how to neutralize a car after soda blasting - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Apr 22nd, 11, 8:34 PM
windycity-chevelle windycity-chevelle is offline
Rafiq
Default how to neutralize a car after soda blasting
Hey guys I am new to this site but I am a Chevelle guy. I am starting my restomod and just got my car soda blasted out here in Chicago. i am going to primer it to prevent any rust but was wondering what is the best solution to neutralize the soda before putting epoxy primer. Any ideas guys I want to do it the right way, I have my front floor and trunk floor ready to go in but cant start until i do this. Also what is the best epoxy primer. Sorry for all the questions
Old Apr 22nd, 11, 8:56 PM
strtcar strtcar is offline
Default Re: how to neutralize a car after soda blasting
Not to hijack this thread but where did you have it done at, and if you don't mind me asking how much did it cost? Looking to get it done to my 70.
Old Apr 22nd, 11, 9:00 PM
Raven1 Raven1 is offline
Scott
Too late now, you already did it. Why didn't the place that did the job give you explicit instructions on post op procedures? I never used soda and glad I never did all these years. Read on:http://www.chevelles.com/forums/showthread.php?t=337165
Old Apr 23rd, 11, 9:31 AM
jeremyb jeremyb is offline
Jeremy
did you have the inside hull and underneath sodablasted also?
only way to neatralize is water (warm water works best) and dawn dish soap or simple green. scrub with a red scotch brite and keep the metal wet as you are scrubbing.....do not let the panels dry up as you are washing...keep them wet until final rinse and after rinsing blow dry with clean air...blow into all the little holes and crevaces. once the metal is clean you will need to sand it with 100g/180g to give the primer something to bite to as soda doesn't profile the metal. clean with wax and grease remover and epoxy prime.
DO NOT use laquer thinner to clean the metal...sanding wont clean the soda either..no matter what you use.
the place didn't give him detailed instructions because most places dont know the detailed instructions on how to neatralize...they have no idea what the soda does to the metal and dont really care to know. main reason soda has revieved a bad wrap....i've used it on many show cars with ZERO problems. does it add a little more labor to the job? yes but in many instances the soda is quicker than other medias. i've done it both ways and no one can argue with me that soda is just sooooooo much more time consuming than general media blasting.....how long do you usualy spend blowing and blowing and blowing other medias out of the car? i'm STILL blowing the stuff out up untill it hits the paint booth for paint.
2 of the main problems from soda, 1 is not properly neatralizing.....will show up 6 months after painted when the car is sitting outside in the sun....small bubbles start to appear over the top surfaces of the car.
2nd is soda coming out from overlapped welded areas like doorjambs, floors, etc. it gets down in those cracks and is extremely hard to get out. I only have exterior panels sodablasted, if they need to be. We've since quit using soda on these areas because of that, besides thats where a lot of sanding labor comes in also, trying to sand all those little areas of metal to get the primer to bite.
as far as primers go, many manufacturers warn against using soda for the problems i've described above....just too much headache for them to deal with soda they just say dont use it....these soda comapanies just never put the time and effort into explaining how treat the substrates after being blasted.
I've used sikkens epoxy over soda cars for years...and have recently started using spi epoxy, and have used it over soda with no problems. best thing to do is contact the company you are going to use and explain the situation. more than likely they aren't going to be happy, but when properly neatralized and sanded, the epoxy with stick and you wont have any problems. Zero.
Old Apr 23rd, 11, 2:13 PM
Scott
My question was rhetorical...and sarcastic. If soda works for some and the end result is trouble free, that's great. If I've managed to scrape by all these years I'll just have to live without it.
  #6
Old Apr 23rd, 11, 2:39 PM
beatnik beatnik is offline
Your posts are always nasty and sarcastic. In fact, you sound like one miserable dude. It seems you're one of those people who try to make others feel bad so you can feel better.
  #7
Old Apr 23rd, 11, 3:01 PM
Scott
My posts are written in a dry and informational manner. Forums to me are used to acquire and provide data. I don't use public forums as a social device, they are merely tools. My social interaction methods require the physical presence of a person. The computer screen is incapable of substitution of what real life personal communication offers. Knowledge I obtain provided by others on line assists in the successful accomplishment of a task, adds to the tools and methods with a given field, and eliminates some of the possiblities of error.
Judging someone solely by what is written on a computer does not produce nearly enough information for an accurate assessment of the person in question.
  #8
Old Apr 23rd, 11, 3:57 PM
Ed.Camino Ed.Camino is offline
Ed
THAT'S TELLIN 'EM RAVEN1
I think your matter of fact manner with a twist of sarcasim is just fine.
Unless of course it is directed at me, cause I have a sensitive side .... what with bein in touch with my inner self and all
2 71 El Caminos
1-Project Polaris for the Marine
2-Dads 5th
I can sure take 'em apart.
  #9
Old Apr 23rd, 11, 4:07 PM
crazy canuck crazy canuck is offline
I thought this was a chevelle forum not a self help/therapy forum
  #10
Old Apr 23rd, 11, 4:27 PM
Rafiq
Every soda blasting shop wanted $800-1200 here I'n Chicago. I had this place come do it at my house $550 good Job and price I'f you ask me. I already know how to get it prep but wanted you guys ideas. Jeremyb thanks a lot do you have an email or # and Raven1 keep your smart remarks to yourself. Also I had them do just the outside, inside just the dash panel and inside rear seat bed and side inside quarter windows. I am getting ready to put I'n new front and trunk floor and will be replacing quarter panels, cowl panel and rear center window channel
  #11
Old Apr 23rd, 11, 6:44 PM
Scott
It was taken incorrectly. I suppose everyone else who gave input in that link I posted should keep their mouth shut about the negatives in regard to soda blasting also. If one posts on an open forum for all the world to read and respond, one should welcome all responses. Otherwise things should be kept in private and off line. People take far too many things they read the wrong way. Except for obvious direct personal attacks and insults.
  #12
Old Apr 23rd, 11, 7:06 PM
Dean Dean is offline
Moderator
What smart remarks Rafiq?
I don't see any "smart remarks" I only see advice from a expert in the body & paint field.
If you don't want to take the advice of an expert in the field, then don't ask.
Just don't be coming here telling folks not to post their opinions on a subject.
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
  #13
Old Apr 23rd, 11, 8:53 PM
Rafiq
My apologies Dean and Raven1, I appreciate every once advice and will take all I can. I know everyone has his/her own opinion and I will take all I can from you guys.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: how to neutralize a car after soda blasting
Human Verification
