visit my friend who owns his own cam shop i see the results of off the shelf oils and what they will do to roller cams...could be the oil could be wrong spring pressures....
Not only does zddp protect cam and lifters but it also protects wrist pins and bearings in the same manner......
  #10
Old Apr 23rd, 11, 1:52 PM
ShawnT ShawnT is offline
Shawn
I use Rotella 15w-40........ I must be a fool
85 swb c10
496
10.5:1 Brodix RR-O
Jake Performance TH400
6.89 @ 96.96
Never fry bacon naked!!
  #11
Old Apr 23rd, 11, 2:12 PM
JIM JIM is offline
Jim/834
Not trying to skimp on oil $$. Just trying to see what was good for break-in. I was planning on switching over to Torco synthetic after the break-in which sure aint cheap! But, if the Brad Penn (also green-ish in color like the Torco) will do the job and the spec sheet shows good amounts of Zinc/phos, I'd use it.
Jim
My 70 Chevelle
The 454
  #12
Old Apr 23rd, 11, 2:31 PM
jeff
I used the rotella in my ford i stopped 2 years ago when i noticed consumption problems,,,usually i would use 1/2 quart in 2500-3000 miles
then something changed in the oil,,, i was using 1 quart in 1500 miles. this was after a year and a half of using it
went back to mobil 1 and after the second oil change i am back to 1/2 quart in 2500-3000 miles
This vehicle is used mainly as a work horse always pulling heavy loads
I get 2mpg better with the mobil 1 also. so it must be cutting down on friction..royal purple runs the same as the mobil 1 in my testing
I do not run rollers i still like my flat tappits and i like to rev the snot out of them too.
ShawnT have you been using rotella for a long time and have you noticed any consumption issues.
I do put a lot of miles on my stuff,, average now is 15-20k miles per car a year 3 cars as daily drivers
a few years ago it was 2 cars and 73k on 1 and 45k on the other a year
That is a bunch of oil changes
  #13
Old Apr 23rd, 11, 3:05 PM
bracketchev1221 bracketchev1221 is online now
Castrol GTX 20-50. All I ever used in my engines.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.259 60'
  #14
Old Apr 23rd, 11, 3:35 PM
Shawn
I use the rotella for a break in type oil on ft cams with break in springs and oil. I run amsoil in my 496 but broke it in with rotella
85 swb c10
496
10.5:1 Brodix RR-O
6.89 @ 96.96
  #15
Old Apr 23rd, 11, 5:10 PM
PRO 48 Fleetline PRO 48 Fleetline is offline
George
Going in my Solid roller 406 build!
By profleetline at 2011-04-11
Chevelle Tech > General Tech Area > Performance      Current Topic: Good oil for solid roller BBC break-in ??
Human Verification
