How to id Holley with choke horn milled off.. - Chevelle Tech
Auto Insurance
Old Apr 21st, 11, 8:53 AM
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
Default How to id Holley with choke horn milled off..
I just picked up this Holley.
The guy said its a 750, it has 4 corner circuits on it.. But the choke horn was milled off
Is there anyway to tell what carb or cfm it actually is?
Aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
Old Apr 21st, 11, 9:44 AM
Dave427 Dave427 is offline
Dave 383 now
Default Re: How to id Holley with choke horn milled off..
Looks like a 750, it has down leg boosters.
Sometimes you can get lucky and it might have 4779 on a metering block.
Do the throttle plates have 172's and 173's?
850's will have 180 on the throttle plates.
800's usually have a 50 cc pump in the rear.
600, 650, 700's all have straight boosters.
Dave
Old Apr 21st, 11, 9:51 AM
bracketchev1221 bracketchev1221 is offline
I was going to "guess" the same. The number on the butterfly is an identifier, and like was said, it looks like it has a 30cc rear pump arm. Other thing is, I'm pretty sure you can measure a bore diameter difference compared to your 650.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
Old Apr 21st, 11, 9:53 AM
Aaron
Yeah the butterflys have 172/173 on them
I was just curious how to Identify, I could compare it to my 4777 and look in te Holley book.
Thanks guys
Aaron
71 chevelle
Dyno video NA
Old Apr 21st, 11, 4:42 PM
wrenchbender wrenchbender is offline
Barry
Measure the diameter of the venturis & the diameter of the throttle bores. Then match up with specs in your Holley book.
  #6
Old Apr 21st, 11, 10:22 PM
RB69SS396Conv RB69SS396Conv is offline
The metering blocks often have the carb's list # stamped on them in some form or fashion... might be possible to deduce that, then look it up in the Holley listing
  #7
Old Apr 22nd, 11, 6:57 AM
blasttime blasttime is offline
X2 thats exacly what to do you can modify holleys to 4 circuit idle so keep that in mind.
Chevelle Tech > General Tech Area > Performance      Current Topic: How to id Holley with choke horn milled off..
Human Verification
